    坐标转换失败
    坐标转换 tf2 ros2-humble dotransformer
    1.6k
    • C
      Chengyawen26
      我是ros2 humble系统, 我想要把相机坐标系下的物体点转换到地图坐标系下,但是一直转换失败。
      我验证了相机坐标系和map之间是能够转换的,请问该如何把相机下的点转到map下呢?
      主要就是: transformed_pose = do_transform_pose(pose_stamped, transform) 出错
      import rclpy
      from tf2_ros import Buffer, TransformListener
      from tf2_ros.buffer_interface import BufferInterface
      from tf2_geometry_msgs import do_transform_pose
      from geometry_msgs.msg import PoseStamped
      import tf_transformations
      def main():
          rclpy.init()
          node = rclpy.create_node('tf2_listener')
          tf_buffer = Buffer()
          listener = TransformListener(tf_buffer, node)
          # pose
          pose_stamped = PoseStamped()
          pose_stamped.header.frame_id = "camera"
          pose_stamped.pose.position.x = 1.0
          pose_stamped.pose.position.y = 2.0
          pose_stamped.pose.position.z = 3.0
          pose_stamped.pose.orientation.x = 0.0
          pose_stamped.pose.orientation.y = 0.0
          pose_stamped.pose.orientation.z = 0.0
          pose_stamped.pose.orientation.w = 1.0
          rclpy.spin_once(node, timeout_sec=1)
          transform = tf_buffer.lookup_transform('base_link', 'camera', rclpy.time.Time())
          print(transform)
          print(transformed_pose)
          node.destroy_node()
          rclpy.shutdown()
      if __name__ == '__main__':
      报错结果:
        File "/home/humble/fishbot_ws/install/tflola/lib/tflola/test2", line 33, in <module>
          sys.exit(load_entry_point('tflola', 'console_scripts', 'test2')())
        File "/home/humble/fishbot_ws/build/tflola/tflola/test2.py", line 79, in main
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/tf2_geometry_msgs/tf2_geometry_msgs.py", line 352, in do_transform_pose
          pose.position.x,
      AttributeError: 'PoseStamped' object has no attribute 'position'
      请大家不吝赐教
        小鱼 技术大佬 @Chengyawen26
        @Chengyawen26 chatgpt
        根据你提供的代码和错误信息,报错显示 'PoseStamped' 对象没有 'position' 属性。这表明您的 pose_stamped 对象并没有正确设置,因此无法访问其位置信息。在设置 pose_stamped 时,请确保正确设置了其位置信息。
        您可以尝试更改您的代码,如下所示:
        import rclpy
        from geometry_msgs.msg import PoseStamped, TransformStamped
        import tf2_ros
        def main():
            rclpy.init()
            # pose
            try:
            except tf2_ros.LookupException as e:
                print("Transform not available: ", e)
            except tf2_ros.ExtrapolationException as e:
                print("Extrapolation exception: ", e)
            node.destroy_node()
            rclpy.shutdown()
        在此示例中,我稍微更改了导入,添加了异常处理以捕获转换查找可能出现的异常,并在异常处理块中打印相关错误信息。请确保您的 TF2 树中确实存在 'camera' 到 'base_link' 的变换。
        • A
          aweliant
          这里应该使用do_transform_pose_stamped。在opt/ros/humble/local/lib/python3.10/dist-packages/tf2_geometry_msgs/tf2_geometry_msgs.py可以看到源代码。
