    安装失败 报错:AttributeError: module 'tools.tool_install_ros' has no attribute 'Tool'
    ros一键安装 一键安装ros
    7
    8
    960
    • Z
      zyn0216
      c2c7a0af-8e86-4a72-8073-c65831565244-图片.png 大佬看看怎么回事
      • 14845479351
        我也出现了一样的问题 等大佬解决 明明之前还不会的
        • 1255355001
          125535500
          我也是这个问题。
            一样的问题,求解决!!!
              小鱼 技术大佬 @1412644878
              @1412644878 还有吗,最近准备升级一波了
              J 1 条回复 最后回复 回复 引用 0
              • J
                JayJoker @小鱼
                @小鱼 有的 我现在还出现这个情况
                Type the number in [] to choose a function:1
                Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_install_ros.py -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate]
                [|][0.01s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.01s] CMD Result:code:4        .
                Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_rosenv.py -O /tmp/fishinstall/tools/tool_config_rosenv.py --no-check-certificate]
                [|][0.00s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.00s] CMD Result:code:4        .
                Run CMD Task:[wget https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_system_source.py -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate]
                [/][0.00s] --2024-09-08 18:24:40--  https://raw.githubusercontent.com/fishros/install/master/tools/tool_config_system_so[|][0.01s] Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443... failed: Connection refuse[-][0.01s] CMD Result:code:4        .
                标题:使用一键安装过程中遇到程序崩溃
                File "/tmp/fishinstall/install.py", line 133, in <module>
                File "/tmp/fishinstall/install.py", line 122, in main
                File "/tmp/fishinstall/tools/base.py", line 1473, in run_tool_file
                tool = importlib.import_module(file.replace(".py","")).Tool()
                ^Croot@a0788b5e3633:/# ^C
                root@a0788b5e3633:/# pip3 install run_tool_file
                ERROR: Could not find a version that satisfies the requirement run_tool_file (from versions: none)
                ERROR: No matching distribution found for run_tool_file
                  小鱼 技术大佬 @JayJoker
                  @JayJoker 有代理吗,咋给你整到国外去了
                    开了代理的原因吧
