    spinonce时,无法正常订阅话题
    ros1 noetic 串口通讯
    1.6k
    • 24291485052
      Plaech
      最近想写一个通过简单的串口协议,遇到了一点问题。我的主函数需要不断循环接收串口,我采用了while循环+spinonce的方式执行。然后我还需要将其他信息发送出去。我使用subcribe订阅话题+回调函数的方式发送,但是我的subscriber似乎没有正确订阅,因为我使用teleop_twist_keyboard节点发送cmd_vel时显示话题没有被订阅。以下是我的主函数代码:
      	serial::Serial ser;
      	std::string tf_parent_frame_id;
      	std::string tf_frame_id;
      	std::string frame_id;
      	double time_offset_in_seconds;
      	bool broadcast_tf;
      	double linear_acceleration_stddev;
      	double angular_velocity_stddev;
      	double orientation_stddev;
      	uint8_t last_received_message_number;
      	bool received_message = false;
      	int data_packet_start;
      	tf::Quaternion orientation;
      	tf::Quaternion zero_orientation;
      	ros::init(argc, argv, "mpu6050_serial_ttl_to_imu_node");
      	ros::NodeHandle private_node_handle("~");
      	private_node_handle.param<std::string>("port", port, "/dev/ttyUSB0");  // USB端口
      	private_node_handle.param<std::string>("tf_parent_frame_id", tf_parent_frame_id, "imu_base");
      	private_node_handle.param<std::string>("tf_frame_id", tf_frame_id, "imu_link");
      	private_node_handle.param<std::string>("frame_id", frame_id, "imu_link");
      	private_node_handle.param<double>("time_offset_in_seconds", time_offset_in_seconds, 0.0);
      	private_node_handle.param<bool>("broadcast_tf", broadcast_tf, true);
      	// Standard Deviation,StdDev,标准偏差指标,目的是用来衡量**的波动性
      	private_node_handle.param<double>("linear_acceleration_stddev", linear_acceleration_stddev, 0.0);
      	private_node_handle.param<double>("angular_velocity_stddev", angular_velocity_stddev, 0.0);
      	private_node_handle.param<double>("orientation_stddev", orientation_stddev, 0.0);
      	ros::NodeHandle nh("imu");
      	ros::Publisher imu_pub = nh.advertise<sensor_msgs::Imu>("data", 100);
      	ros::Publisher imu_temperature_pub = nh.advertise<sensor_msgs::Temperature>("temperature", 50);
      	ros::ServiceServer service = nh.advertiseService("set_zero_orientation", set_zero_orientation); // 定义了一个服务器
      	ros::Subscriber sub = nh.subscribe("cmd_vel", 20, callback);
      	ros::Rate r(200); // 200 hz
      	sensor_msgs::Imu imu; // 标准数据类型 可见 http://docs.ros.org/jade/api/sensor_msgs/html/msg/Imu.html
      	 * 	Header header
      		geometry_msgs/Quaternion orientation
      		float64[9] orientation_covariance # Row major about x, y, z axes
      		geometry_msgs/Vector3 angular_velocity
      		float64[9] angular_velocity_covariance # Row major about x, y, z axes
      		geometry_msgs/Vector3 linear_acceleration
      		float64[9] linear_acceleration_covariance # Row major x, y z
      	imu.linear_acceleration_covariance[0] = linear_acceleration_stddev; // 线性加速度协方差 = 线性加速度标准差?
