    ubuntu18.04安装melodic失败
    一键安装 动手学ros2
    • 22987766972
      Rookie
      本来想在ubuntu18.04的电脑上试一下ros1和ros2共存,原本有个melodic,想着再一键安装个ros2,但发现一键安装过程中终端在删除ros1-melodic的东西,就ctrl+c掉了,想着再一键安装melodic,但安装不上了。
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 无法下载 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/xenial/main/binary-amd64/Packages.gz 文件尺寸不符(131387 != 131381)。您使用的镜像正在同步中? [IP: 101.6.15.130 80]\n', ' Hashes of expected file:\n', ' - Filesize:131381 [weak]\n', ' - SHA256:fd30efb4caa6be6351569c6c5f3ba175e9d2229d66bfa0c5868432f2b0615fad\n', ' - SHA1:3f696a8f0c0e13c727479354dab039693065c6ea [weak]\n', ' - MD5Sum:9d97d72cdf2a96bff35317cc74a085cd [weak]\n', ' Release file created at: Mon, 23 May 2022 22:12:16 +0000\n', 'E: 部分索引文件下载失败。如果忽略它们,那将转而使用旧的索引文件。\n']
      Run CMD Task:[sudo apt search curl ]
      This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads th[|] This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads th[] This package retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads th[-]Result:success 3 amd64dock app0.12-5ubuntu3.2 amd644amd64y 5.3.5-1ubuntu3.8 all alll
      [-]Result:code:100 buntu2.19) 但是 7.58.0-2ubuntu3.24 正要被安装
      Run CMD Task:[sudo apt search gnupg2 ]
      [-]Result:success ent (new v2.x) i386sier
      [-]Result:success 卸载 0 个软件包,有 0 个软件包未被升级。
      [-]Result:code:2
      [-]Result:code:2
      导入密钥失败,开始更换导入方式并二次尝试...
      [-]Result:success K/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys F42ED6FBAB17C654
      [-]Result:success
      [-]Result:success
      [-]Result:success u xenial-security InReleaseese [4,668 B]
      Run CMD Task:[sudo apt search ros-base ]
      A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure[|] End-Effector package: provides a ROS-based set of standard interfaces to command robotics end-effectors in an agn[] A metapackage which extends ros_core and includes other basic non-robot tools like actionlib, dynamic reconfigure[-]Result:success
      RUN Choose Task:[请输入括号内的数字]
      [1]:ardent(ROS2)
      [2]:kinetic(ROS1)
      [3]:lunar(ROS2)
      [4]:melodic(ROS1)
      [0]:quit
      请输入[]内的数字以选择:4
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:melodic(ROS1)桌面版
      [2]:melodic(ROS1)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt search aptitude ]
      [-]Result:success r Debiandevelopment files)trained
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      下列信息可能会对解决问题有所帮助:
      下列软件包有未满足的依赖关系:
      ros-melodic-desktop-full : 依赖: ros-melodic-desktop 但是它将不会被安装
      依赖: ros-melodic-perception 但是它将不会被安装
      依赖: ros-melodic-simulators 但是它将不会被安装
      依赖: ros-melodic-urdf-sim-tutorial 但是它将不会被安装
      [-]Result:code:100 dic-urdf-sim-tutorial 但是它将不会被安装
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-melodic-desktop-full)
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo aptitude install ros-melodic-desktop-full]
      下列“新”软件包将被安装。
      cmake{a} cmake-data{a} fltk1.3-doc{a} fluid{a} gazebo9{ab} gazebo9-common{a} gazebo9-plugin-base{ab}
      gir1.2-gtk-2.0{a} google-mock{a} hddtemp{a} libapr1-dev{ab} libaprutil1-dev{ab} libatk1.0-dev{ab}
      libavcodec-ffmpeg56{a} libavformat-ffmpeg56{a} libavutil-ffmpeg54{a} libbluray1{a} libboost-system1.58.0{a}
      libboost-thread1.58.0{a} libbullet-dev{a} libbulletcollision2.83.6{a} libbulletdynamics2.83.6{a}
      libbulletsoftbody2.83.6{a} libbz2-dev{ab} libcairo-script-interpreter2{a} libcairo2-dev{ab}
      libconsole-bridge-dev{a} libconsole-bridge0.2v5{a} libcv-dev{a} libcvaux-dev{a} libfltk-cairo1.3{a}
      libfltk-forms1.3{a} libfltk-gl1.3{a} libfltk-images1.3{a} libfltk1.3{a} libfltk1.3-dev{a} libgazebo9{ab}
      libgazebo9-dev{ab} libgdk-pixbuf2.0-dev{ab} libgraphviz-dev{ab} libgtk2.0-dev{ab} libgtkglext1{a}
      libgts-dev{ab} libgvc6-plugins-gtk{a} libhighgui-dev{a} libilmbase-dev{a} liblinearmath2.83.6{a}
      liblog4cxx-dev{a} liblog4cxx10v5{a} liblz4-dev{ab} libmodplug1{a} libogre-1.9-dev{a} libogre-1.9.0v5{a}
