    melodic安装Cartographer时编译报错
    cartographer melodic
    • 6
      ros小菜鸡
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:289:49: error: ISO C++ forbids declaration of ‘EXCLUSIVE_LOCKS_REQUIRED’ with no type [-fpermissive]
      EXCLUSIVE_LOCKS_REQUIRED(parent_->mutex_);
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:289:9: error: ‘int cartographer::mapping::PoseGraph2D::TrimmingHandle::EXCLUSIVE_LOCKS_REQUIRED(int)’ cannot be overloaded
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:281:9: error: with ‘int cartographer::mapping::PoseGraph2D::TrimmingHandle::EXCLUSIVE_LOCKS_REQUIRED(int)’
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:290:71: error: expected ‘;’ at end of member declaration
      void SetTrajectoryState(int trajectory_id, TrajectoryState state) override
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:291:34: error: ‘parent_’ has not been declared
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:291:41: error: expected ‘,’ or ‘...’ before ‘->’ token
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:291:49: error: ISO C++ forbids declaration of ‘EXCLUSIVE_LOCKS_REQUIRED’ with no type [-fpermissive]
      /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d.h:291:9: error: ‘int cartographer::mapping::PoseGraph2D::TrimmingHandle::EXCLUSIVE_LOCKS_REQUIRED(int)’ cannot be overloaded
      In file included from /home/fu/cartographer_ws/src/cartographer/cartographer/mapping/internal/2d/pose_graph_2d_test.cc:24:0:
      /home/fu/cartographer_ws/src/cartographer/cartographer/common/internal/testing/lua_parameter_dictionary_test_helpers.h: In member function ‘virtual std::__cxx11::string cartographer::common::DummyFileResolver::GetFileContentOrDie(const string&)’:
      /home/fu/cartographer_ws/src/cartographer/cartographer/common/internal/testing/lua_parameter_dictionary_test_helpers.h:42:3: error: control reaches end of non-void function [-Werror=return-type]
      /home/fu/cartographer_ws/src/cartographer/cartographer/common/internal/testing/lua_parameter_dictionary_test_helpers.h: In member function ‘virtual std::__cxx11::string cartographer::common::DummyFileResolver::GetFullPathOrDie(const string&)’:
      /home/fu/cartographer_ws/src/cartographer/cartographer/common/internal/testing/lua_parameter_dictionary_test_helpers.h:46:3: error: control reaches end of non-void function [-Werror=return-type]
      cc1plus: some warnings being treated as errors
      ninja: build stopped: subcommand failed.
      <== Failed to process package 'cartographer':
      Command '['ninja', '-j20', '-l20']' returned non-zero exit status 1
      Reproduce this error by running:
      ==> cd /home/fu/cartographer_ws/build_isolated/cartographer && ninja -j20 -l20
      一直在报这种语法错误,上面是部分报错信息,由于都是这种语法报错所以就截取部分报错信息。求大佬答疑解惑,这到底是什么问题?困扰我好几天了。
