    ROS2 在自己的工作空间下载turtlesim功能包编译后报错
    ros2 cmake报错
    • 13983639341
      CMake Error at CMakeLists.txt:4 (find_package):
      By not providing "Findcatkin.cmake" in CMAKE_MODULE_PATH this project has
      asked CMake to find a package configuration file provided by "catkin", but
      CMake did not find one.
      Could not find a package configuration file provided by "catkin" with any
      of the following names:
      catkinConfig.cmake
      catkin-config.cmake
      Add the installation prefix of "catkin" to CMAKE_PREFIX_PATH or set
      "catkin_DIR" to a directory containing one of the above files. If "catkin"
      installed.
      请问有没有大佬知道怎么解决
        小鱼 技术大佬 @1398363934
        @1398363934 一个好的提问不仅能够帮助自己理清楚问题,还有助于别人快速帮助到你。——提问的智慧
