    Ubuntu20.04安装ROS2失败
    ubuntu20.04 一键安装失败
    1.4k
    • Z
      lizeqing20021113
      Run CMD Task:[sudo apt-cache search python3-colcon-common-extensions ]
      [\]python3-colcon-common-extensions - Meta package aggregating colcon-core and c[-]Result:success
      [\]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 2 个软件包未被[-]Result:success
      [-]Result:success                            for argparse (for Python 3)
      [\]python3-rosdep2 - rosdep package manager abstraction tool for Robot OS (Pytho[-]Result:success                           anager abstraction tool for ROS
      Run CMD Task:[ls /opt/ros/rolling/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
      这是什么情况呢?Ubuntu20.04系统,安装ROS2rolling版本
      • Z
        lizeqing20021113
        RUN Choose Task:[请输入括号内的数字]
        [1]:noetic(ROS1)
        [2]:foxy(ROS2)
        [3]:galactic(ROS2)
        [4]:rolling(ROS2)
        [0]:quit
        请输入[]内的数字以选择:4
        请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
        [1]:rolling(ROS2)桌面版
        [2]:rolling(ROS2)基础版(小)
        [0]:quit
        请输入[]内的数字以选择:1
        [|]aptitude-common - architecture independent files for the aptitude package man[/]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[\]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[-]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[/]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[\]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[-]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[\]libcwidget-dev - high-level terminal interface library for C++ (development f[|]apt-cacher - Caching proxy server for Debian/Ubuntu/Devuan software repositor[/]apticron-systemd - Simple tool to mail about pending package updates - system[-]Result:success                           end for Debian
        Run CMD Task:[sudo apt install   ros-rolling-desktop -y]
        正在读取软件包列表... 完成
        正在分析软件包的依赖关系树
        正在读取状态信息... 完成
        下列信息可能会对解决问题有所帮助:
        • Z zeqingLi 将这个主题转为问答主题,在
        • Z zeqingLi 将这个主题标记为已解决,在
          小鱼 技术大佬 @zeqingLi
          @zeqingLi 提供完成的日志
