    ROS2的lifecycle的相关问题
    ros2 humble lifecyclenode
    1.0k
    • yudonghou123Y
      小猴同学
      系统ubuntu22.04,ROS2humble
      各位大佬们,我在项目中遇到这么一个问题,就是我的设备目前情况是这样的:
      在短途内通过wifi发送上电指令,上电后,通过PLC的上电状况来启动和暂停节点,举个问题的例子因为我的IMU和DVL是通过串口转socket向工控机发送消息,如果首先开启IMU的发布节点,而IMU没有上电,IMU节点会因为socket通信迟迟没有连接从而报错退出节点,因此我考虑使用lifecycle来管理节点,通过上电后返回的上电状态来启动和暂停节点的运行,但是lifecycle的客户端总是在响应过后,能够正常启动服务端节点,但是每次启动后,客户端总是会退出,必须重新运行节点,我想能让他持续等待下一次的下电状态,请问我应该怎么修改比较好.
      大佬们,我采用官方给的客户端程序如下(学的比较基础)
      #include <chrono>
      #include <memory>
      #include <string>
      #include <thread>
      #include <iostream>
      #include <stdio.h>
      #include <stdlib.h>
      #include <auv_msgs/msg/wifidata.hpp>
      #include "lifecycle_msgs/msg/state.hpp"
      #include "lifecycle_msgs/msg/transition.hpp"
      #include "lifecycle_msgs/srv/change_state.hpp"
      #include "lifecycle_msgs/srv/get_state.hpp"
      #include "auv_msgs/msg/wifidata.hpp"
      #include "rclcpp/rclcpp.hpp"
      #include "auv_lifecycle/lifecycle_var.h"
      #include "rcutils/logging_macros.h"
      using namespace std;
      using std::placeholders::_1;
      static constexpr char const *lifecycle_node = "ctd_sensor_publisher";
      static constexpr char const *node_get_state_topic = "ctd_sensor_publisher/get_state";
      static constexpr char const *node_change_state_topic = "ctd_sensor_publisher/change_state";
      template <typename FutureT, typename WaitTimeT>
      std::future_status
      wait_for_result(
          FutureT &future,
          WaitTimeT time_to_wait)
        auto end = std::chrono::steady_clock::now() + time_to_wait;
        std::chrono::milliseconds wait_period(100);
        std::future_status status = std::future_status::timeout;
        do
          auto now = std::chrono::steady_clock::now();
          auto time_left = end - now;
          if (time_left <= std::chrono::seconds(0))
            break;
          status = future.wait_for((time_left < wait_period) ? time_left : wait_period);
        } while (rclcpp::ok() && status != std::future_status::ready);
        return status;
      class LifecycleServiceClient : public rclcpp::Node
      public:
        explicit LifecycleServiceClient(const std::string &node_name)
            : Node(node_name)
        void init()
          Power_on_sub_ = this->create_subscription<auv_msgs::msg::WIFIDATA>("wifi_data_state", 10, std::bind(&LifecycleServiceClient::power_on_callback, this, _1));
          client_get_state_ = this->create_client<lifecycle_msgs::srv::GetState>(node_get_state_topic);
          client_change_state_ = this->create_client<lifecycle_msgs::srv::ChangeState>(node_change_state_topic);
        unsigned int get_state(std::chrono::seconds time_out = 1000000s)
          auto request = std::make_shared<lifecycle_msgs::srv::GetState::Request>();
          if (!client_get_state_->wait_for_service(time_out))
            RCLCPP_ERROR(
                get_logger(),
                "Service %s is not available.",
                client_get_state_->get_service_name());
            return lifecycle_msgs::msg::State::PRIMARY_STATE_UNKNOWN;
          // We send the service request for asking the current
          // state of the lc_talker node.
          auto future_result = client_get_state_->async_send_request(request).future.share();
          // Let's wait until we have the answer from the node.
