    18.04 ros2一键安装出错
    ros2一键安装 ros2安装
      狼狈相骑士
      [-]Result:code:100
      Run CMD Task:[sudo apt install ros-dashing-ros-base -y]
      E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
      E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
      [-]Result:code:100
      Run CMD Task:[ls /opt/ros/dashing/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
