    ros2使用launch打开gazebo时提示缺少rclpy._rclpy_pybind11和_rclpy_pybind11.cpython-311-x86_64-linux-gnu.so
    ros2 galactic ros2 launch rclpypybind11
    1.9k
    • 12632917721
      终陌
      [spawn_entity.py-4] ModuleNotFoundError: No module named 'rclpy._rclpy_pybind11'
      [spawn_entity.py-4] The C extension '/opt/ros/galactic/lib/python3.8/site-packages/_rclpy_pybind11.cpython-311-x86_64-linux-gnu.so' isn't present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-without-library-present-on-the-system' for possible solutions
      [ERROR] [spawn_entity.py-4]: process has died [pid 31276, exit code 1, cmd '/opt/ros/galactic/lib/gazebo_ros/spawn_entity.py -topic robot_description -entity robot_gazebo --ros-args'].
      [gzclient -2] Node::Advertise(): Error advertising topic [/ground_plane/joint_cmd]. Did you forget to start the discovery service?
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1263291772
        @1263291772 https://fishros.org.cn/forum/topic/369/用launch文件运行gazebo时报错-找不到rclpy-_rclpy_pybind11/5
          小鱼 技术大佬 @1263291772
          @1263291772
