    根据nav2中文文档中建立urdf文件,编译的时候报错,求救
    nav2源码安装有错误提示 nav2教程中遇到的问题
    • 13454440611
      太阳当空照
      RuntimeError: Signal event received before subprocess transport available.
      [INFO] [joint_state_publisher-1]: process started with pid [9550]
      [joint_state_publisher-1] [INFO] [1697455391.387972882] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
      [ERROR] [joint_state_publisher-1]: process[joint_state_publisher-1] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
      [INFO] [joint_state_publisher-1]: sending signal 'SIGTERM' to process[joint_state_publisher-1]
      [ERROR] [joint_state_publisher-1]: process has died [pid 9550, exit code -15, cmd '/opt/ros/foxy/lib/joint_state_publisher/joint_state_publisher --ros-args -r __node:=joint_state_publisher'].
