在自定义服务环节出现了问题,求解决!
BorrowMoney.srv
String name uint32 money --- bool success uint32 money -
project(village_interfaces)Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
endif()find dependencies
find_package(sensor_msgs REQUIRED)
find_package(rosidl_default_generators REQUIRED)uncomment the following section in order to fill in
further dependencies manually.
find_package(<dependency> REQUIRED)
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)the following line skips the linter which checks for copyrights
uncomment the line when a copyright and license is not present in all source files
#set(ament_cmake_copyright_FOUND TRUE)
the following line skips cpplint (only works in a git repo)
uncomment the line when this package is not in a git repo
#set(ament_cmake_cpplint_FOUND TRUE)
endif()rosidl_generate_interfaces(${PROJECT_NAME}
"msg/Novel.msg"
"srv/BorrowMoney.srv"
DEPENDENCIES sensor_msgs
)ament_package()
<?xml version="1.0"?>
<package format="3">
<name>village_interfaces</name>
<version>0.0.0</version>
<maintainer email="ning@todo.todo">ning</maintainer>
<license>TODO: License declaration</license><buildtool_depend>ament_cmake</buildtool_depend>
<member_of_group>rosidl_interface_packages</member_of_group> #添加这一行<test_depend>ament_lint_auto</test_depend>
<test_depend>ament_lint_common</test_depend><export>
</export>
</package> -
@JerryNing 在 在自定义服务环节出现了问题,求解决! 中说:
BorrowMoney.srv
String name uint32 money --- bool success uint32 moneysrtring name
String 小写的
