    第九章机器人仿真出现错误
    ros2 教材文档第九章
    5
    13
    6.2k
    • 4417555354
      头怎么还不秃啊
      第九章将启动gazebo和生产fishbot写成launch文件,运行后报如下错误:
      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_imu_sensor.so: libgazebo_ros_imu_sensor.so: cannot open shared object file: No such file or directory
      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_ray_sensor.so: libgazebo_ros_ray_sensor.so: cannot open shared object file: No such file or directory
      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_diff_drive.so: libgazebo_ros_diff_drive.so: cannot open shared object file: No such file or directory
      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_joint_state_publisher.so: libgazebo_ros_joint_state_publisher.so: cannot open shared object file: No such file or directory
      [spawn_entity.py-2] [INFO] [1682642034.099216784] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
      [INFO] [spawn_entity.py-2]: process has finished cleanly [pid 8160]
      • 4417555354
        头怎么还不秃啊
        urdf文件是直接复制的,应该不会错
        <?xml version="1.0"?>
        <robot name="fishbot">
        <!-- Robot Footprint -->
        <link name="base_footprint"/>
        <child link="base_link"/>
        <origin xyz="0.0 0.0 0.076" rpy="0 0 0"/>
        </joint>
        <!-- base link -->
        <link name="base_link">
        <visual>
        <geometry>
        <cylinder length="0.12" radius="0.10"/>
        </geometry>
        <material name="blue">
        </material>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </material>
        </collision>
        <inertial>
        <mass value="0.2"/>
        <inertia ixx="0.0122666" ixy="0" ixz="0" iyy="0.0122666" iyz="0" izz="0.02"/>
        </inertial>
        </link>
        <!-- laser link -->
        <link name="laser_link">
        <visual>
        <geometry>
        </geometry>
        <material name="black">
        </material>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </material>
        </collision>
        <inertial>
        <mass value="0.1"/>
        <inertia ixx="0.000190416666667" ixy="0" ixz="0" iyy="0.0001904" iyz="0" izz="0.00036"/>
        </inertial>
        </link>
        <!-- laser joint -->
        <parent link="base_link" />
        <child link="laser_link" />
        <origin xyz="0 0 0.075" />
        </joint>
        <link name="imu_link">
        <visual>
        <geometry>
        <box size="0.02 0.02 0.02"/>
        </geometry>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </collision>
        <inertial>
        <mass value="0.1"/>
        </inertial>
        </link>
        <!-- imu joint -->
        <child link="imu_link" />
        <origin xyz="0 0 0.02" />
        </joint>
        <link name="left_wheel_link">
        <visual>
        <geometry>
        <cylinder length="0.04" radius="0.032"/>
        </geometry>
        </material>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </material>
        </collision>
        <inertial>
        <mass value="0.2"/>
        </inertial>
        </link>
        <visual>
        <geometry>
        </geometry>
        </material>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </material>
        </collision>
        <inertial>
        <mass value="0.2"/>
        </inertial>
        </link>
        <origin xyz="-0.02 0.10 -0.06" />
        <axis xyz="0 1 0" />
        </joint>
        <origin xyz="-0.02 -0.10 -0.06" />
        </joint>
        <link name="caster_link">
        <visual>
        <geometry>
        <sphere radius="0.016"/>
        </geometry>
        </material>
        </visual>
        <collision>
        <geometry>
        </geometry>
        </material>
        </collision>
        <inertial>
        <mass value="0.02"/>
        </inertial>
        </link>
        <child link="caster_link" />
        <origin xyz="0.06 0.0 -0.076" />
        </joint>
        <gazebo reference="caster_link">
        </gazebo>
        <mu1 value="0.0"/>
        <mu2 value="0.0"/>
        <kp value="1000000.0" />
        <kd value="10.0" />
        <!-- <fdir1 value="0 0 1"/> -->
        </gazebo>
        <gazebo>
        <ros>
        <namespace>/</namespace>
        </ros>
        <update_rate>30</update_rate>
        <!-- wheels -->
        <!-- <left_joint>left_wheel_joint</left_joint> -->
        <!-- <right_joint>right_wheel_joint</right_joint> -->
        <!-- kinematics -->
        <wheel_diameter>0.065</wheel_diameter>
        <!-- limits -->
        <!-- output -->
        <publish_wheel_tf>false</publish_wheel_tf>
        </plugin>
          <plugin name="fishbot_joint_state" filename="libgazebo_ros_joint_state_publisher.so">
            <ros>
              <remapping>~/out:=joint_states</remapping>
