    10.5Cartographer进行建图时出错
    cartographer ros2-foxy cartographer建图
    • 8648495838
      阿坤
      最后由 864849583 编辑
      ubuntu20.04 安装的ros版本为foxy cartographer使用的是一键安装 gazebo仿真环境已启动 执行ros2 launch fishbot_cartographer cartographer.launch.py 时出错 ```
      下面为执行结果:
      hk@hk:~/src/fishbot_cartographer$ ros2 launch fishbot_cartographer cartographer.launch.py
      [INFO] [launch]: All log files can be found below /home/hk/.ros/log/2023-12-20-15-25-52-773319-hk-3876
      Task exception was never retrieved
      future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=PackageNotFoundError("package 'cartographer_ros' not found, searching: ['/home/hk/src/fishbot_cartographer/install/fishbot_cartographer', '/opt/ros/foxy']")>
      File "/opt/ros/foxy/lib/python3.8/site-packages/ament_index_python/packages.py", line 50, in get_package_prefix
      content, package_prefix = get_resource('packages', package_name)
      File "/opt/ros/foxy/lib/python3.8/site-packages/ament_index_python/resources.py", line 48, in get_resource
      raise LookupError(
      LookupError: Could not find the resource 'cartographer_ros' of type 'packages'
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 228, in _process_one_event
      await self.__process_event(next_event)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py", line 248, in __process_event
      visit_all_entities_and_collect_futures(entity, self.__context))
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 45, in visit_all_entities_and_collect_futures
      futures_to_return += visit_all_entities_and_collect_futures(sub_entity, context)
      [Previous line repeated 1 more time]
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 38, in visit_all_entities_and_collect_futures
      sub_entities = entity.visit(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/action.py", line 108, in visit
      return self.execute(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/actions/node.py", line 453, in execute
      ret = super().execute(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 823, in execute
      self.__expand_substitutions(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 668, in __expand_substitutions
      cmd = [perform_substitutions(context, x) for x in self.__cmd]
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/execute_process.py", line 668, in <listcomp>
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in perform_substitutions
      return ''.join([context.perform_substitution(sub) for sub in subs])
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/utilities/perform_substitutions_impl.py", line 26, in <listcomp>
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_context.py", line 232, in perform_substitution
      return substitution.perform(self)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/substitutions/executable_in_package.py", line 76, in perform
      package_prefix = super().perform(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/substitutions/find_package.py", line 79, in perform
      result = self.find(package)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch_ros/substitutions/find_package.py", line 96, in find
      return get_package_prefix(package_name)
      File "/opt/ros/foxy/lib/python3.8/site-packages/ament_index_python/packages.py", line 52, in get_package_prefix
      raise PackageNotFoundError(
      ament_index_python.packages.PackageNotFoundError: "package 'cartographer_ros' not found, searching: ['/home/hk/src/fishbot_cartographer/install/fishbot_cartographer', '/opt/ros/foxy']"
      • 8648495838 864849583 删除了该主题于
      • 8648495838 864849583 恢复了该主题于
        小鱼 技术大佬 @864849583
        @864849583 在 10.5Cartographer进行建图时出错 中说:
        确实是每安装或者构建完成导致的
        • M
          mericalandintent
          看起来没找到包,试试在工作空间执行source install/setup.bash
          8648495838 1 条回复 最后回复 回复 引用 0
          • 8648495838
            阿坤 @mericalandintent
            @mericalandintent 执行这条指令之前已经source过了
              小鱼 技术大佬 @864849583
              确实是每安装或者构建完成导致的
              • 小鱼小 小鱼 将这个主题标记为已解决,在
