    1、树莓派raspbian buster一键安装失败。2、安装了melodic和docker
    树莓派一键安装 melodic
    456
    • 16043339391
      莫上
      Run CMD Task:[sudo apt-cache search docker-ce ]
      [-]Result:success
      File "/tmp/fishinstall/install.py", line 91, in <module>
      File "/tmp/fishinstall/install.py", line 83, in main
      File "/tmp/fishinstall/tools/base.py", line 1233, in run_tool_file
      File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 236, in run
      self.install_ros_with_docker()
      File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 222, in install_ros_with_docker
      self.install_docker()
      File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 138, in install_docker
      run_tool_file('tools.tool_install_docker')
      File "/tmp/fishinstall/tools/tool_install_docker.py", line 64, in run
      File "/tmp/fishinstall/tools/tool_install_docker.py", line 55, in install_docker
      AptUtils.install_pkg_check_dep("docker-ce")
      File "/tmp/fishinstall/tools/base.py", line 1183, in install_pkg_check_dep
      result = AptUtils.install_pkg(name)
      File "/tmp/fishinstall/tools/base.py", line 1172, in install_pkg
      for key in dic.keys():
      AttributeError: 'NoneType' object has no attribute 'keys'
      一键安装 docker 和ros melodic 时最后报错,请问这要如何解决呀
      • 列表
      16043339391 1 条回复 最后回复 回复 引用 0
      • 16043339391
        莫上 @1604333939
        @1604333939 --2023-05-17 22:50:07-- http://fishros.com/install
        --2023-05-17 22:50:07-- http://fishros.com/install/
        再次使用存在的到 fishros.com:80 的连接。
        已发出 HTTP 请求,正在等待回应... 200 OK
        长度:582 [application/octet-stream]
        正在保存至: “fishros”
        2023-05-17 22:50:08 (22.2 MB/s) - 已保存 “fishros” [582/582])
        SSH is enabled and the default password for the 'pi' user has not been changed.
        This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
        正在读取软件包列表... 完成
        正在分析软件包的依赖关系树
        正在读取状态信息... 完成
        python3-distro 已经是最新版 (1.3.0-1)。
        python3-yaml 已经是最新版 (3.13-2)。
        升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 721 个软件包未被升级。
        --2023-05-17 22:50:10-- http://fishros.com/install/install1s/tools/base.py
        长度:42293 (41K) [application/octet-stream]
        /tmp/fishinstall/to 100%[===================>] 41.30K --.-KB/s 用时 0.1s
        2023-05-17 22:50:10 (411 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42293/42293])
        [-]Result:success
        基础检查通过...
        RUN Choose Task:[请输入括号内的数字]
        ---众多工具,等君来用---
        [6]:一键安装:nodejs
        [7]:一键安装:VsCode开发工具
        [8]:一键安装:Docker
        [10]:一键安装:微信(可以在Linux上使用的微信)
        [77]:测试模式:运行自定义工具测试
        [0]:quit
        请输入[]内的数字以选择:11
        --2023-05-17 22:50:21-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
        长度:11540 (11K) [application/octet-stream]
        正在保存至: “/tmp/fishinstall/tools/tool_install_ros_with_docker.py”
        /tmp/fishinstall/to 100%[===================>] 11.27K --.-KB/s 用时 0s
        2023-05-17 22:50:21 (52.0 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11540/11540])
        --2023-05-17 22:50:21-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
        长度:1366 (1.3K) [application/octet-stream]
        正在保存至: “/tmp/fishinstall/tools/tool_install_vscode.py”
        /tmp/fishinstall/to 100%[===================>] 1.33K --.-KB/s 用时 0s
        2023-05-17 22:50:22 (31.5 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1366/1366])
        --2023-05-17 22:50:22-- http://fishros.com/install/install1s/tools/tool_install_docker.py
        长度:2882 (2.8K) [application/octet-stream]
        正在保存至: “/tmp/fishinstall/tools/tool_install_docker.py”
        /tmp/fishinstall/to 100%[===================>] 2.81K --.-KB/s 用时 0s
        2023-05-17 22:50:22 (59.4 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2882/2882])
        欢迎使用一键安装ROS-Docker版,支持所有版本ROS,本工具由作者小鱼提供
        ================================1.版本选择======================================
        [1]:noetic
        [2]:humble
        [3]:foxy
        [4]:galactic
        [5]:melodic
        [6]:rolling