            </ros>
            <joint_name>right_wheel_joint</joint_name>
            <joint_name>left_wheel_joint</joint_name>
          </plugin>
          </gazebo>
          <gazebo reference="laser_link">
          </gazebo>
        <gazebo reference="imu_link">
          <sensor name="imu_sensor" type="imu">
          <plugin filename="libgazebo_ros_imu_sensor.so" name="imu_plugin">
              <ros>
                <remapping>~/out:=imu</remapping>
              </ros>
              <initial_orientation_as_reference>false</initial_orientation_as_reference>
            </plugin>
            <always_on>true</always_on>
            <update_rate>100</update_rate>
            <visualize>true</visualize>
            <imu>
              <angular_velocity>
                <x>
                  <noise type="gaussian">
                    <mean>0.0</mean>
                    <stddev>2e-4</stddev>
                    <bias_mean>0.0000075</bias_mean>
                    <bias_stddev>0.0000008</bias_stddev>
                  </noise>
                </x>
                <y>
                    <mean>0.0</mean>
                  </noise>
                </y>
                <z>
                    <mean>0.0</mean>
                  </noise>
                </z>
              </angular_velocity>
              <linear_acceleration>
                <x>
                    <mean>0.0</mean>
                    <stddev>1.7e-2</stddev>
                    <bias_mean>0.1</bias_mean>
                    <bias_stddev>0.001</bias_stddev>
                  </noise>
                </x>
                <y>
                    <mean>0.0</mean>
                  </noise>
                </y>
                <z>
                    <mean>0.0</mean>
                  </noise>
                </z>
              </linear_acceleration>
            </imu>
          </sensor>
        </gazebo>
          <sensor name="laser_sensor" type="ray">
          <update_rate>5</update_rate>
          <pose>0 0 0.075 0 0 0</pose>
          <ray>
              <scan>
                <horizontal>
                  <samples>360</samples>
                  <resolution>1.000000</resolution>
                  <min_angle>0.000000</min_angle>
                  <max_angle>6.280000</max_angle>
                </horizontal>
              </scan>
              <range>
                <min>0.120000</min>
                <max>3.5</max>
                <resolution>0.015000</resolution>
              </range>
              <noise>
                <type>gaussian</type>
                <mean>0.0</mean>
                <stddev>0.01</stddev>
              </noise>
          </ray>
          <plugin name="laserscan" filename="libgazebo_ros_ray_sensor.so">
            <ros>
              <!-- <namespace>/tb3</namespace> -->
              <remapping>~/out:=scan</remapping>
            </ros>
            <output_type>sensor_msgs/LaserScan</output_type>
            <frame_name>laser_link</frame_name>
          </plugin>
          </sensor>
        </gazebo>
        </robot>
          小鱼 技术大佬 @441755535
          @441755535 前面的依赖没安装
          4417555354 2 条回复 最后回复 回复 引用 0
          • 4417555354
            头怎么还不秃啊 @小鱼
            @小鱼 可是文档里面要安装的东西我都安装了啊
            • 4417555354
              头怎么还不秃啊 @小鱼
              @小鱼 (base) hdm@hdm-virtual-machine:~$ sudo apt install ros-humble-gazebo-ros
              正在读取软件包列表... 完成
              正在分析软件包的依赖关系树... 完成
              正在读取状态信息... 完成
              ros-humble-gazebo-ros 已经是最新版 (3.7.0-1jammy.20230302.204832)。
              升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 33 个软件包未被升级。
                小鱼 技术大佬 @441755535
                @441755535 是plugins,建模仿真篇里的
                • 4417555354
                  头怎么还不秃啊 @小鱼
                  @小鱼 ok,已解决
                  25527284782 1 条回复 最后回复 回复 引用 0
                  • 4417555354
                    头怎么还不秃啊 @小鱼
                    @小鱼 谢谢鱼总
                    • 25527284782
                      BR @441755535
                      @441755535 请问怎么解决的啊,怎么安装plugins
                      • 25527284782
                        BR @441755535
                        @441755535 大佬求教
                        • 25527284782
                          BR @2552728478
                          @2552728478 网上查了下,已经解决啦👌
                          27521765252 1 条回复 最后回复 回复 引用 0
                          • 27521765252
                            勿扰清梦 @2552728478
                            @2552728478 你好,请问是咋么解决的?我也卡到这一步了。
                            D 1 条回复 最后回复 回复 引用 0
                            • D
                              dylanin1999 @2752176525
                              @2752176525 sudo apt install ros-humble-gazebo-ros-pkgs