      	imu.linear_acceleration_covariance[4] = linear_acceleration_stddev;
      	imu.linear_acceleration_covariance[8] = linear_acceleration_stddev;
      	imu.angular_velocity_covariance[0] = angular_velocity_stddev;
      	imu.angular_velocity_covariance[4] = angular_velocity_stddev;
      	imu.angular_velocity_covariance[8] = angular_velocity_stddev;
      	imu.orientation_covariance[0] = orientation_stddev;
      	imu.orientation_covariance[4] = orientation_stddev;
      	imu.orientation_covariance[8] = orientation_stddev;
      	 *  Header header		# timestamp is the time the temperature was measured
                               	# frame_id is the location of the temperature reading
       		float64 temperature     # Measurement of the Temperature in Degrees Celsius
       		float64 variance        # 0 is interpreted as variance unknown 方差
      	sensor_msgs::Temperature temperature_msg;
      	temperature_msg.variance = 0; //方差
      	static tf::TransformBroadcaster tf_br;
      	tf::Transform transform;
      	transform.setOrigin(tf::Vector3(0, 0, 0));
      	std::string input;
      	std::string read;
      	while (ros::ok())
      		try
      			if (ser.isOpen()) // 端口打开
      				// read string from serial device 从串行设备读取字符串
      				if (ser.available())
      					read = ser.read(ser.available());
      					// ROS_INFO("read %i new characters from serial port, adding to %i characters of old input.", (int)read.size(), (int)input.size());
      					input += read;
      					// ROS_WARN_STREAM(" Wait read ");
      					// 读到的字符串长度>=33  输入中可能有完整的包
      					while (input.length() >= 35) // while there might be a complete package in input
      						//parse for data packets 解析数据包
      						data_packet_start = input.find("\x55\x51"); // 找开头的标记位
      						if (data_packet_start != std::string::npos)
      							ROS_DEBUG("found possible start of data packet at position %d", data_packet_start);
      							if ((input.length() >= data_packet_start + 33) && (input.compare(data_packet_start + 11, 2, "\x55\x52") == 0) && (input.compare(data_packet_start + 22, 2, "\x55\x53") == 0)) //check if positions 26,27 exist, then test values
      								// ROS_ERROR_STREAM(" Found ");
      								// ROS_INFO("Found");
      								 * 采用和陀螺仪同样的计算方法,当AFS_SEL=3时,数字-32767对应-16g,32767对应16g。把32767除以16,就可以得到2048, 即我们说的灵敏度。把从加速度计读出的数字除以2048,就可以换算成加速度的数值。举个例子,如果我们从加速度计读到的数字是1000,那么对应的加速度数据是1000/2048=0.49g。g为加速度的单位,重力加速度定义为1g, 等于9.8米每平方秒。
      								 * 也就是说说直接从imu中读取到的并不是真正的加速度值,而是一个比例值,相当于几倍的重力加速度g
      								// get gyro values 获得陀螺值
      								ROS_DEBUG("seems to be a real data package: long enough and found end characters");
      								for(int i = 0;i<3;i++){
      									vel_angular[0].data[1+i] = input[data_packet_start+2+i];
      									vel_angular[1].data[1+i] = input[data_packet_start+5+i];
      									vel_angular[2].data[1+i] = input[data_packet_start+8+i];
      									accel[0].data[1+i] = input[data_packet_start+13+i];
      									accel[1].data[1+i] = input[data_packet_start+16+i];
      									accel[2].data[1+i] = input[data_packet_start+19+i];
      									yaw.data[1+i] = input[data_packet_start+24+i];
      									roll.data[1+i] = input[data_packet_start+27+i];
      									pitch.data[1+i] = input[data_packet_start+30+i];
      								ROS_INFO("%f,%f,%f",yaw.d,roll.d,pitch.d);
      								tf::Matrix3x3 obs_mat;
      								obs_mat.setEulerYPR(yaw.d, pitch.d, roll.d);
      								obs_mat.getRotation(orientation);
      								// calculate measurement time
      								if (!zero_orientation_set)
      									zero_orientation = orientation;
      									zero_orientation_set = true;
      								//http://answers.ros.org/question/10124/relative-rotation-between-two-quaternions/
      								tf::Quaternion differential_rotation;
      								differential_rotation = zero_orientation.inverse() * orientation;
      								ros::Time measurement_time = ros::Time::now() + ros::Duration(time_offset_in_seconds);
      								// publish imu message
      								imu.header.stamp = measurement_time;
      								imu.header.frame_id = frame_id;
      								// quaternionTFToMsg(differential_rotation, imu.orientation); // 把tf四元数转化为geomsg四元数
      								imu.angular_velocity.x = vel_angular[0].d; // 角速度
      								imu.angular_velocity.y = vel_angular[1].d;
      								imu.angular_velocity.z = vel_angular[2].d;
      								imu.linear_acceleration.x = accel[0].d; // 线加速度
      								imu.linear_acceleration.y = accel[1].d;
