    Nav2源码安装colcon build出现很多问题
    Nav2
    nav2源码安装有错误提示 ros2-humble
    • 10191161081
      歪比巴卜
      至于问题有点多,我放图可能不太好。我是在我自己conda的 ros2环境下操作的。就一直出现问题,一会是缺numpy,一会是缺empy 然后cmake的又缺了。然后现在又有这些问题,编译不成功。。。,以下是一段输出。我想问一下这难道跟我的conda环境有关吗?计算机小白,只知道pip对于不同环境会有自己的包
      CMake Warning at src/CMakeLists.txt:1 (add_library):
        Cannot generate a safe runtime search path for target nav2_util_core
        because files in some directories may conflict with libraries in implicit
        directories:
          runtime library [libpython3.10.so.1.0] in /usr/lib/x86_64-linux-gnu may be hidden by files in:
            /home/ros2/miniconda3/envs/ros2/lib
        Some of these libraries may not be found correctly.
      CMake Warning at src/CMakeLists.txt:26 (add_executable):
        Cannot generate a safe runtime search path for target lifecycle_bringup
        directories:
      CMake Warning at /opt/ros/humble/share/ament_cmake_gtest/cmake/ament_add_gtest_executable.cmake:50 (add_executable):
        Cannot generate a safe runtime search path for target test_node_utils
        directories:
        /opt/ros/humble/share/ament_cmake_gtest/cmake/ament_add_gtest_executable.cmake:37 (_ament_add_gtest_executable)
        /opt/ros/humble/share/ament_cmake_gtest/cmake/ament_add_gtest.cmake:68 (ament_add_gtest_executable)
        test/CMakeLists.txt:3 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_service_client
        directories:
        test/CMakeLists.txt:9 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_string_utils
        directories:
        test/CMakeLists.txt:13 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_lifecycle_utils
        directories:
        test/CMakeLists.txt:17 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_actions because
        directories:
        test/CMakeLists.txt:21 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_lifecycle_node
        directories:
        test/CMakeLists.txt:25 (ament_add_gtest)
        test_lifecycle_cli_node because files in some directories may conflict with
        libraries in implicit directories:
        test/CMakeLists.txt:29 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_geometry_utils
        directories:
        test/CMakeLists.txt:33 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_odometry_utils
        directories:
        test/CMakeLists.txt:37 (ament_add_gtest)
        Cannot generate a safe runtime search path for target test_robot_utils
        directories:
        test/CMakeLists.txt:41 (ament_add_gtest)
      Finished <<< nav2_util [50.4s]
      Starting >>> nav_2d_utils
      Starting >>> nav2_behavior_tree
      Starting >>> nav2_lifecycle_manager
      Starting >>> nav2_map_server
      --- stderr: nav2_map_server
      CMake Error at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
        GRAPHICSMAGICKCPP_LIBRARIES (missing: GRAPHICSMAGICKCPP_INCLUDE_DIRS)
        /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
        cmake_modules/FindGRAPHICSMAGICKCPP.cmake:31 (find_package_handle_standard_args)
        CMakeLists.txt:17 (find_package)
      • 10191161081
        歪比巴卜
        --- stderr: nav2_amcl
        /usr/bin/ld: 找不到 /lib64/libc.so.6: 没有那个文件或目录
        /usr/bin/ld: 找不到 /usr/lib64/libc_nonshared.a: 没有那个文件或目录
        /usr/bin/ld: 找不到 /lib64/librt.so.1: 没有那个文件或目录
        gmake[2]: *** [src/map/CMakeFiles/map_lib.dir/build.make:145:src/map/libmap_lib.so] 错误 1
        gmake[1]: *** [CMakeFiles/Makefile2:293:src/map/CMakeFiles/map_lib.dir/all] 错误 2
        Failed   <<< nav2_amcl [0.40s, exited with code 2]
        现在是报这个问题了,鱼哥哥,帮我看看
          小鱼 技术大佬 @1019116108
          @1019116108 https://fishros.org.cn/forum/topic/554/jupyter新建python3文件终端报错-导入rclpy报错/20
