    4.3.3 C++ 客户端代码实现rclcpp/rclcpp.hpp: 没有那个文件或目录
    rclcpp 无头文件目录
    • 4
      开心
      patrol_client.cpp代码(无报错)
      #include <chrono>
      #include <cstdlib>
      #include <ctime>
      #include "rclcpp/rclcpp.hpp"
      #include "chapt4_interfaces/srv/patrol.hpp"
      using Patrol = chapt4_interfaces::srv::Patrol;
      class PatrolClient : public rclcpp::Node
          public:
           PatrolClient() : Node("patrol_client") {
              patrol_client_ = this->create_client<Patrol>("patrol");
              timer_ = this->create_wall_timer(10s,
              std::bind(&PatrolClient::timer_callback, this));
              srand(time(NULL));
          void timer_callback() {
              while (!patrol_client_->wait_for_service(std::chrono::seconds(1)))
                  if(!rclcpp::ok()) {
                      RCLCPP_ERROR(this->get_logger(),"等待服务端过程中被打断...");
                      return;
                  RCLCPP_INFO(this->get_logger(),"等待服务端上线中");
              auto request = std::make_shared<Patrol::Request>();
              request->target_x = rand() % 15;
              request->target_y = rand() % 15;
              RCLCPP_INFO(this->get_logger(), "请求巡逻:(%f,%f)",request->target_x,
              request->target_y);
              patrol_client_->async_send_request(
                  request,
                  [&](rclcpp::Client<Patrol>::SharedFuture result_future) -> void {
                      auto response = result_future.get();
                      if (response->result == Patrol::Response::SUCCESS) {
                          RCLCPP_INFO(this->get_logger(), "目标点处理成功");
                      } else if (response->result == Patrol::Response::FALL) {
                          RCLCPP_INFO(this->get_logger(), "目标点处理失败");
          private:
           rclcpp::Client<Patrol>::SharedPtr patrol_client_;
      int main(int argc, char **argv) {
          rclcpp::init(argc, argv);
          auto node = std::make_shared<PatrolClient>();
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      Cmakelists.txt文件:
      project(demo_cpp_service)
      endif()
      # find dependencies
      find_package(chapt4_interfaces REQUIRED)
      find_package(rclcpp REQUIRED)
      find_package(geometry_msgs REQUIRED)
      find_package(turtlesim REQUIRED)
      if(BUILD_TESTING)
      endif()
      add_executable(turtle_control src/turtle_control.cpp)
      add_executable(patrol_client src/patrol_client.cpp)
      ament_target_dependencies(turtle_control rclcpp geometry_msgs turtlesim chapt4_interfaces)
      install(
            TARGETS
            turtle_control
            patrol_client
      ament_package()
      colcon build报错:
      tarting >>> chapt4_interfaces
      Finished <<< chapt4_interfaces [0.42s]
      Starting >>> demo_cpp_service
      Starting >>> demo_python_service
      Finished <<< demo_python_service [0.82s]
      --- stderr: demo_cpp_service
      /home/tingbo/chapt4/chapt4_ws/src/demo_cpp_service/src/patrol_client.cpp:4:10: fatal error: rclcpp/rclcpp.hpp: 没有那个文件或目录
          4 | #include "rclcpp/rclcpp.hpp"
      compilation terminated.
      gmake[2]: *** [CMakeFiles/patrol_client.dir/build.make:76:CMakeFiles/patrol_client.dir/src/patrol_client.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:165:CMakeFiles/patrol_client.dir/all] 错误 2
      Failed   <<< demo_cpp_service [5.95s, exited with code 2]
      Summary: 2 packages finished [6.59s]
        1 package failed: demo_cpp_service
        1 package had stderr output: demo_cpp_service
      目录配置文件
          "configurations": [
                  "name": "Linux",
                  "includePath": [
                      "${workspaceFolder}/**",
                      "/opt/ros/${ROS_DISTRO}/include/**",
                      "/opt/ros/humble/include"
                  "defines": [],
                  "compilerPath": "/usr/bin/gcc",
                  "cStandard": "c17",
                  "cppStandard": "gnu++17",
                  "intelliSenseMode": "linux-gcc-x64"
          "version": 4
        小鱼 技术大佬 @43996173
        @43996173 如何你在代码中引用了某个库,那么你应该像给turtle_control链接库一样,给patrol_client练级相应的依赖库。
        # 添加该条命令
        ament_target_dependencies(patrol_client rclcpp geometry_msgs turtlesim chapt4_interfaces)
        以后请按照模板提问: https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
        4 1 条回复 最后回复 回复 引用 0
        • 4
          开心 @小鱼
          @小鱼 ok,谢谢老师!
