    ROS仿真一个可动小车时,单独在RVIZ里查看小车模型参数没有问题,但是在gazebo中驱动小车时,终端报错且RVIZ中小车模型出现错误
    仿真
    gazebo ros rviz
    • 380880073
      38088007
      • 操作系统:ubantu18.04
      • ROS版本:melodic
      • gazebo9
      新手小白在做一个可动小车的仿真时,遇到了如下问题,恳请各位相助!
      我在RVIZ里查看小车模型时可以得到下图所示的模型图
      但是当我输入命令
      roslaunch steer_mini_gazebo steer_mini_sim.launch
      在gazebo中驱动小车时,却出现了如下报错
      [ INFO] [1701960022.508446103, 61.242000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
      [FATAL] [1701960022.609885892, 61.242000000]: Failed to create robot simulation interface loader: Could not find library corresponding to plugin steer_bot_hardware_gazebo/SteerBotHardwareGazebo. Make sure the plugin description XML file has the correct name of the library and that the library actually exists.
      [ INFO] [1701960022.610109458, 61.242000000]: Loaded gazebo_ros_control.
      且在RIVIZ中车轮的link也无法识别,如下图所示
      在网上找了很久都没找到解决方案,恳请各位大佬帮忙!万分感谢!
      相关代码附在下面:
      • 小车的urdf文件
      <?xml version="1.0" encoding="utf-8"?>
      <!-- This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner (brawner@gmail.com)
           Commit Version: 1.5.1-0-g916b5db  Build Version: 1.5.7152.31018
           For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
      <robot
        name="neor_mini">
            <link name="base_link">
          <!-- avoid root link inertia warnings, annotation -->
          <inertial>
            <origin
              xyz="0.030649671440691 -1.79069899872708E-05 0.0558717976709459"
              rpy="0 0 0" />
            <mass
              value="1.72617713171385" />
            <inertia
              ixx="0.0107311274569357"
              ixy="-3.24164649120244E-08"
              ixz="0.00169188715816868"
              iyy="0.0198871551919603"
              iyz="2.40252669081509E-07"
              izz="0.0269841937242323" />
          </inertial>
          <visual>
            <origin xyz="0 0 0" rpy="0 0 0" />
            <geometry>
              <mesh filename="package://neor_mini/meshes/base_link.dae" />
            </geometry>
            <material name="">
            <color rgba="0.250980392156863 0.250980392156863 0.250980392156863 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/base_link.STL" />
            </geometry>
          </collision>
        </link>
        <link
          name="rear_wheel_link">
          <inertial>
            <origin
              xyz="-8.88178419700125E-16 -2.05391259555654E-14 -0.00112500000001892"
              rpy="0 0 0" />
            <mass
              value="5.65486677646169E-05" />
            <inertia
              ixx="1.32005796313028E-10"
              ixy="-1.938704560671E-27"
              ixz="2.13770572261755E-26"
              iyy="1.32005796313028E-10"
              iyz="-7.60216295195271E-25"
              izz="2.03575203952622E-10" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/rear_wheel_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="0.274509803921569 1 0.247058823529412 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="rear_wheel_joint"
          type="continuous">
          <origin
            xyz="-0.181499999999597 0 0.0399999999987674"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="rear_wheel_link" />
          <axis
            xyz="0 1 0" />
        </joint>
        <link
          name="left_rear_link">
          <inertial>
            <origin
              xyz="7.85229659072684E-11 -0.0196762547002777 4.85059770127805E-11"
              rpy="0 0 0" />
            <mass
              value="0.29556182905038" />
            <inertia
              ixx="0.000374087423652291"
              ixy="2.19336154342606E-13"
              ixz="-5.50404301757561E-12"
              iyy="0.000661017199375587"
              iyz="-5.10049385981967E-14"
              izz="0.000374087441459994" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/left_rear_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="0.792156862745098 0.819607843137255 0.933333333333333 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="left_rear_joint"
          type="continuous">
          <origin
            xyz="-0.181499999999595 0.228542434993694 0.0399999999991634"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="left_rear_link" />
          <axis
            xyz="0 1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="right_rear_link">
          <inertial>
            <origin
              xyz="7.8521189550429E-11 0.0196762545376323 3.35983463273237E-11"
              rpy="0 0 0" />
            <mass
              value="0.295561829050389" />
            <inertia
              ixx="0.000374087423652306"
              ixy="-2.1933774523493E-13"
              ixz="5.50404145624456E-12"
              iyy="0.000661017199375601"
              iyz="-5.10073974604221E-14"
              izz="0.000374087441459995" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/right_rear_link.STL" />
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="right_rear_joint"
          type="continuous">
          <origin
            xyz="-0.181499999999595 -0.228542434994426 0.0399999999991584"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="right_rear_link" />
          <axis
            xyz="0 1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="front_steer_link">
          <inertial>
            <origin
              xyz="-2.1316282072803E-14 3.67778030252452E-11 -0.00112486602459905"
              rpy="0 0 0" />
            <mass
              value="5.65486677646163E-05" />
            <inertia
              ixx="1.32005796313026E-10"
              ixy="1.16322273640277E-26"
              ixz="1.20446157864484E-28"
              iyy="1.32005796313026E-10"
              iyz="-8.66481261175625E-27"
              izz="2.03575203952619E-10" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/front_steer_link.STL" />
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="front_steer_joint"
          type="revolute">
          <origin
            xyz="0.172883370897628 0 -0.00376561854722868"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="front_steer_link" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.72"
            upper="0.72"
            effort="0"
            velocity="0" />
        </joint>
