    colcon build 编译出现错误
    colcon build colcon
    1.1k
    • 13480828091
      主要出现错误:WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces,不太理解为什么
      [8.207s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'examples_rclpy_executors' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_publisher' is in: /opt/ros/foxy
      'examples_rclpy_minimal_subscriber' is in: /opt/ros/foxy
      'examples_rclpy_minimal_action_server' is in: /opt/ros/foxy
      'examples_rclcpp_multithreaded_executor' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_composition' is in: /opt/ros/foxy
      'examples_rclpy_minimal_publisher' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_service' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_action_client' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_subscriber' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_timer' is in: /opt/ros/foxy
      'examples_rclpy_minimal_service' is in: /opt/ros/foxy
      'examples_rclpy_minimal_action_client' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_client' is in: /opt/ros/foxy
      'examples_rclpy_minimal_client' is in: /opt/ros/foxy
      'examples_rclcpp_minimal_action_server' is in: /opt/ros/foxy
      If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      --allow-overriding examples_rclcpp_minimal_action_client examples_rclcpp_minimal_action_server examples_rclcpp_minimal_client examples_rclcpp_minimal_composition examples_rclcpp_minimal_publisher examples_rclcpp_minimal_service examples_rclcpp_minimal_subscriber examples_rclcpp_minimal_timer examples_rclcpp_multithreaded_executor examples_rclpy_executors examples_rclpy_minimal_action_client examples_rclpy_minimal_action_server examples_rclpy_minimal_client examples_rclpy_minimal_publisher examples_rclpy_minimal_service examples_rclpy_minimal_subscriber
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> examples_rclcpp_async_client
      Starting >>> examples_rclcpp_cbg_executor
      Starting >>> examples_rclcpp_minimal_action_client
      Starting >>> examples_rclcpp_minimal_action_server
      [Processing: examples_rclcpp_async_client, examples_rclcpp_cbg_executor, examples_rclcpp_minimal_action_client, examples_rclcpp_minimal_action_server]
      --- stderr: examples_rclcpp_async_client
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp: In lambda function:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:46:42: error: ‘using element_type = class rclcpp::Client<example_interfaces::srv::AddTwoInts>’ {aka ‘class rclcpp::Client<example_interfaces::srv::AddTwoInts>’} has no member named ‘prune_requests_older_than’
      46 | size_t n_pruned = this->client_->prune_requests_older_than(
      In file included from /opt/ros/foxy/include/rclcpp/client.hpp:40,
      from /opt/ros/foxy/include/rclcpp/callback_group.hpp:23,
      from /opt/ros/foxy/include/rclcpp/any_executable.hpp:20,
      from /opt/ros/foxy/include/rclcpp/memory_strategy.hpp:24,
      from /opt/ros/foxy/include/rclcpp/memory_strategies.hpp:18,
      from /opt/ros/foxy/include/rclcpp/executor_options.hpp:20,
      from /opt/ros/foxy/include/rclcpp/executor.hpp:33,
      from /opt/ros/foxy/include/rclcpp/executors/multi_threaded_executor.hpp:26,
      from /opt/ros/foxy/include/rclcpp/executors.hpp:21,
      from /opt/ros/foxy/include/rclcpp/rclcpp.hpp:146,
      from /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:24:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp: In member function ‘void ClientNode::queue_async_request(int64_t, int64_t)’:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:103:14: error: ‘class std::shared_future<std::pair<std::shared_ptr<example_interfaces::srv::AddTwoInts_Request_<std::allocator<void> > >, std::shared_ptr<example_interfaces::srv::AddTwoInts_Response_<std::allocator<void> > > > >’ has no member named ‘request_id’
      103 | result.request_id);
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp: At global scope:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:123:6: error: ‘optional’ in namespace ‘std’ does not name a template type
      123 | std::optional<int64_t>
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:123:1: note: ‘std::optional’ is only available from C++17 onwards
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:171:53: error: no matching function for call to ‘rclcpp::executors::SingleThreadedExecutor::spin_until_future_complete(const std::future<void>&)’
      171 | executor.spin_until_future_complete(stop_token);
      In file included from /opt/ros/foxy/include/rclcpp/executors/multi_threaded_executor.hpp:26,
      /opt/ros/foxy/include/rclcpp/executor.hpp:194:3: note: candidate: ‘template<class ResponseT, class TimeRepT, class TimeT> rclcpp::FutureReturnCode rclcpp::Executor::spin_until_future_complete(const std::shared_future<_Res>&, std::chrono::duration<_Rep, _Period>)’
      194 | spin_until_future_complete(
      /opt/ros/foxy/include/rclcpp/executor.hpp:194:3: note: template argument deduction/substitution failed:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:171:53: note: ‘const std::future<void>’ is not derived from ‘const std::shared_future<_Res>’
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp: In function ‘int main(int, char**)’:
      /home/ggl/colcon_test_ws/src/examples/rclcpp/services/async_client/main.cpp:175:28: error: ‘read_number’ was not declared in this scope; did you mean ‘read_more’?
      175 | auto optional_number = read_number(buffer, logger);
      | read_more
      make[2]: *** [CMakeFiles/client_main.dir/build.make:63:CMakeFiles/client_main.dir/main.cpp.o] 错误 1
      make[1]: *** [CMakeFiles/Makefile2:78:CMakeFiles/client_main.dir/all] 错误 2
      make: *** [Makefile:141:all] 错误 2
      Failed <<< examples_rclcpp_async_client [34.5s, exited with code 2]
      Aborted <<< examples_rclcpp_minimal_action_server [41.7s]
      Aborted <<< examples_rclcpp_minimal_action_client [42.7s]
      Aborted <<< examples_rclcpp_cbg_executor [56.1s]
      Summary: 0 packages finished [1min 5s]
      1 package failed: examples_rclcpp_async_client
      3 packages aborted: examples_rclcpp_cbg_executor examples_rclcpp_minimal_action_client examples_rclcpp_minimal_action_server
      3 packages had stderr output: examples_rclcpp_async_client examples_rclcpp_cbg_executor examples_rclcpp_minimal_action_client
      18 packages not processed
