    激光雷达无法启动
    移动机器人制作
    激光雷达 ubuntu 22.04
    790
    • 18048496431
      han
      雷达是eai的x2,在虚拟机上驱动雷达的时候 无法启动雷达。topic list也没有/scan话题。但是串口是有数据的。截屏2024-03-05 23.19.23.png
      parallels@han:~/fishbot_ws/src/ydlidar_ros2$ ros2 launch ydlidar ydlidar_launch.py
      [INFO] [launch]: All log files can be found below /home/parallels/.ros/log/2024-03-05-23-16-28-674379-han-63566
      [INFO] [ydlidar_node-1]: process started with pid [63591]
      [INFO] [static_transform_publisher-2]: process started with pid [63594]
      [static_transform_publisher-2] [WARN] [1709651788.775672408] []: Old-style arguments are deprecated; see --help for new-style arguments
      [ydlidar_node-1] [YDLIDAR INFO] Current ROS Driver Version: 1.4.5
      [static_transform_publisher-2] [INFO] [1709651788.790112179] [static_tf_pub_laser]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.020000', '0.000000', '0.000000')
      [static_transform_publisher-2] from 'base_link' to 'laser_frame'
      [ydlidar_node-1] [YDLIDAR]:SDK Version: 1.4.5
      [ydlidar_node-1] [YDLIDAR]:Lidar running correctly ! The health status: good
      [ydlidar_node-1] 139926289409600 thread has been canceled
      [ydlidar_node-1] [CYdLidar] Failed to turn on the Lidar, because the lidar is blocked or the lidar hardware is faulty.
      [ydlidar_node-1] [YDLIDAR INFO] Now YDLIDAR is stopping .......
      [INFO] [ydlidar_node-1]: process has finished cleanly [pid 63591]
        小鱼 技术大佬 @1804849643
        @1804849643 记得修改端口号诶
        18048496431 1 条回复 最后回复 回复 引用 0
        • 18048496431
          han @小鱼
          @小鱼 如果这个雷达在windows下那个官方软件也无法正常运行,现实校验错误 是不是证明这个雷达是有问题的。
          小鱼小 M 2 条回复 最后回复 回复 引用 0
            小鱼 技术大佬 @1804849643
            @1804849643 不好说哈,找卖家确认下
            • M
              mixllred @1804849643
              @1804849643 感觉这个雷达工作不是很稳定,老是中断
                小鱼 技术大佬 @mixllred
                @mixllred 不会的,这个雷达出货量最大的就是扫地机上了,根据你的使用方法,考虑其他因素,如果使用无线模式,一定注意网络质量
