    启动rviz显示This application failed to start because it could not find or load the Qt platform plugin "xcb"
    rviz qt 求助 求助贴
    1.5k
    • S
      sundingsheng1130
      (base) nvidia@nvidia-desktop:~$ rviz
      QFactoryLoader::QFactoryLoader() checking directory path "/opt/ros/melodic/bin/platforms" ...
      in "".
      Reinstalling the application may fix this problem.
      Aborted (core dumped)
      同时启动rqt也存在报错
      (base) nvidia@nvidia-desktop:~$ rqt_graph
        File "/opt/ros/melodic/bin/rqt_graph", line 8, in <module>
          sys.exit(main.main(sys.argv, standalone='rqt_graph.ros_graph.RosGraph'))
        File "/opt/ros/melodic/lib/python2.7/dist-packages/rqt_gui/main.py", line 65, in main
          hash(os.environ['ROS_PACKAGE_PATH'])))
        File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_gui/main.py", line 407, in main
          from python_qt_binding import QT_BINDING
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/__init__.py", line 55, in <module>
          from .binding_helper import loadUi, QT_BINDING, QT_BINDING_MODULES, QT_BINDING_VERSION  # @UnusedImport
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 276, in <module>
          getattr(sys, 'SELECT_QT_BINDING_ORDER', None),
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 120, in _select_qt_binding
          (', '.join(["'%s'" % b for b in binding_order]), '\n'.join(error_msgs)))
      ImportError: Could not find Qt binding (looked for: 'pyqt', 'pyside'):
        ImportError for 'pyqt': /usr/lib/python2.7/dist-packages/PyQt5/QtCore.aarch64-linux-gnu.so: symbol _ZN23QOperatingSystemVersion11AndroidOreoE version Qt_5 not defined in file libQt5Core.so.5 with link time reference
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 108, in _select_qt_binding
          QT_BINDING_VERSION = binding_loader(required_modules, optional_modules)
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 153, in _load_pyqt
          _named_import('PyQt5.%s' % module_name)
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 133, in _named_import
          module = builtins.__import__(name)
      ImportError: /usr/lib/python2.7/dist-packages/PyQt5/QtCore.aarch64-linux-gnu.so: symbol _ZN23QOperatingSystemVersion11AndroidOreoE version Qt_5 not defined in file libQt5Core.so.5 with link time reference
        ImportError for 'pyside': No module named PySide2.QtCore
        File "/opt/ros/melodic/lib/python2.7/dist-packages/python_qt_binding/binding_helper.py", line 185, in _load_pyside
          _named_import('PySide2.%s' % module_name)
      ImportError: No module named PySide2.QtCore
      系统是unbuntu18.04 Jetson Xaiver NX开发板 在此之前只安装过miniforge和安装搜狗输入法,装完ros后没有办法启动rviz和rqt,通过 locate libqxcb 发现
      /media/nvidia/21936f55-9c2d-4d1a-9b0a-c27dcd577a97/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqxcb.so
      /opt/MVS/bin/platforms/libqxcb.so
      直接在 ~/.bashrc中添加
      export QT_PLUGIN_PATH=/usr/lib/aarch64-linux-gnu/qt5/plugins/:$QT_PLUGIN_PATH
      再运行rviz会报错
      QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms" ...
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqeglfs.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqeglfs.so, metadata=
          "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
          "MetaData": {
              "Keys": [
                  "eglfs"
          "className": "QEglFSIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqeglfs.so:
        Plugin uses incompatible Qt library (5.9.5) [release]
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqeglfs.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so, metadata=
          "MetaData": {
              "Keys": [
                  "linuxfb"
          "className": "QLinuxFbIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimal.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimal.so, metadata=
          "MetaData": {
              "Keys": [
                  "minimal"
          "className": "QMinimalIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimal.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimal.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so, metadata=
          "MetaData": {
              "Keys": [
                  "minimalegl"
          "className": "QMinimalEglIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so, metadata=
          "MetaData": {
              "Keys": [
                  "offscreen"
          "className": "QOffscreenIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqvnc.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqvnc.so, metadata=
          "MetaData": {
              "Keys": [
                  "vnc"
          "className": "QVncIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqvnc.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqvnc.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      QFactoryLoader::QFactoryLoader() looking at "/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
      Found metadata in lib /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqxcb.so, metadata=
          "MetaData": {
              "Keys": [
                  "xcb"
          "className": "QXcbIntegrationPlugin",
          "debug": false,
          "version": 329989
      In /usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqxcb.so:
      "The plugin '/usr/lib/aarch64-linux-gnu/qt5/plugins/platforms/libqxcb.so' uses incompatible Qt library. (5.9.5) [release]"
               not a plugin
      in "".
      但是另外的板子也是5.9.5的版本,真的不知道咋子搞了,求助!
        小鱼 技术大佬 @sundingsheng1130
        @sundingsheng1130 以下来自GPT
        这个问题看起来与Qt库版本不匹配有关。你的Jetson Xavier NX上的Qt版本为5.9.5,而ROS Melodic可能需要一个不同版本的Qt。以下是一些可能的解决方法:
        1. 更新ROS依赖的Qt版本:ROS Melodic使用的Qt版本可能不与Jetson Xavier NX上的Qt版本匹配。你可以尝试更新ROS依赖的Qt版本以匹配你的系统上的Qt版本。这可能需要一些手动编译和安装。
        2. 使用docker容器:ROS官方维护了Docker容器,这些容器可以在不同的系统上运行,而不会受到主机系统的Qt版本的影响。你可以尝试在Jetson Xavier NX上运行ROS容器,这将隔离ROS环境,避免与系统Qt版本的冲突。
        3. 查看ROS Melodic的系统要求:确保你的Jetson Xavier NX系统符合ROS Melodic的系统要求。有时,特定版本的ROS可能需要特定版本的操作系统或软件库,确保你的系统满足这些要求。
        4. 升级ROS版本:如果可能的话,考虑升级到ROS Noetic或其他更高版本,看看是否有更好的兼容性。
        5. 查找并删除不兼容的Qt库:查找并删除Jetson Xavier NX上的Qt库,确保不会与ROS Melodic的Qt库发生冲突。但请谨慎操作,以免影响其他应用程序。
        6. 查看其他用户的解决方案:在ROS社区或Jetson Xavier NX的用户社区中,可能有其他用户遇到了类似的问题并提供了解决方案。查看相关讨论论坛或社交媒体组可能会有所帮助。
        请记住在尝试上述解决方案之前备份重要数据,并小心操作,以避免对系统造成不可逆的损害。根据你的需求和系统设置,选择最适合你的解决方案。
