    自定义接口编译报错
    编译出错 ros2 添加接口
    1.4k
    • 32797253273
      printf("⁧⁧ ;("⁧‭
      CMake Error at CMakeLists.txt:11 (find_package):
      By not providing "Findexample_ros2_interfaces.cmake" in CMAKE_MODULE_PATH
      this project has asked CMake to find a package configuration file provided
      by "example_ros2_interfaces", but CMake did not find one.
      "example_ros2_interfaces" with any of the following names:
      example_ros2_interfacesConfig.cmake
      example_ros2_interfaces-config.cmake
      Add the installation prefix of "example_ros2_interfaces" to
      CMAKE_PREFIX_PATH or set "example_ros2_interfaces_DIR" to a directory
      containing one of the above files. If "example_ros2_interfaces" provides a
      separate development package or SDK, be sure it has been installed.
      Failed <<< example_interfaces_rclcpp [0.98s, exited with code 1]
      Aborted <<< example_topic_rclpy [0.97s]
      Summary: 2 packages finished [1.22s]
      1 package failed: example_interfaces_rclcpp
      1 package aborted: example_topic_rclpy
      1 package had stderr output: example_interfaces_rclcpp
      yangruilin@yangruilin-virtual-machine:~/d21ros2/chapt3/chapt3_ws$ ^C
      yangruilin@yangruilin-virtual-machine:~/d21ros2/chapt3/chapt3_ws$ colcon build
      Starting >>> example_interfaces_rclcpp
      Starting >>> example_service_rclcpp
      Starting >>> example_topic_rclcpp
      Starting >>> example_topic_rclpy
      Finished <<< example_topic_rclcpp [0.80s]
      Finished <<< example_service_rclcpp [0.83s]
      --- stderr: example_interfaces_rclcpp
        小鱼 技术大佬 @3279725327
        @3279725327 在 自定义接口编译报错 中说:
        检查代码中是否有 find_package(example_ros2_interfaces)
        32797253273 1 条回复 最后回复 回复 引用 0
        • 32797253273
          printf("⁧⁧ ;("⁧‭ @小鱼
          @小鱼 好的谢谢
          再 1 条回复 最后回复 回复 引用 0
          • 再
            再道 @3279725327
            @3279725327 想问你你解决这个问题了吗,我检查过后依然无法编译
