    第十章配置fishbot建图时Rviz2 fixed frame报错,无法显示地图
    Nav2
    ros2 动手学ros,rviz
    1.5k
    • tf_wangT
      tf_wang
      跟着教程先启动gazebo后启动Rviz2,随后Rviz2的Fixed Frame报错
      这是我用rqt_graph查看的node和topic,看起来好像也没什么问题
      这是gazebo.launch.py的内容:
      import os
          robot_name_in_model = ''
          urdf_name = "fishbot_base.urdf"
          ld = LaunchDescription()
          gazebo_world_path = os.path.join(pkg_share, 'world/fishbot.world')
          # Start Gazebo server
              cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so',gazebo_world_path],
              output='screen')
          # Launch the robot
          spawn_entity_cmd = Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-entity', robot_name_in_model,  '-file', urdf_model_path ], output='screen')
          return ld
      这是cartographer.launch.py的内容:
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='fishbot_cartographer').find('fishbot_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间,我们用gazebo,这里设置成true
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          # 地图的分辨率
          resolution = LaunchConfiguration('resolution', default='0.05')
          # 地图的发布周期
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='fishbot_2d.lua')
          rviz_config_dir = os.path.join(pkg_share, 'config')+"/cartographer.rviz"
          print(f"rviz config in {rviz_config_dir}")
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename])
          cartographer_occupancy_grid_node = Node(
              executable='cartographer_occupancy_grid_node',
              name='cartographer_occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
          #===============================================定义启动文件========================================================
          ld.add_action(cartographer_node)
          ld.add_action(cartographer_occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
      gazebo和Rviz2都启动正常,网上搜索尝试了一些办法也没解决,请各位帮我看看问题出哪了
      10330329341 1 条回复 最后回复 回复 引用 0
      • 10330329341
        一万二的笑 @tf_wang
        @tf_wang cmake里添加代码
        • install(
        • DIRECTORY config launch rviz
        • DESTINATION share/${PROJECT_NAME}