          // If the request times out, we return an unknown state.
          auto future_status = wait_for_result(future_result, time_out);
          if (future_status != std::future_status::ready)
            RCLCPP_ERROR(
                get_logger(), "Server time out while getting current state for node %s", lifecycle_node);
          // We have an succesful answer. So let's print the current state.
          if (future_result.get())
            RCLCPP_INFO(
                get_logger(), "Node %s has current state %s.",
                lifecycle_node, future_result.get()->current_state.label.c_str());
            return future_result.get()->current_state.id;
          else
            RCLCPP_ERROR(
                get_logger(), "Failed to get current state for node %s", lifecycle_node);
        bool change_state(std::uint8_t transition, std::chrono::seconds time_out = 1000000s)
          auto request = std::make_shared<lifecycle_msgs::srv::ChangeState::Request>();
          request->transition.id = transition;
          if (!client_change_state_->wait_for_service(time_out))
            RCLCPP_ERROR(
                get_logger(),
                client_change_state_->get_service_name());
            return false;
          // We send the request with the transition we want to invoke.
          auto future_result = client_change_state_->async_send_request(request).future.share();
            RCLCPP_ERROR(
            return false;
          // We have an answer, let's print our success.
          if (future_result.get()->success)
            RCLCPP_INFO(
                get_logger(), "Transition %d successfully triggered.", static_cast<int>(transition));
            return true;
          else
            RCLCPP_WARN(
                get_logger(), "Failed to trigger transition %u", static_cast<unsigned int>(transition));
            return false;
      private:
        std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState>> client_get_state_;
        std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState>> client_change_state_;
        rclcpp::Subscription<auv_msgs::msg::WIFIDATA>::SharedPtr Power_on_sub_;
        std::mutex mtxlf;
        void power_on_callback(const auv_msgs::msg::WIFIDATA &power_on_msg)
          mtxlf.lock();
          ctd_powerflag = power_on_msg.bcontrolon_cabina;
          // cout<<ctd_powerflag<<endl;
          mtxlf.unlock();
      void callee_script(std::shared_ptr<LifecycleServiceClient> lc_client)
        rclcpp::WallRate time_between_state_changes(0.1); // 10s
        sleep(3);
        cout << ctd_powerflag << endl;
        if (ctd_powerflag == true)
          if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_CONFIGURE))
            return;
          if (!lc_client->get_state())
            return;
        if (!rclcpp::ok())
          return;
        if (ctd_powerflag == false)
          if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_CLEANUP))
            return;
            return;
        // activate
        //   time_between_state_changes.sleep();
        //   if (!rclcpp::ok())
        //     return;
        //   if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_ACTIVATE))
        //     return;
        //   if (!lc_client->get_state())
        //     return;
        // deactivate
        //     return;
        //   if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_DEACTIVATE))
        //     return;
        //     return;
        // // activate it again
        //   if (!rclcpp::ok()) {
        //     return;
        //   if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_ACTIVATE)) {
        //     return;
        //   if (!lc_client->get_state()) {
        //     return;
        // // and deactivate it again
        //     return;
        //   if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_DEACTIVATE)) {
        //     return;
        //     return;
        // we cleanup
        //    return;
        // and finally shutdown
        // Note: We have to be precise here on which shutdown transition id to call
        // We are currently in the unconfigured state and thus have to call
        // TRANSITION_UNCONFIGURED_SHUTDOWN
        //     return;
        //   if (!lc_client->change_state(lifecycle_msgs::msg::Transition::TRANSITION_UNCONFIGURED_SHUTDOWN))
        //     return;
        //     return;
      // void wake_executor(std::shared_future<void> future, rclcpp::executors::SingleThreadedExecutor &exec)
      void wake_executor(std::shared_future<void> future, rclcpp::executors::MultiThreadedExecutor &exec)
        future.wait();
        exec.cancel();
        // force flush of the stdout buffer.
        setvbuf(stdout, NULL, _IONBF, BUFSIZ);
        rclcpp::init(argc, argv);
        auto lc_client = std::make_shared<LifecycleServiceClient>("ctd_sensor_publisher");
        lc_client->init();
        // rclcpp::executors::SingleThreadedExecutor exe;
        rclcpp::executors::MultiThreadedExecutor exe;
        exe.add_node(lc_client);
        std::shared_future<void> script = std::async(
            std::launch::async,
            std::bind(callee_script, lc_client));
        auto wake_exec = std::async(
            std::launch::async,
            std::bind(wake_executor, script, std::ref(exe)));
        exe.spin_until_future_complete(script);
        rclcpp::shutdown();
        return 0;
      芜湖
        小鱼 技术大佬 @yudonghou123
        @yudonghou123 问题看的有点迷糊
        在 ROS2的lifecycle的相关问题 中说:
        看main函数,这个future完成后,代码就退出了。在script对应的函数里看到很多 return,检查下在哪里出现的return。
