    ORB-SLAM2 ROS部分代码编译问题
    orb-slam2 ros
      lightwxz
      大佬们,
      我现在在编译ORB-SLAM2 ROS部分代码,他是用的ROS1,所以我使用了 wget http://fishros.com/install -O fishros && . fishros,由于我的系统是UBuntu22.04,所以我安装了docker里的ROS1,但是依旧编译不成功。但是docker里的小海龟是可以跑起来的。
      报错信息如下:
      -- Found PythonInterp: /usr/bin/python (found version "2.7.17")
      [rosbuild] Building package ORB_SLAM2
      [rosbuild] Error from directory check: /opt/ros/melodic/share/ros/core/rosbuild/bin/check_same_directories.py  /home/xin/Documents/ORB_SLAM2/Examples/ROS/ORB_SLAM2
        File "/opt/ros/melodic/share/ros/core/rosbuild/bin/check_same_directories.py", line 46, in <module>
          raise Exception
      Exception
      CMake Error at /opt/ros/melodic/share/ros/core/rosbuild/private.cmake:99 (message):
        [rosbuild] rospack found package "ORB_SLAM2" at "", but the current
        directory is "/home/xin/Documents/ORB_SLAM2/Examples/ROS/ORB_SLAM2".  You
        should double-check your ROS_PACKAGE_PATH to ensure that packages are found
        in the correct precedence order.
        /opt/ros/melodic/share/ros/core/rosbuild/public.cmake:177 (_rosbuild_check_package_location)
        CMakeLists.txt:4 (rosbuild_init)
      -- Configuring incomplete, errors occurred!
      See also "/home/xin/Documents/ORB_SLAM2/Examples/ROS/ORB_SLAM2/build/CMakeFiles/CMakeOutput.log".
      如果docker还是不行的话:
      我需要在我的Ubuntu22系统上编译成功ORB-SLAM里的ros1代码请问我可以在Ubuntu22里安装ros1吗
