    moveit2编译过程中moveit_task_constructor_core失败
    moveit2 安装
    5
    5
    934
    • 32860290153
      SoaR
      软件版本:ubuntu22.04+ros2 humble+moveit2
      出现问题:今天尝试在虚拟机上安装moveit2,完全按照一个csdn的教程来的,但是到运行指令
      colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release --parallel-workers 2
      的时候编译到moveit_task_constructor_core就失败了,报错如下:
      CMake Error at CMakeLists.txt:14 (find_package):
        By not providing "Findpy_binding_tools.cmake" in CMAKE_MODULE_PATH this
        project has asked CMake to find a package configuration file provided by
        "py_binding_tools", but CMake did not find one.
        Could not find a package configuration file provided by "py_binding_tools"
        with any of the following names:
          py_binding_toolsConfig.cmake
          py_binding_tools-config.cmake
        Add the installation prefix of "py_binding_tools" to CMAKE_PREFIX_PATH or
        set "py_binding_tools_DIR" to a directory containing one of the above
        files.  If "py_binding_tools" provides a separate development package or
        SDK, be sure it has been installed.
      尝试的解决办法:
      在电脑中搜索这个py_binding_tools什么都没有,然后尝试了
      pip3 install pybinding
      安装,但是还是没有用
      M 1 条回复 最后回复 回复 引用 1
      • M
        miracle @3286029015
        @3286029015 我和你的报错差不多,我的报错是这个:
        CMake Error at CMakeLists.txt:13 (find_package):
        By not providing "Findmoveit_task_constructor_core.cmake" in
        CMAKE_MODULE_PATH this project has asked CMake to find a package
        configuration file provided by "moveit_task_constructor_core", but CMake
        did not find one.
        "moveit_task_constructor_core" with any of the following names:
        moveit_task_constructor_coreConfig.cmake
        moveit_task_constructor_core-config.cmake
        Add the installation prefix of "moveit_task_constructor_core" to
        CMAKE_PREFIX_PATH or set "moveit_task_constructor_core_DIR" to a directory
        containing one of the above files. If "moveit_task_constructor_core"
        installed.
        4 1 条回复 最后回复 回复 引用 0
        • 3208815783
          无
          sudo apt install ros-humble-py-binding-tools
          W 1 条回复 最后回复 回复 引用 0
          • 4
            420785828 @miracle
            @miracle 你依次排查一下:
            1.编译顺序问题,可能在编译项目包的时候没有编译到某些依赖包
            2.cmakelist和package可能没有找包和链接完全。
            rosdep install --from-paths src --ignore-src -y --rosdistro humble
            检查所有依赖有没有正确安装
            3.可能你的src里进行过错误的构建操作,导致src下面有build,log,install路径,导致source冲突。删除src下的构建文件和工作空间下的构建文件重新构建
              wsxq2 @320881578
              @320881578 这位仁兄提供的回答可能才是正解,@miracle 你可以尝试下
