    colcon build 使用问题
    ros2 colcon build
    • 16287993151
      早点睡晚安吧
      1. source 环境后 还是会出现 警告
      foxy@ubuntu:~/robot_ws$ colcon build
      [2.986s] WARNING:colcon.colcon_core.prefix_path.colcon:The path '/home/foxy/install' in the environment variable COLCON_PREFIX_PATH doesn't exist
      [2.987s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/foxy/install/mqtt_ros_pkg' in the environment variable AMENT_PREFIX_PATH doesn't exist
      [2.987s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/foxy/install/mqtt_ros_pkg' in the environment variable CMAKE_PREFIX_PATH doesn't exist
      1. colcon build 为什么 经常 第一次编译黄色警告编译失败,第二次 就能成功
