    C++ 编译 Action: /navigate_to_pose 报错
    nav2 action ,报错
    1.1k
    • 651980546
      等待修复
      最后由 65198054 编辑
      编译报错信息如下
      : 第一条
      -1: error: CMakeFiles/node_hunter_ros2_qt.dir/src/rclcomm.cpp.o: in function `rclcpp_action::Client<nav2_msgs::action::NavigateToPose>::SharedPtr rclcpp_action::create_client<nav2_msgs::action::NavigateToPose>(std::shared_ptrrclcpp::node_interfaces::NodeBaseInterface, std::shared_ptrrclcpp::node_interfaces::NodeGraphInterface, std::shared_ptrrclcpp::node_interfaces::NodeLoggingInterface, std::shared_ptrrclcpp::node_interfaces::NodeWaitablesInterface, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::shared_ptrrclcpp::CallbackGroup, rcl_action_client_options_s const&)':
      第二条:
      error: undefined reference to `rosidl_action_type_support_t const* rosidl_typesupport_cpp::get_action_type_support_handle<nav2_msgs::action::NavigateToPose>()'
      附截图:
      CMakelist里包含了:
      报错代码主要是:
      #include <memory>
      #include "rclcpp/rclcpp.hpp"
      #include "std_msgs/msg/int32.hpp"
      #include <geometry_msgs/msg/twist.hpp>
      #include "geometry_msgs/msg/transform_stamped.hpp"
      #include "tf2/exceptions.h"
      #include "tf2_ros/transform_listener.h"
      #include "tf2_ros/buffer.h"
      #include "hunterdriver.h"
      #include "nav2_msgs/action/navigate_to_pose.hpp"
      #include "rclcpp_action/rclcpp_action.hpp"
      using NavigationAction = nav2_msgs::action::NavigateToPose;
      using NavigationActionClient = rclcpp_action::Client<NavigationAction>;
      using NavigationActionGoalHandle = rclcpp_action::ClientGoalHandle<NavigationAction>;
      NavigationActionClient::SharedPtr action_client_;
      action_client_ =
      rclcpp_action::create_client<NavigationAction>(
      (rclcpp::Node*)(node.get()), "navigate_to_pose");
      请问大佬,要改哪里?
      小鱼小 651980546 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @65198054
        @65198054
        • 651980546
          等待修复 @65198054
          @65198054
          找到问题了
          应该用nav2_msgs 而不是 nav_msgs
