    《ROS 2多协议传输控制器》使用 micro-ROS 协议+以太网DHCP方式接入 ROS 系统
    多协议传输控制器
    noreplay fishros dhcp
    1.5k
      开始前准备:
      硬件:
      1. 传输控制板*1
      2. Type-B电源线*1
      3. 网线*1
      4. 带网口的电脑或者USB网卡*1
      5. 9~28V电源
      软件:
      1. 安装Ubuntu的系统*1
      2. 安装好ROS2 Humble以上版本ROS系统
      1. micro-ROS Agent 和 消息接口下载与构建
      在主目录下创建,ros2_transmission_ws 目录及子目录src(其他目录也可以)
      mkdir  -p ~/ros2_transmission_ws/src
      下载源码
      cd ~/ros2_transmission_ws/src
      git clone http://github.fishros.org/https://github.com/fishros/micro-ROS-Agent -b humble
      git clone http://github.fishros.org/https://github.com/fishros/robot_interfaces
      git clone http://github.fishros.org/https://github.com/micro-ROS/micro_ros_msgs.git -b humble
      构建工作空间
      colcon build
      Starting >>> micro_ros_agent
      Starting >>> robot_interfaces
      Finished <<< robot_interfaces [6.76s]
      [Processing: micro_ros_agent]
      --- stderr: micro_ros_agent
      正克隆到 'xrceagent'...
      切换到一个新分支 'ros2'
      HEAD 目前位于 c25243c Enable Domain Override on Reference and XML Participant (#351)
      CMake Warning (dev) at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
        The package name passed to `find_package_handle_standard_args` (tinyxml2)
        does not match the name of the calling package (TinyXML2).  This can lead
        to problems in calling code that expects `find_package` result variables
        (e.g., `_FOUND`) to follow a certain pattern.
        cmake/modules/FindTinyXML2.cmake:40 (find_package_handle_standard_args)
        /opt/ros/humble/share/fastrtps/cmake/fastrtps-config.cmake:51 (find_package)
        CMakeLists.txt:153 (find_package)
      This warning is for project developers.  Use -Wno-dev to suppress it.
      Finished <<< micro_ros_agent [56.9s]
      Summary: 2 packages finished [58.9s]
        1 package had stderr output: micro_ros_agent
      看到:Summary: 2 packages finished [58.9s] 就表示构建成功了,中间的警告请忽略。
      2.完成硬件连接
      这种连接方式的特点是,通过网线将雷达和电脑(控制卡)直连,优点是稳定。
      连接方式:
      电脑<----Type-B|USB线----->控制板USB口
      电脑<----网线----->路由器<----网线----->控制板网口
      电源---->控制板电源口
      3.查看电脑IP地址
      使用ifconfig查看所有网卡
      ifconfig
      enx4ce173422378: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 192.168.0.2  netmask 255.255.255.0  broadcast 192.168.0.255
              inet6 fe80::915b:c170:f24c:844c  prefixlen 64  scopeid 0x20<link>
              ether 4c:e1:73:42:23:78  txqueuelen 1000  (以太网)
              RX packets 38  bytes 3850 (3.8 KB)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 81  bytes 12357 (12.3 KB)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
      lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
              inet 127.0.0.1  netmask 255.0.0.0
              inet6 ::1  prefixlen 128  scopeid 0x10<host>
              loop  txqueuelen 1000  (本地环回)
              RX packets 879222  bytes 758350473 (758.3 MB)
              TX packets 879222  bytes 758350473 (758.3 MB)
      可以看到我这里有一个USB网卡:enx4ce173422378 是以太网(你的可能不是这个名字,请仔细辨别)
      目前已经自动DHCP分配了一个IP地址:192.168.0.2 这个就是服务器的IP地址。
      4.使用配置助手修改配置
      打开配置助手,扫描配置,确认如下选项的值,若不是,请手动修改。
      配置项 描述 设置值
      transport_mode 传输模式(例如以太网静态IP配置协议) eth_dhcp
      server_ip 服务器的IP地址 你的电脑ip(这里是192.168.0.2)
      server_port 服务器的端口号 8888
      传输模式我们这里采用 eth_dhcp ,动态分配IP模式,并设置micro-ROS的服务器的IP地址为你的电脑ip地址。
      设置完成后请手动或者点击配置助手的重启设备进行重启。
      5.运行agent,接收消息
      进入到工作空间,运行agent
      source install/setup.bash
      ros2 run micro_ros_agent micro_ros_agent  udp4 --port 8888 -v4
      [1719815438.222600] info     | UDPv4AgentLinux.cpp | init                     | running...             | port: 8888
      [1719815438.222750] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 4