      libopenal-dev{ab} libopencv-calib3d-dev{a} libopencv-calib3d2.4v5{a} libopencv-contrib-dev{a}
      libopencv-contrib2.4v5{a} libopencv-core-dev{a} libopencv-core2.4v5{a} libopencv-dev{a}
      libopencv-features2d-dev{a} libopencv-features2d2.4v5{a} libopencv-flann-dev{a} libopencv-flann2.4v5{a}
      libopencv-gpu-dev{a} libopencv-gpu2.4v5{a} libopencv-highgui-dev{a} libopencv-highgui2.4v5{a}
      libopencv-imgproc-dev{a} libopencv-imgproc2.4v5{a} libopencv-legacy-
      ros-melodic-image-pipeline{a} ros-melodic-image-proc{ab} ros-melodic-image-publisher{ab}
      ros-melodic-image-rotate{ab} ros-melodic-image-transport{ab} ros-melodic-image-transport-plugins{a}
      ros-melodic-image-view{ab} ros-melodic-interactive-marker-tutorials{a} ros-melodic-interactive-markers{a}
      ros-melodic-joint-limits-interface{a} ros-melodic-joint-state-controller{ab}
      ros-melodic-joint-state-publisher{a} ros-melodic-kdl-conversions{a} ros-melodic-kdl-parser{ab}
      ros-melodic-kdl-parser-py{a} ros-melodic-laser-assembler{ab} ros-melodic-laser-filters{ab}
      ros-melodic-laser-geometry{a} ros-melodic-laser-pipeline{a} ros-melodic-librviz-tutorial{a}
      ros-melodic-map-msgs{a} ros-melodic-media-export{a} ros-melodic-message-filters{a}
      ros-melodic-message-generation{a} ros-melodic-message-runtime{a} ros-melodic-mk{a} ros-melodic-nav-msgs{a}
      ros-melodic-nodelet{ab} ros-melodic-nodelet-core{a} ros-melodic-nodelet-topic-tools{a}
      ros-melodic-nodelet-tutorial-math{ab} ros-melodic-orocos-kdl{a} ros-melodic-pcl-conversions{a}
      ros-melodic-pcl-msgs{a} ros-melodic-pcl-ros{ab} ros-melodic-perception{a} ros-melodic-perception-pcl{a}
      ros-melodic-pluginlib{a} ros-melodic-pluginlib-tutorials{ab} ros-melodic-polled-camera{a}
      ros-melodic-position-controllers{ab} ros-melodic-python-orocos-kdl{a} ros-melodic-python-qt-binding{a}
      ros-melodic-qt-dotgraph{a} ros-melodic-qt-gui{a} ros-melodic-qt-gui-cpp{ab} ros-melodic-qt-gui-py-common{a}
      ros-melodic-qwt-dependency{a} ros-melodic-realtime-tools{a} ros-melodic-resource-retriever{ab}
      ros-melodic-robot{a} ros-melodic-robot-state-publisher{ab} ros-melodic-ros{a} ros-melodic-ros-base{a}
      ros-melodic-ros-comm{a} ros-melodic-ros-core{a} ros-melodic-ros-environment{a} ros-melodic-ros-tutorials{a}
      ros-melodic-roslaunch{a} ros-melodic-roslib{a} ros-melodic-roslint{a} ros-melodic-roslisp{a}
      ros-melodic-roslz4{a} ros-melodic-rosmake{a} ros-melodic-rosmaster{a} ros-melodic-rosmsg{a}
      ros-melodic-rosnode{a} ros-melodic-rosout{a} ros-melodic-rospack{ab} ros-melodic-rosparam{a}
      ros-melodic-rospy{a} ros-melodic-rospy-tutorials{a} ros-melodic-rosservice{a} ros-melodic-rostest{a}
      ros-melodic-rostime{a} ros-melodic-rostopic{a} ros-melodic-rosunit{a} ros-melodic-roswtf{a}
      ros-melodic-rqt-action{a} ros-melodic-rqt-bag{a} ros-melodic-rqt-bag-plugins{a}
      ros-melodic-rqt-common-plugins{a} ros-melodic-rqt-console{a} ros-melodic-rqt-dep{a} ros-melodic-rqt-graph{a}
      ros-melodic-rqt-gui{a} ros-melodic-rqt-gui-cpp{ab} ros-melodic-rqt-gui-py{a} ros-melodic-rqt-image-view{ab}
      ros-melodic-rqt-launch{a} ros-melodic-rqt-logger-level{a} ros-melodic-rqt-moveit{a} ros-melodic-rqt-msg{a}
      ros-melodic-rqt-nav-view{a} ros-melodic-rqt-plot{a} ros-melodic-rqt-pose-view{a} ros-melodic-rqt-publisher{a}
      ros-melodic-rqt-py-common{a} ros-melodic-rqt-py-console{a} ros-melodic-rqt-reconfigure{a}
      ros-melodic-rqt-robot-dashboard{a} ros-melodic-rqt-robot-monitor{a} ros-melodic-rqt-robot-plugins{a}
      ros-melodic-rqt-robot-steering{a} ros-melodic-rqt-runtime-monitor{a} ros-melodic-rqt-rviz{ab}
      ros-melodic-rqt-service-caller{a} ros-melodic-rqt-shell{a} ros-melodic-rqt-srv{a} ros-melodic-rqt-tf-tree{a}
      ros-melodic-rqt-top{a} ros-melodic-rqt-topic{a} ros-melodic-rqt-web{a} ros-melodic-rviz{ab}
