    roscore 报错
    ros2 humble安装 roscore错误 ros2 humble
    1.2k
    • 10319186081
      1031918608
      c@wp:~$ roscore
      File "/usr/bin/roscore", line 37, in <module>
      from roslaunch.nodeprocess import DEFAULT_TIMEOUT_SIGINT, DEFAULT_TIMEOUT_SIGTERM
      File "/usr/lib/python3/dist-packages/roslaunch/init.py", line 62, in <module>
      from .scriptapi import ROSLaunch
      File "/usr/lib/python3/dist-packages/roslaunch/scriptapi.py", line 42, in <module>
      import roslaunch.parent
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 54, in <module>
      import roslaunch.server
      File "/usr/lib/python3/dist-packages/roslaunch/server.py", line 80, in <module>
      from rosgraph_msgs.msg import Log
      ImportError: cannot import name 'Log' from 'rosgraph_msgs.msg' (/opt/ros/humble/local/lib/python3.10/dist-packages/rosgraph_msgs/msg/init.py)
      小鱼小 W 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1031918608
        @1031918608
          wesafe @1031918608
          @1031918608 解决了吗,我也是这个问题,一直没解决
