    microros通信问题
    MicroROS
    microros ros2-foxy
    • 29180954962
      天问
      ros版本:foxy
      库:根据网上教程自己生成的foxy版本的库链接文本,所以应该不是版本问题。
      硬件:STM32F407ZGT6
      程序:```
      /* Includes ------------------------------------------------------------------*/
      #include "FreeRTOS.h"
      #include "task.h"
      #include "main.h"
      #include "cmsis_os.h"
      #include "usart.h"
      #include "microros_tasks.h"
      #include "microros_allocators.h"
      #include "STM_custom_transport.h"
      #include "std_msgs/msg/int32.h"
      uint8_t ch = 'c';
      int i=0;
      /* Private includes ----------------------------------------------------------/
      USER CODE BEGIN Includes */
      /* USER CODE END Includes */
      /* Private typedef -----------------------------------------------------------/
      typedef StaticTask_t osStaticThreadDef_t;
      USER CODE BEGIN PTD */
      /* USER CODE END PTD */
      /* Private define ------------------------------------------------------------/
      USER CODE BEGIN PD */
      /* USER CODE END PD */
      /* Private macro -------------------------------------------------------------/
      USER CODE BEGIN PM */
      /* USER CODE END PM */
      /* Private variables ---------------------------------------------------------/
      USER CODE BEGIN Variables */
      /* USER CODE END Variables /
      Definitions for defaultTask /
      osThreadId_t defaultTaskHandle;
      const osThreadAttr_t defaultTask_attributes = {
      .name = "defaultTask",
      .stack_size = 128 * 4,
      .priority = (osPriority_t) osPriorityNormal,
      Definitions for LED1 /
      osThreadId_t LED1Handle;
      const osThreadAttr_t LED1_attributes = {
      .name = "LED1",
      .priority = (osPriority_t) osPriorityAboveNormal,
      Definitions for Microros */
      osThreadId_t MicrorosHandle;
      uint32_t MicrorosBuffer[ 3000 ];
      osStaticThreadDef_t MicrorosControlBlock;
      const osThreadAttr_t Microros_attributes = {
      .name = "Microros",
      .cb_mem = &MicrorosControlBlock,
      .cb_size = sizeof(MicrorosControlBlock),
      .stack_mem = &MicrorosBuffer[0],
      .stack_size = sizeof(MicrorosBuffer),
      .priority = (osPriority_t) osPriorityHigh,
      /* Private function prototypes -----------------------------------------------/
      USER CODE BEGIN FunctionPrototypes */
      /* USER CODE END FunctionPrototypes */
      void StartDefaultTask(void *argument);
      void LED1_Task(void *argument);
      void Microros_Task(void *argument);
      void MX_FREERTOS_Init(void); /* (MISRA C 2004 rule 8.1) */
      • @brief FreeRTOS initialization
      • @param None
      • @retval None
        void MX_FREERTOS_Init(void) {
      defaultTaskHandle = osThreadNew(StartDefaultTask, NULL, &defaultTask_attributes);
      /* creation of LED1 /
      LED1Handle = osThreadNew(LED1_Task, NULL, &LED1_attributes);
      creation of Microros */
      MicrorosHandle = osThreadNew(Microros_Task, NULL, &Microros_attributes);
      /* USER CODE END Header_StartDefaultTask */
      void StartDefaultTask(void argument)
      while(1){
      HAL_GPIO_TogglePin(LED_2_GPIO_Port, LED_2_Pin);
      osDelay(1000);
      USER CODE END StartDefaultTask */
      /* USER CODE END Header_LED1_Task */
      /* USER CODE BEGIN LED1_Task /
      Infinite loop /
      while(1){
      HAL_GPIO_TogglePin(LED_1_GPIO_Port, LED_1_Pin);
      osDelay(1000);
      USER CODE END LED1_Task */
      /* USER CODE END Header_Microros_Task */
      void Microros_Task(void argument)
      USER CODE BEGIN StartDefaultTask */
      rmw_uros_set_custom_transport(
      true,
      (void *) &huart1,
      cubemx_transport_open,
      cubemx_transport_close,
      cubemx_transport_write,
      cubemx_transport_read);
      rcl_allocator_t freeRTOS_allocator = rcutils_get_zero_initialized_allocator();
      freeRTOS_allocator.allocate = microros_allocate;
      freeRTOS_allocator.deallocate = microros_deallocate;
      freeRTOS_allocator.reallocate = microros_reallocate;
      freeRTOS_allocator.zero_allocate = microros_zero_allocate;
      if (!rcutils_set_default_allocator(&freeRTOS_allocator)) {
      printf("Error on default allocators (line %d)\n", LINE);
      // micro-ROS app
      rcl_publisher_t publisher;
      std_msgs__msg__Int32 msg;
      rclc_support_t support;
      rcl_allocator_t allocator;
      rcl_node_t node;
      //create init_options
      // create node
      rclc_node_init_default(&node, "cubemx_node", "", &support);
      // create publisher
      rclc_publisher_init_default(
      &publisher,
      &node,
      ROSIDL_GET_MSG_TYPE_SUPPORT(std_msgs, msg, Int32),
      "cubemx_publisher");
      msg.data = 0;
      for(;;)
      rcl_ret_t ret = rcl_publish(&publisher, &msg, NULL);
      if (ret != RCL_RET_OK)
      printf("Error publishing (line %d)\n", LINE);
      msg.data++;
      osDelay(10);
      /* USER CODE END StartDefaultTask */
      问题:当运行代理时可以检测到信息,但是运行命令无法查询到创建的话题,具体如下图
      ![屏幕截图 2023-07-13 150702.png](/forum/assets/uploads/files/1689236095760-屏幕截图-2023-07-13-150702-resized.png)
      ![屏幕截图 2023-07-13 150650.png](/forum/assets/uploads/files/1689236103715-屏幕截图-2023-07-13-150650.png)
      29180954962 1 条回复 最后回复 回复 引用 0
      • 29180954962
        天问 @2918095496
        上面两张图好像有问题,补充一下
        • 29180954962
          天问 @2918095496
          @2918095496 这个经过测试,找到了问题所在,在程序运行过程中,有几个语句的初始化出现了问题,导致了以上的问题出现,具体问题如下:
          //micro-ROS configuration
          true,
          (void *) &huart1,
          // micro-ROS app
          rcl_node_t node;
          rcl_ret_t ret1 = rclc_support_init(&support, 0, NULL, &allocator);
          // create node
          rcl_ret_t ret2 = rclc_node_init_default(&node, "cubemx_node", "", &support);
          // //create publisher
          rclc_publisher_init_best_effort(
          &publisher,
          &node,
          msg.data = 0;
          for(;;)
          msg.data++;
          osDelay(10);
          /* USER CODE END 5 */
          在以上几个初始化的时候会报错,rclc_support_init()在这个初始化时有时,返回数字1报一般性错误,rclc_node_init_default()这个会因为上一个初始化报错,返回数字101,上下文错误,还有就是 rcl_publish()会返回数字300,RCL_RET_PUBLISHER_INVALID指返回rcl_publisher_t无效。
          目前问题还没有解决,希望能给些指导,谢谢。
          14477904841 1 条回复 最后回复 回复 引用 0
          • 14477904841
            不惑 @2918095496
            @2918095496 请问解决了吗?