      ros-melodic-rviz-plugin-tutorials{ab} ros-melodic-rviz-python-tutorial{a} ros-melodic-self-test{a}
      ros-melodic-sensor-msgs{a} ros-melodic-shape-msgs{a} ros-melodic-simulators{a} ros-melodic-smach{a}
      ros-melodic-smach-msgs{a} ros-melodic-smach-ros{a} ros-melodic-smclib{a} ros-melodic-stage{a}
      melodic-xacro{a} ros-melodic-xmlrpcpp{a} sbcl{a} sip-dev{a}
      ttf-dejavu-core{a} x11proto-composite-dev{a} x11proto-randr-dev{a} x11proto-xinerama-dev{a}
      下列软件包将被“删除”:
      ftdi-eeprom{u} libconfuse-common{u} libconfuse2{u} libftdi-dev{u} libftdi1{u} libftdi1-2{u}
      0 个软件包被升级,新安装 401 个, 6 个将被删除, 同时 0 个将不升级。
      需要获取 140 MB 的存档。 解包后将要使用 621 MB。
      下列软件包存在未满足的依赖关系:
      ros-melodic-image-proc : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-qt-gui-cpp : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                            依赖: libtinyxml2-6 (>= 5.0.0) which is a virtual package and is not provided by any available package
      python-sip-dev : 依赖: python-sip (= 4.17+dfsg-1ubuntu0.1) but 4.19.7+dfsg-1ubuntu0.1 is installed
      ros-melodic-diff-drive-controller : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                                       依赖: liburdfdom-model which is a virtual package and is not provided by any available package
      ros-melodic-gazebo-ros-control : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                                    依赖: libignition-common which is a virtual package and is not provided by any available package
                                    依赖: libignition-math4 which is a virtual package and is not provided by any available package
                                    依赖: libsdformat6 which is a virtual package and is not provided by any available package
                                    依赖: liburdfdom-world which is a virtual package and is not provided by any available package
      ros-melodic-resource-retriever : 依赖: libcurl4 (>= 7.16.2) which is a virtual package and is not provided by any available package
      ros-melodic-image-view : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-compressed-depth-image-transport : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libprotoc-dev : 依赖: libprotobuf-dev (= 2.6.1-1.3) but 3.0.0-9.1ubuntu1.1 is installed
      ros-melodic-depth-image-proc : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-image-rotate : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-gazebo-plugins : 依赖: libignition-common which is a virtual package and is not provided by any available package
                                依赖: libogre-1.9.0v5 (>= 1.9.0+dfsg1-9~) but 1.9.0+dfsg1-7 is to be installed
      ros-melodic-rviz : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libgts-dev : 依赖: libgts-0.7-5 (= 0.7.6+darcs121130-1.2) but 0.7.6+darcs121130-4 is installed
      libgtk2.0-dev : 依赖: libgtk2.0-0 (= 2.24.30-1ubuntu1.16.04.2) but 2.24.32-1ubuntu1 is installed
      libopenexr-dev : 依赖: libopenexr22 (= 2.2.0-10ubuntu2.6) but 2.2.0-11.1ubuntu1.9 is installed
      ros-melodic-rqt-image-view : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-urdf : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-position-controllers : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libcairo2-dev : 依赖: libcairo2 (= 1.14.6-1) but 1.15.10-2ubuntu0.1 is installed
      依赖: libcairo-gobject2 (= 1.14.6-1) but 1.15.10-2ubuntu0.1 is installed
      ros-melodic-nodelet-tutorial-math : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libopenal-dev : 依赖: libopenal1 (= 1:1.16.0-3) but 1:1.18.2-2 is installed
      ros-melodic-nodelet : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-class-loader : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                              依赖: libpocofoundation50 which is a virtual package and is not provided by any available package
      libgazebo9-dev : 依赖: libsdformat6-dev which is a virtual package and is not provided by any available package
