    动手学ros2的11章节,编译nav2包报错问题
    nav2 ros2-humble
      粉肠
      最后由 3054163659 编辑
      ubuntu22.04,humble,通过代理克隆了nav2的包后进行编译,然后报错,编译路径为工作空间下面,结果报错```
      ~/chapt8_ws$ colcon build --packages-up-to navigation2
      [0.726s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'nav2_amcl' is in: /opt/ros/humble
      'navigation2' is in: /opt/ros/humble
      'nav2_map_server' is in: /opt/ros/humble
      'nav2_navfn_planner' is in: /opt/ros/humble
      'nav2_common' is in: /opt/ros/humble
      'nav2_behavior_tree' is in: /opt/ros/humble
      'nav2_lifecycle_manager' is in: /opt/ros/humble
      'nav2_msgs' is in: /opt/ros/humble
      'nav2_planner' is in: /opt/ros/humble
      'nav2_util' is in: /opt/ros/humble
      If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      --allow-overriding nav2_amcl nav2_behavior_tree nav2_common nav2_lifecycle_manager nav2_map_server nav2_msgs nav2_navfn_planner nav2_planner nav2_util navigation2
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> nav2_common
      Starting >>> nav_2d_msgs
      Finished <<< nav2_common [0.55s]
      Starting >>> nav2_msgs
      Starting >>> nav2_voxel_grid
      Finished <<< nav_2d_msgs [1.37s]
      Starting >>> dwb_msgs
      Finished <<< nav2_msgs [2.56s]
      Starting >>> nav2_util
      Starting >>> nav2_simple_commander
      Finished <<< dwb_msgs [2.05s]
      --- stderr: nav2_simple_commander
      /usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
      warnings.warn(
      Finished <<< nav2_simple_commander [0.79s]
      --- stderr: nav2_util
      CMake Error at test/CMakeLists.txt:7 (find_package):
      By not providing "Findtest_msgs.cmake" in CMAKE_MODULE_PATH this project
      has asked CMake to find a package configuration file provided by
      "test_msgs", but CMake did not find one.
      Could not find a package configuration file provided by "test_msgs" with
      any of the following names:
      test_msgsConfig.cmake
      test_msgs-config.cmake
      Add the installation prefix of "test_msgs" to CMAKE_PREFIX_PATH or set
      "test_msgs_DIR" to a directory containing one of the above files. If
      "test_msgs" provides a separate development package or SDK, be sure it has
      been installed.
      gmake: *** [Makefile:436:cmake_check_build_system] 错误 1
      Failed <<< nav2_util [1.13s, exited with code 2]
      Aborted <<< nav2_voxel_grid [4.83s]
      Summary: 5 packages finished [6.21s]
      1 package failed: nav2_util
      1 package aborted: nav2_voxel_grid
      2 packages had stderr output: nav2_simple_commander nav2_util
      29 packages not processed
      试过下载了这个test-msgs包,再次编译后电脑死机了
      小鱼小 26932262522 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @3054163659
        @3054163659 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
        • 26932262522
          命里有我 @3054163659
          @3054163659 你好,你解决了吗,我也有这个问题