      <!-- In order to fit ackermann simulation plugins's request,amend the front steer link and it's joint -->
       <link name="front_steer_right_link">
       <!--  remember add inertial  label,if not,and it can't visual on gazebo-->
       <inertial>
            <origin xyz="9.44636555644252E-08 -0.000295273745285485 -8.13046296954667E-11" rpy="0 0 0" />
            <mass value="0.296315811300368" />
            <inertia
              ixx="0.000374692013709393"
              ixy="-9.17172260383823E-08"
              ixz="-2.43187512356516E-12"
              iyy="0.000661029987747155"
              iyz="1.9736939507106E-13"
              izz="0.000374691963930348" />
          </inertial>
         <visual>
           <geometry>
             <cylinder length="0.001" radius="0.005"/>
           </geometry>
           <origin rpy="0 0 0"  xyz="0 0 0" />
           <material name="">
                <color rgba="0.792156862745098 0.819607843137255 0.933333333333333 1" />
           </material>
         </visual>
         <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
       </link>
       <joint name="front_steer_right_joint" type="revolute">
          <origin rpy="0 0 0"  xyz="0.17 -0.21 0.102" />
          <parent link="base_link" />
          <child link="front_steer_right_link" />
          <axis xyz="0 0 1" />     <!-- charge steer direction default is 0 0 1-->
          <limit lower="-0.69" upper="0.69" effort="0" velocity="0" />
       </joint>
        <link
          name="front_right_wheel_link">
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/front_right_wheel_link.STL" />
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint name="front_right_wheel_joint" type="continuous">
          <origin xyz="0 0 -0.06" rpy="0 0 0" />   <!-- amend the position between steer_right_link and front right wheel-->
          <parent link="front_steer_right_link" />
          <child  link="front_right_wheel_link" />
          <axis xyz="0 1 0" />
        </joint>
       <link name="front_steer_left_link">
          <inertial>
            <inertia
          </inertial>
         <visual>
           <geometry>
           </geometry>
         </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
       </link>
       <joint name="front_steer_left_joint" type="revolute">
          <origin rpy="0 0 0"  xyz="0.17 0.21 0.102" />
          <child link="front_steer_left_link" />
       </joint>
        <link
          name="front_left_wheel_link">
          <inertial>
            <origin
              xyz="-3.99413835339146E-11 0.000295273997845347 1.08602016268833E-10"
              rpy="0 0 0" />
            <mass
              value="0.296315811293944" />
            <inertia
              ixx="0.00037469197851121"
              ixy="-1.84493877596723E-13"
              ixz="-9.50756757097929E-12"
              iyy="0.00066103001709398"
              iyz="-1.17866882205563E-13"
              izz="0.000374691969713977" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://neor_mini/meshes/front_left_wheel_link.STL" />
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint name="front_left_wheel_joint" type="continuous">
          <origin xyz="0 0 -0.06" rpy="0 0 0" />      <!-- amend the position between steer_left_link and front left wheel-->
          <parent link="front_steer_left_link" />
          <child link="front_left_wheel_link" />
        </joint>
      </robot>
      • 在gazebo中驱动小车的urdf文件
      <robot name="neor_mini">
        <!-- Add Gazebo plugins -->
          <!-- Load ros_control plugin using the steer_bot_hardware_gazebo
          implementation of the hardware_interface::RobotHW -->
        <gazebo>
          <plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
            <robotSimType>steer_bot_hardware_gazebo/SteerBotHardwareGazebo</robotSimType>
            <legacyModeNS>false</legacyModeNS>
          </plugin>
        </gazebo>
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <geometry>
            </geometry>
            <material name="">
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          type="continuous">
          <origin
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
          <axis
            xyz="0 1 0" />
        </joint>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          type="continuous">
          <origin
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
          <axis
            xyz="0 1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          type="continuous">
          <origin
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
          <axis
            xyz="0 1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          type="revolute">
          <origin
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
          <axis
            xyz="0 0 1" />
          <limit
            lower="-0.72"
            upper="0.72"
            effort="0"
            velocity="0" />
        </joint>
       <inertial>
            <inertia
          </inertial>
         <visual>
           <geometry>
           </geometry>
           <material name="">
           </material>
         </visual>
         <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
       </link>
       </joint>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        </joint>
          <inertial>
            <inertia
          </inertial>
         <visual>
           <geometry>
           </geometry>
         </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
       </link>
       </joint>
        <link
          <inertial>
            <origin
              rpy="0 0 0" />
            <mass
            <inertia
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
            <material
              name="">
              <color
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        </joint>
      </robot>
      • launch文件
      <launch>
        <param name="robot_description" textfile="$(find neor_mini)/urdf/neor_mini.urdf" />
        <node name="joint_state_publisher_gui" pkg="joint_state_publisher_gui" type="joint_state_publisher_gui" />
        <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" />
        <node name="rviz" pkg="rviz" type="rviz" args="-d $(find neor_mini)/rviz/neor_mini_rviz.rviz" />
      </launch>