                    依赖: libignition-math4-dev which is a virtual package and is not provided by any available package
                    依赖: libignition-transport4-dev which is a virtual package and is not provided by any available package
                    依赖: libignition-msgs-dev which is a virtual package and is not provided by any available package
                    依赖: libignition-common-dev which is a virtual package and is not provided by any available package
                    依赖: libignition-fuel-tools1-dev which is a virtual package and is not provided by any available package
      ros-melodic-rqt-gui-cpp : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libxrandr-dev : 依赖: libxrandr2 (= 2:1.5.0-1) but 2:1.5.1-1 is installed
      ros-melodic-image-publisher : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libbz2-dev : 依赖: libbz2-1.0 (= 1.0.6-8ubuntu0.2) but 1.0.6-8.1ubuntu0.2 is installed
      gazebo9 : 依赖: libignition-msgs which is a virtual package and is not provided by any available package
             依赖: libignition-transport4 which is a virtual package and is not provided by any available package
      ros-melodic-diagnostic-aggregator : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-robot-state-publisher : 依赖: liburdfdom-world which is a virtual package and is not provided by any available package
      libqwt-qt5-dev : 依赖: libqwt-qt5-6 (= 6.1.2-5) but 6.1.3-1 is installed
      gazebo9-plugin-base : 依赖: libcurl4 (>= 7.16.2) which is a virtual package and is not provided by any available package
      libpango1.0-dev : 依赖: gir1.2-pango-1.0 (= 1.38.1-1) but 1.40.14-1ubuntu0.1 is installed
      依赖: libpango-1.0-0 (= 1.38.1-1) but 1.40.14-1ubuntu0.1 is installed
      依赖: libpangocairo-1.0-0 (= 1.38.1-1) but 1.40.14-1ubuntu0.1 is installed
      依赖: libpangoft2-1.0-0 (= 1.38.1-1) but 1.40.14-1ubuntu0.1 is installed
      依赖: libpangoxft-1.0-0 (= 1.38.1-1) but 1.40.14-1ubuntu0.1 is installed
      ros-melodic-laser-assembler : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libxcursor-dev : 依赖: libxcursor1 (= 1:1.1.14-1ubuntu0.16.04.2) but 1:1.1.15-1 is installed
      ros-melodic-theora-image-transport : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-controller-manager : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-gazebo-ros : 依赖: libignition-common which is a virtual package and is not provided by any available package
      libxcb-shm0-dev : 依赖: libxcb-shm0 (= 1.11.1-1ubuntu1) but 1.13-2~ubuntu18.04 is installed
      ros-melodic-pcl-ros : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-rospack : 依赖: libtinyxml2-6 (>= 5.0.0) which is a virtual package and is not provided by any available package
      ros-melodic-cpp-common : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libaprutil1-dev : 依赖: libaprutil1 (= 1.5.4-1build1) but 1.6.1-2ubuntu0.1 is installed
      ros-melodic-rosbag-storage : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                                依赖: libgpgme-dev which is a virtual package and is not provided by any available package
      debhelper : 破坏: cmake (< 3.9~) but 3.5.1-1ubuntu3 is to be installed
      破坏: cmake:i386 (< 3.9~) but it is not going to be installed
      libgdk-pixbuf2.0-dev : 依赖: libgdk-pixbuf2.0-0 (= 2.32.2-1ubuntu1.6) but 2.36.11-2 is installed
      依赖: gir1.2-gdkpixbuf-2.0 (= 2.32.2-1ubuntu1.6) but 2.36.11-2 is installed
      ros-melodic-rosconsole-bridge : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-filters : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libapr1-dev : 依赖: libapr1 (= 1.5.2-3) but 1.6.3-2 is installed
      ros-melodic-pluginlib-tutorials : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-joint-state-controller : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-rosbag : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                        依赖: python-pycryptodome which is a virtual package and is not provided by any available package
