    8.1.3 cmake找不到源文件
    cmake报错 找不到源文件
    • 4
      开心
      空间构建报错:
      tingbo@DESKTOP-NHH5E05:~/chapt8/learn_pluginlib$ colcon build
      Starting >>> motion_control_system
      --- stderr: motion_control_system
      CMake Error at CMakeLists.txt:13 (add_library):
        Cannot find source file:
          src/spin_motion_controller.cpp
        Tried extensions .c .C .c++ .cc .cpp .cxx .cu .mpp .m .M .mm .ixx .cppm .h
        .hh .h++ .hm .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .hip .ispc
        No SOURCES given to target: spin_motion_controller
      CMake Generate step failed.  Build files cannot be regenerated correctly.
      Failed   <<< motion_control_system [1.50s, exited with code 1]
      Summary: 0 packages finished [1.73s]
        1 package failed: motion_control_system
        1 package had stderr output: motion_control_system
      Failed   <<< motion_control_system [1.51s, exited with code 1]
      Summary: 0 packages finished [1.76s]
      cmakelists.txt代码:
      project(motion_control_system)
      endif()
      #==========查找依赖=========
      # find dependencies
      find_package(pluginlib REQUIRED)
      include_directories(include )
      #===========添加库文件========\
      add_library(spin_motion_controller SHARED src/spin_motion_controller.cpp)
      ament_target_dependencies(spin_motion_controller pluginlib)
      install(TARGETS spin_motion_controller
        ARCHIVE DESTINATION lib
        LIBRARY DESTINATION lib
        RUNTIME DESTINATION bin
      install(DIRECTORY include/
        DESTINATION include/
      #导出插件描述文件
      pluginlib_export_plugin_description_file(motion_control_system
      spin_motion_plugins.xml)
      if(BUILD_TESTING)
      endif()
      ament_package()
      spin_motion_cotroller.cpp代码:
      #include <iostream>
      #include "motion_control_system/spin_motion_controller.hpp"
      namespace motion_control_system{
          void SpinMotionController::start() {
              //实现旋转逻辑运动控制逻辑
              std::cout<<"SpinMotionController::start"<<std::endl;
          void SpinMotionController::stop() {
              // 停止运动控制
              std::cout<<"SpinMotionController::stop"<<std::endl;
      } //namespace motion_control_system
      #include "pluginlib/class_list_macros.hpp"
      PLUGINLIB_EXPORT_CLASS(motion_control_system::SpinMotionController,
      motion_control_system::MotionController)
      spin_motion_controller.hpp代码:
      #ifndef SPIN_MOTION_CONTROLLER_HPP
      #define SPIN_MOTION_CONTROLLER_HPP
      #include "motion_control_system/motion_control_interface.hpp"
          class SpinMotionController : public MotionController
          public:
              void start() override;
              void stop() override;
      } // namespace motion_control_system
      #endif // SPIN_MOTION_CONTROLLER_HPP
      • ganyuanzhenG
        Elysia 技术大佬 @43996173
        @43996173 在 8.1.3 cmake找不到源文件 中说:
        文件名:spin_motion_cotroller.cpp
        CMake里的文件名:src/spin_motion_controller.cpp
        是你的CMake文件名错了
        4 1 条回复 最后回复 回复 引用 0
        • 4
          开心 @ganyuanzhen
          @ganyuanzhen 在 8.1.3 cmake找不到源文件 中说:
          收到,谢谢