        [7]:kinetic
        [8]:eloquent
        [9]:dashing
        [10]:crystal
        [11]:bouncy
        [12]:ardent
        [13]:lunar
        [14]:indigo
        [0]:quit
        请输入[]内的数字以选择:5
        你选择了melodic(ROS1),该版本目前状态:长期支持
        ================================2.安装Docker======================================
        Run CMD Task:[docker version]
        [-]Result:code:127
        欢迎使用一键安装Docker,支持amd64和arm64架构系统,本工具由作者alyssa提供
        开始根据系统架构,为你下载对应版本的docker~
        [|]获取:6 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates In[-]Result:success --upgradable’ 来查看它们。
        Run CMD Task:[sudo apt install apt-transport-https ca-certificates curl software-properties-common -y]
        [/]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 721 个软件包未[-]Result:success
        Run CMD Task:[curl -fsSL https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu/gpg | sudo apt-key add -]
        [-]Result:success
        Run CMD Task:[sudo apt-key fingerprint 0EBFCD88]
        [-]Result:success deb) docker@docker.com
        Run CMD Task:[sudo add-apt-repository "deb [arch=arm64] https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu $(lsb_release -cs) stable" -y]
        File "/usr/bin/add-apt-repository", line 95, in <module>
        sp = SoftwareProperties(options=options)
        File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in init
        self.reload_sourceslist()
        File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
        self.distro.get_sources(self.sourceslist)
        File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
        (self.id, self.codename))
        aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/buster
        下载完成,接下来升级apt索引~
        开始安装最新版本docker CE~
        Run CMD Task:[sudo apt --fix-broken install -y]
        [-]Result:success
        • 16043339391
          莫上 @1604333939
          @1604333939 一键安装ros也失败了
          --2023-05-17 22:47:25-- http://fishros.com/install
          --2023-05-17 22:47:25-- http://fishros.com/install/
          正在保存至: “fishros”
          2023-05-17 22:47:25 (15.8 MB/s) - 已保存 “fishros” [582/582])
          正在读取软件包列表... 完成
          正在分析软件包的依赖关系树
          正在读取状态信息... 完成
          --2023-05-17 22:47:28-- http://fishros.com/install/install1s/tools/base.py
          2023-05-17 22:47:29 (409 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42293/42293])
          [-]Result:success
          基础检查通过...
          ---众多工具,等君来用---
          [6]:一键安装:nodejs
          [7]:一键安装:VsCode开发工具
          [8]:一键安装:Docker
          [77]:测试模式:运行自定义工具测试
          [0]:quit
          请输入[]内的数字以选择:1
          --2023-05-17 22:47:37-- http://fishros.com/install/install1s/tools/tool_install_ros.py
          长度:19115 (19K) [application/octet-stream]
          /tmp/fishinstall/to 100%[===================>] 18.67K --.-KB/s 用时 0.1s
          2023-05-17 22:47:37 (188 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19115/19115])
          --2023-05-17 22:47:37-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
          长度:2457 (2.4K) [application/octet-stream]
          /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s 用时 0s
          2023-05-17 22:47:38 (101 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
          --2023-05-17 22:47:38-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
          长度:7708 (7.5K) [application/octet-stream]
          /tmp/fishinstall/to 100%[===================>] 7.53K --.-KB/s 用时 0.001s
          2023-05-17 22:47:38 (6.50 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7708/7708])
          小鱼:检测当前系统debian10.13:buster 支持一键安装ROS
          [1]:更换系统源再继续安装
          [2]:不更换继续安装
          [0]:quit
          请输入[]内的数字以选择:1
          欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
          请选择换源方式,如果不知道选什么请选2
          [1]:仅更换系统源
          [2]:更换系统源并清理第三方源
          [0]:quit
          请输入[]内的数字以选择:2
          [-]Result:success
          删除一个资源文件
          [-]Result:success
          [-]Result:success
          [-]Result:success
          检测到当前系统架构为[arm64:buster],正在为你更换对应源..
