    launch,yaml格式出现问题
    ros2 launch yaml
    • 4439640734
      房间里的大象
      launch出现问题,yaml格式
      ros2 launch cpp05_names demo03_names_launch.yaml
      [INFO] [launch]: All log files can be found below /home/fw/.ros/log/2023-04-03-11-07-41-350081-fw-14885
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): Caught exception when trying to load file of format [yaml]: Caught exception when trying to load file of format [yaml]: Expected only one root
        小鱼 技术大佬 @443964073
        @443964073
