    Fishbot 四驱版使用PCA9685扩展PWM接口数量
    fishbot 四驱板 pca9658
    1.3k
      板子本身舵机接口不够,可以使用PCA9685进行扩展,该版本价格10元左右,某宝均可购买。
      驱动例程如下,PIO工程
      platformio.ini
      ; PlatformIO Project Configuration File
      ;   Build options: build flags, source filter
      ;   Upload options: custom upload port, speed and extra flags
      ;   Library options: dependencies, extra library storages
      ;   Advanced options: extra scripting
      ; Please visit documentation for the other options and examples
      ; https://docs.platformio.org/page/projectconf.html
      [env:featheresp32]
      platform = espressif32
      board = featheresp32
      framework = arduino
      lib_deps = nachtravevl/PCA9685-Arduino@^1.2.15
      main.cpp
      #include "PCA9685.h"
      PCA9685 pwmController;                  // Library using default B000000 (A5-A0) i2c address, and default Wire @400kHz
      PCA9685_ServoEval pwmServo1;
      void setup() {
          Serial.begin(115200);               // Begin Serial and Wire interfaces
          Wire.begin(18,19);
          pwmController.resetDevices();       // Resets all PCA9685 devices on i2c line
          pwmController.init();               // Initializes module using default totem-pole driver mode, and default disabled phase balancer
          pwmController.setPWMFreqServo(); // Set PWM freq to 100Hz (default is 200Hz, supports 24Hz to 1526Hz)
          for(int i=0;i<16;i++)
            pwmController.setChannelPWM(i, pwmServo1.pwmForAngle(0+i*10)); // Set PWM to 128/255, shifted into 4096-land
            Serial.println(pwmController.getChannelPWM(i)); // Should output 2048, which is 128 << 4
      void loop() {