      libxcomposite-dev : 依赖: libxcomposite1 (= 1:0.4.4-1) but 1:0.4.4-2 is installed
      libgraphviz-dev : 依赖: libcdt5 (= 2.38.0-12ubuntu2.1) but 2.40.1-2 is installed
      依赖: libcgraph6 (= 2.38.0-12ubuntu2.1) but 2.40.1-2 is installed
      依赖: libgvc6 (= 2.38.0-12ubuntu2.1) but 2.40.1-2 is installed
      依赖: libgvpr2 (= 2.38.0-12ubuntu2.1) but 2.40.1-2 is installed
      依赖: libpathplan4 (= 2.38.0-12ubuntu2.1) but 2.40.1-2 is installed
      ros-melodic-tf2 : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-transmission-interface : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      python-pyqt5 : 依赖: qtbase-abi-5-5-1 which is a virtual package, provided by:
      - libqt5core5a (5.5.1+dfsg-16ubuntu7.7), but 5.9.5+dfsg-0ubuntu2.6 is installed
      - libqt5core5a (5.5.1+dfsg-16ubuntu7), but 5.9.5+dfsg-0ubuntu2.6 is installed
                  依赖: sip-api-11.2 which is a virtual package, provided by:
                          - python-sip (4.17+dfsg-1ubuntu0.1), but 4.19.7+dfsg-1ubuntu0.1 is installed
                          - python-sip (4.17+dfsg-1build1), but 4.19.7+dfsg-1ubuntu0.1 is installed
      ros-melodic-rviz-plugin-tutorials : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-kdl-parser : 依赖: libtinyxml2-6 (>= 5.0.0) which is a virtual package and is not provided by any available package
      libpixman-1-dev : 依赖: libpixman-1-0 (= 0.33.6-1) but 0.34.0-2ubuntu0.1 is installed
      gnupg : 破坏: python-gnupg (< 0.3.8-3) but 0.3.8-2 is to be installed
      x11proto-dev : 破坏: x11proto-composite-dev (< 1:2018.3) but 1:0.4.2-2 is to be installed
      破坏: x11proto-composite-dev:i386 (< 1:2018.3) which is a virtual package, provided by:
      - x11proto-dev (2018.4-4), but 2018.4-4 is installed
      - x11proto-composite-dev (1:0.4.2-2), but 1:0.4.2-2 is to be installed
                  破坏: x11proto-randr-dev (< 2018.3) but 1.5.0-1 is to be installed
                  破坏: x11proto-randr-dev:i386 (< 2018.3) which is a virtual package, provided by:
                          - x11proto-randr-dev (1.5.0-1), but 1.5.0-1 is to be installed
                  破坏: x11proto-xinerama-dev (< 2018.3) but 1.2.1-2 is to be installed
                  破坏: x11proto-xinerama-dev:i386 (< 2018.3) which is a virtual package, provided by:
                          - x11proto-xinerama-dev (1.2.1-2), but 1.2.1-2 is to be installed
      ros-melodic-stereo-image-proc : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      googletest : 冲突: google-mock (< 1.8.0) but 1.7.0-18092013-1 is to be installed
      libatk1.0-dev : 依赖: libatk1.0-0 (= 2.18.0-1) but 2.28.1-1 is installed
      依赖: gir1.2-atk-1.0 (= 2.18.0-1) but 2.28.1-1 is installed
      ros-melodic-compressed-image-transport : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
                                            依赖: libturbojpeg0-dev which is a virtual package and is not provided by any available package
      ros-melodic-laser-filters : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      liblz4-dev : 依赖: liblz4-1 (= 0.0~r131-2ubuntu2) but 0.0~r131-2ubuntu3.1 is installed
      ros-melodic-rqt-rviz : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      ros-melodic-image-transport : 依赖: libconsole-bridge0.4 which is a virtual package and is not provided by any available package
      libgazebo9 : 依赖: libbullet2.87 which is a virtual package and is not provided by any available package
                依赖: libignition-fuel-tools1-1 which is a virtual package and is not provided by any available package
                依赖: libqtpropertybrowser4 which is a virtual package and is not provided by any available package
                依赖: libtinyxml2-6 (>= 6.0.0) which is a virtual package and is not provided by any available package
      [-]Result:code:2
        小鱼 技术大佬 @2298776697
        @2298776697 可能有依赖冲突,可以试试 aptitude 试试
        • 小鱼小 小鱼 将这个主题标记为已解决,在