      [1719815496.167443] info     | Root.cpp           | create_client            | create                 | client_key: 0x4786978B, session_id: 0x81
      [1719815496.167490] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0x4786978B, address: 192.168.0.5:47138
      [1719815496.183027] info     | ProxyClient.cpp    | create_participant       | participant created    | client_key: 0x4786978B, participant_id: 0x000(1)
      [1719815496.185031] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x000(2), participant_id: 0x000(1)
      [1719815496.186523] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0x4786978B, publisher_id: 0x000(3), participant_id: 0x000(1)
      [1719815496.188218] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0x4786978B, datawriter_id: 0x000(5), publisher_id: 0x000(3)
      [1719815496.190136] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x001(2), participant_id: 0x000(1)
      [1719815496.191351] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0x4786978B, subscriber_id: 0x000(4), participant_id: 0x000(1)
      [1719815496.192840] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0x4786978B, datareader_id: 0x000(6), subscriber_id: 0x000(4)
      [1719815496.194586] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x002(2), participant_id: 0x000(1)
      [1719815496.195990] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0x4786978B, publisher_id: 0x001(3), participant_id: 0x000(1)
      [1719815496.197459] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0x4786978B, datawriter_id: 0x001(5), publisher_id: 0x001(3)
      [1719815496.199148] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x003(2), participant_id: 0x000(1)
      [1719815496.200651] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0x4786978B, subscriber_id: 0x001(4), participant_id: 0x000(1)
      [1719815496.202154] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0x4786978B, datareader_id: 0x001(6), subscriber_id: 0x001(4)
      [1719815496.203922] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x004(2), participant_id: 0x000(1)
      [1719815496.205361] info     | ProxyClient.cpp    | create_publisher         | publisher created      | client_key: 0x4786978B, publisher_id: 0x002(3), participant_id: 0x000(1)
      [1719815496.206800] info     | ProxyClient.cpp    | create_datawriter        | datawriter created     | client_key: 0x4786978B, datawriter_id: 0x002(5), publisher_id: 0x002(3)
      [1719815496.208490] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x4786978B, topic_id: 0x005(2), participant_id: 0x000(1)
      [1719815496.209961] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0x4786978B, subscriber_id: 0x002(4), participant_id: 0x000(1)
      [1719815496.211445] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0x4786978B, datareader_id: 0x002(6), subscriber_id: 0x002(4)
      看到上面的日志就表示连接成功了,接着就可以尝试订阅IO状态话题,打开新的终端,输入如下命令:
      ros2 topic echo /read_io
      analog: []
      digital:
      - 1
      - 1
      - 1
      - 1
      analog: []
      digital:
      - 1
      - 1
      - 1
      - 1
      可以看到这里每帧输出了四个数据,是四个输入IO的状态,这个话题默认以10Hz进行发布,发布频率可以修改。
      使用 ros2 topic list 可以查看控制器节点可以支持的话题。
      话题名称 消息接口 订阅/发布
      /write_485 robot_interfaces/msg/RawUInt8 订阅
      /write_can robot_interfaces/msg/CanFrame 订阅
      /write_io robot_interfaces/msg/WriteIO 订阅
      /read_485 robot_interfaces/msg/RawUInt8 发布
      /read_can robot_interfaces/msg/CanFrame 发布
      /read_io robot_interfaces/msg/ReadIO 发布
      关于每个话题如何使用,可以参考例程篇介绍。
      6. 设置固定IP地址
      因为控制板要将数据发送到电脑端,如果电脑的IP采用DHCP动态分配,一旦分配到其他IP都会造成通信异常。解决方法是通过在路由器后台设置IP地址和MAC地址绑定,这样就可以保证每次分配的IP一致。
      • 小鱼小 小鱼 在 中 引用了 这个主题