          替换完成,尝试第一次更新....
          [|]获取:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [[-]获取:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease[/]获取:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates In[-]Result:success --upgradable’ 来查看它们。
          搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
          ['获取:1 https://mirrors.tuna.tsinghua.edu.cn/debian buster InRelease [122 kB]', '获取:2 https://mirrors.tuna.tsinghua.edu.cn/debian buster-updates InRelease [56.6 kB]', '获取:3 https://mirrors.tuna.tsinghua.edu.cn/debian buster-backports InRelease [51.4 kB]', '获取:4 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates InRelease [34.8 kB]', '已下载 264 kB,耗时 4秒 (65.5 kB/s)', '正在读取软件包列表...', '正在分析软件包的依赖关系树...', '正在读取状态信息...', '有 721 个软件包可以升级。请执行 ‘apt list --upgradable’ 来查看它们。']
          镜像修复完成.....
          [/]cl-curry-compose-reader-macros - Reader macros for function partial applicati[/]libcupt4-2-downloadmethod-curl - flexible package manager -- libcurl download[|]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[|]libcurl4-gnutls-dev - development files and documentation for libcurl (GnuTLS[-]libcurl4-nss-dev - development files and documentation for libcurl (NSS flavo[/]libcurl4-openssl-dev - development files and documentation for libcurl (OpenS[]flickcurl-doc - utilities to call the Flickr API from command line - document[]libflickcurl0-dbg - C library for accessing the Flickr API - debugging symbol[|]forensics-extra - Forensics Environment - extra console components (metapacka[-]gnupg1 - GNU privacy guard - a PGP implementation (deprecated "classic" versi[/]golang-github-moul-http2curl-dev - Go package for convert Golang's http.Reque[-]libghc-curl-doc - Documentation for the libcurl Haskell bindings; documentati[/]libghc-curl-prof - Profiling libraries for the libcurl Haskell bindings; prof[|]libghc-hxt-doc - collection of tools for processing XML with Haskell; documen[-]libghc-hxt-prof - collection of tools for processing XML with Haskell; profil[/]libghc-hxt-http-doc - Interface to native Haskell HTTP package HTTP; document[]libghc-hxt-http-prof - Interface to native Haskell HTTP package HTTP; profili[|]libresource-retriever-dev - Robot OS resource_retriever library - development[|]librust-curl+http2-dev - Rust bindings to libcurl for making HTTP requests - [-]librust-curl-dev - Rust bindings to libcurl for making HTTP requests - Rust s[/]librust-curl-sys+http2-dev - Native bindings to the libcurl library - feature[]librust-curl-sys+libnghttp2-sys-dev - Native bindings to the libcurl library [|]librust-curl-sys-dev - Native bindings to the libcurl library - Rust source c[-]librust-git2+curl-dev - Bindings to libgit2 for interoperating with git repos[/]librust-git2-curl-dev - Backend for an HTTP transport in libgit2 powered by l[]librust-libgit2-sys+curl-dev - Native bindings to the libgit2 library - featu[|]librust-libgit2-sys+curl-sys-dev - Native bindings to the libgit2 library - f[]libstrongswan-extra-plugins - strongSwan utility and crypto library (extra pl[/]golang-github-ssgelm-cookiejarparser-dev - Go library that parses a curl cook[-]Result:success ect inputstream addon for Kodi
          []升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 721 个软件包未[-]Result:success
          [-]Result:success
          [-]Result:success
          [-]获取:7 https://mirrors.tuna.tsinghua.edu.cn/debian-security buster/updates In[/]获取:8 http://packages.ros.org/ros2/ubuntu buster/main arm64 Packages [59.5 k[-]Result:success --upgradable’ 来查看它们。
          [-]Result:success r Robot OS roscpp-coreageKerberos
          [-]Result:success
          [-]Result:success
          [-]Result:success
          [-]Result:code:2
          [-]Result:code:2
            小鱼 技术大佬 @1604333939
            @1604333939 暂不支持这个系统一键安装,需要你自己装docker和ros
            • 16043339391
              莫上 @小鱼
              @小鱼 大佬,有没有安装教程呀
