    MicroROS开发时将程序烧录失败错误代码1
    MicroROS
    烧录失败 microros
    4.2k
    • 3307093903
      小豆
      Warning! Please install `99-platformio-udev.rules`.
      More details: https://docs.platformio.org/en/latest/core/installation/udev-rules.html
      CURRENT: upload_protocol = esptool
      Looking for upload port...
      Auto-detected: /dev/ttyUSB0
      Uploading .pio/build/featheresp32/firmware.bin
      esptool.py v4.2.1
      Serial port /dev/ttyUSB0
      Connecting....
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool.py", line 34, in <module>
          esptool._main()
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 1004, in _main
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 646, in main
          esp = esp or get_default_connected_device(
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 895, in get_default_connected_device
          _esp.connect(before, connect_attempts)
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 631, in connect
          last_error = self._connect_attempt(
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 572, in _connect_attempt
          self.sync()
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 435, in sync
          val, _ = self.command(
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 375, in command
          p = self.read()
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 307, in read
          return next(self._slip_reader)
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 1402, in slip_reader
          read_bytes = port.read(1 if waiting == 0 else waiting)
        File "/home/bigbean/.platformio/penv/lib/python3.10/site-packages/serial/serialposix.py", line 595, in read
          raise SerialException(
      serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
      *** [upload] Error 1
      ===================================== [FAILED] Took 3.75 seconds =====================================
       *  终端进程“platformio 'run', '--target', 'upload'”已终止,退出代码: 1。
       *  终端将被任务重用,按任意键关闭。
       *  正在文件夹 example10_hello_microros 中执行任务: platformio run --target upload
      Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
      Verbose mode can be enabled via `-v, --verbose` option
      CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
      PLATFORM: Espressif 32 (5.2.0) > Adafruit ESP32 Feather
      HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
      DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
      PACKAGES:
       - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
       - tool-esptoolpy @ 1.40201.0 (4.2.1)
       - tool-mkfatfs @ 2.0.1
       - tool-mklittlefs @ 1.203.210628 (2.3)
       - tool-mkspiffs @ 2.230.0 (2.30)
       - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
      LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
      LDF Modes: Finder ~ chain, Compatibility ~ soft
      Installing pyyaml with pip at PlatformIO environment
      /home/bigbean/.platformio/penv/bin/python -m pip install pyyaml
      Requirement already satisfied: pyyaml in /home/bigbean/.platformio/penv/lib/python3.10/site-packages (6.0.1)
      Installing markupsafe==2.0.1 with pip at PlatformIO environment
      /home/bigbean/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
      Requirement already satisfied: markupsafe==2.0.1 in /home/bigbean/.platformio/penv/lib/python3.10/site-packages (2.0.1)
      Configuring featheresp32 with transport serial
      micro-ROS already built
      Found 33 compatible libraries
      Scanning dependencies...
      Dependency Graph
      |-- micro_ros_platformio @ 0.0.1+sha.085c5dd
      Building in release mode
      Retrieving maximum program size .pio/build/featheresp32/firmware.elf
      Checking size .pio/build/featheresp32/firmware.elf
      Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
      RAM:   [=         ]  15.0% (used 49144 bytes from 327680 bytes)
      Flash: [==        ]  22.6% (used 296213 bytes from 1310720 bytes)
      Configuring upload protocol...
      AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
      esptool.py v4.2.1
      Connecting.....
          esptool._main()
          self.sync()
        File "/home/bigbean/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 445, in sync
          val, _ = self.command()
          p = self.read()
      • 3307093903
        小豆
        好像是上一步的MicroROS的Docker镜像还在占用USB0构建镜像的原因
        小鱼小 26932262522 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @330709390
          @330709390 同一时间只能有一个程序使用串口
          3307093903 26932262522 2 条回复 最后回复 回复 引用 1
          • 3307093903
            小豆 @小鱼
            @小鱼 嗯,还有一个问题,就是docker那边已经下载好了,但启动很缓慢,几十分钟都还没好,没有达到手册里的那几个步骤,请问初次启动是这么慢吗
            一直卡在以下界面
            1692670448.813736] info     | TermiosAgentLinux.cpp | init                     | running...             | fd: 3
            [1692670448.815704] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 6
              小鱼 技术大佬 @330709390
              @330709390 这是启动成功了,在等待连接中
                小黄小黄触底反弹ت @小鱼
                @小鱼 这里一直在等待连接怎么办呢,按开发板的rst也没用
                • 26932262522
                  命里有我 @330709390
                  @330709390 这个怎么结束对串口的占用啊
                  • 26932262522
                    命里有我 @小鱼
                    @小鱼 这个怎么知道是不是只有一个串口在用啊
                      小鱼 技术大佬 @2693226252
                      @2693226252 比如串口调试助手,查看器,凡是用到串口的地方都关掉
                      26932262522 1 条回复 最后回复 回复 引用 0
                      • 26932262522
                        命里有我 @小鱼
                        @小鱼 好的,我试试,谢谢鱼哥
