    激光雷达启动失败
    雷达 humble
    1.6k
    • 32535196423
      3253519642
      环境是ubuntu22.04, humble
      使用的是ydlidar x3雷达,运行官方给的humble驱动报错,说是检测不到健康码
      [INFO] [launch]: All log files can be found below /home/star/.ros/log/2024-04-30-07-42-53-898042-star-Dell-G15-5511-71747
      [INFO] [ydlidar_ros2_driver_node-1]: process started with pid [71758]
      [INFO] [static_transform_publisher-2]: process started with pid [71760]
      [static_transform_publisher-2] [WARN] [1714434173.990213394] []: Old-style arguments are deprecated; see --help for new-style arguments
      [ydlidar_ros2_driver_node-1] [INFO] [1714434173.996838940] [ydlidar_ros2_driver_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
      [ydlidar_ros2_driver_node-1] [YDLIDAR] SDK initializing
      [ydlidar_ros2_driver_node-1] [YDLIDAR] SDK has been initialized
      [ydlidar_ros2_driver_node-1] [YDLIDAR] SDK Version: 1.2.5
      [static_transform_publisher-2] [INFO] [1714434173.998294667] [static_tf_pub_laser]: Spinning until stopped - publishing transform
      [static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.020000')
      [static_transform_publisher-2] from 'base_link' to 'laser_frame'
      [ydlidar_ros2_driver_node-1] [YDLIDAR] Lidar successfully connected [/dev/ttyUSB0:230400]
      [ydlidar_ros2_driver_node-1] [YDLIDAR] Error, cannot retrieve YDLidar health code: ffffffff
      [ydlidar_ros2_driver_node-1] [YDLIDAR] Fail to get baseplate device information
      [ydlidar_ros2_driver_node-1] [YDLIDAR] Lidar init success, Elapsed time 2661 ms
      [ydlidar_ros2_driver_node-1] [YDLIDAR] Failed to start scan mode: ffffffff
      [ydlidar_ros2_driver_node-1] [INFO] [1714434182.293046750] [ydlidar_ros2_driver_node]: [YDLIDAR INFO] Now YDLIDAR is stopping .......
      [INFO] [ydlidar_ros2_driver_node-1]: process has finished cleanly [pid 71758]
      但是sdk运行example是正常的,有没有大佬知道这是什么情况
      H 1 条回复 最后回复 回复 引用 0
      • 32535196423 3253519642 将这个主题标记为已解决,在
      • H
        hunterlin1102 @3253519642
        @3253519642 您好,我也遇到了类似的问题,请问是怎么解决的?
          wltsql
          这个怎么解决的,我现在也遇到这个问题