      								imu.linear_acceleration.z = accel[2].d;
      								imu_pub.publish(imu);
      								// publish temperature message
      								// publish tf transform
      								if (broadcast_tf)
      									transform.setRotation(differential_rotation);
      									tf_br.sendTransform(tf::StampedTransform(transform, measurement_time, tf_parent_frame_id, tf_frame_id));
      								input.erase(0, data_packet_start + 33); // delete everything up to and including the processed packet
      							else
      								// ROS_INFO("%s",input.substr(data_packet_start + 22, 2).c_str());
      								// ROS_INFO("%d",(input.length()-data_packet_start));
      								if (input.length() >= data_packet_start + 33)
      									input.erase(0, data_packet_start + 1); // delete up to false data_packet_start character so it is not found again
      								else
      									// do not delete start character, maybe complete package has not arrived yet
      									input.erase(0, data_packet_start);
      						else
      							// no start character found in input, so delete everything
      							input.clear();
      			else
      				// try and open the serial port
      				try
      					ser.setPort(port);
      					ser.setBaudrate(115200);
      					serial::Timeout to = serial::Timeout::simpleTimeout(1000);
      					ser.setTimeout(to);
      					ser.open();
      				catch (serial::IOException &e)
      					ROS_ERROR_STREAM("Unable to open serial port " << ser.getPort() << ". Trying again in 5 seconds.");
      					ros::Duration(5).sleep();
      				if (ser.isOpen())
      					ROS_DEBUG_STREAM("Serial port " << ser.getPort() << " initialized and opened.");
      			ROS_ERROR_STREAM("Error reading from the serial port " << ser.getPort() << ". Closing connection.");
      			ser.close();
      		ros::spinOnce();
      		r.sleep();
      	ros::spin();
      	return 0;
      是因为有什么问题呢,或者有什么更好的方式进行通讯。
      我的环境是ros noetic
      24291485052 1 条回复 最后回复 回复 引用 0
      • 24291485052
        Plaech @2429148505
        @2429148505 在 spinonce时,无法正常订阅话题 中说:
        	serial::Serial ser;
        	bool broadcast_tf;
        	 * 	Header header
        	std::string input;
        	std::string read;
        	while (ros::ok())
        		try
        					input += read;
        								if (broadcast_tf)
        							else
        								else
        						else
        							input.clear();
        			else
        				try
        					ser.setPort(port);
        					ser.setTimeout(to);
        					ser.open();
        				if (ser.isOpen())
        			ser.close();
        		ros::spinOnce();
        		r.sleep();
        	ros::spin();
        	return 0;
        我的环境是ros noetic
        解决了,是node后面加了(imu),导致话题接收在/imu/cmd_vel下了
          在您的代码中,您使用了 ros::spinOnce() 来处理ROS事件,但是您也在主循环中执行了长时间运行的操作(读取串口数据和处理数据包),这可能导致 ros::spinOnce() 没有足够的机会来检查和处理订阅的消息。
          当您调用 ros::spinOnce() 时,它会检查并调用所有等待的回调函数(例如,订阅的回调)。然而,如果您的主循环阻塞了很长时间,那么这些回调可能不会被及时调用。
          此外,您的代码在循环的最后调用了 ros::spin(),这是不必要的,因为您已经在循环中使用了 ros::spinOnce()。调用 ros::spin() 会进入一个新的循环,这可能导致不可预测的行为,因为您已经有一个循环在处理串口数据和ROS事件。
          为了解决这个问题,您可以尝试以下策略:
          1. 增加 ros::spinOnce() 的调用频率:您可以通过减少 ros::Rate r(200); 中的频率来增加 ros::spinOnce() 的调用次数。但是,请注意,这可能会增加CPU的使用率。
          2. 使用ROS的异步回调:对于串口读取和处理,您可以考虑使用ROS的异步回调功能,而不是在主循环中直接处理。这样,您就可以让ROS回调机制来处理消息,而不必在主循环中阻塞。
          3. 分离串口处理和ROS事件处理:您可以将串口读取和处理放在一个单独的线程中,以便它可以并行运行而不阻塞ROS事件的处理。这将需要一些线程同步的知识,但可以使您的程序更加响应和高效。
          4. 使用ROS的Serial库:ROS提供了一个用于串口通信的库(rosserial),它可能更适合在ROS环境中使用。虽然它可能不直接支持您的特定硬件或协议,但它提供了一个框架,您可以基于它进行扩展。
          最后,请注意,您的代码中存在一些可能的错误或不一致之处,例如使用 < 和 > 而不是 &lt; 和 &gt; 来表示小于和大于符号,以及 private_node_handle.param&lt;std::string&gt; 应该是 private_node_handle.param<std::string>("key", value, default_value);。确保您的代码没有这些错误,并正确设置了所有必要的参数。
          • 24291485052
            Plaech @2429148505
            	serial::Serial ser;
            	bool broadcast_tf;
            	 * 	Header header
            	std::string input;
            	std::string read;
            	while (ros::ok())
            		try
            					input += read;
            								if (broadcast_tf)
            							else
            								else
            						else
            							input.clear();
            			else
            				try
            					ser.setPort(port);
            					ser.setTimeout(to);
            					ser.open();
            				if (ser.isOpen())
            			ser.close();
            		ros::spinOnce();
            		r.sleep();
            	ros::spin();
            	return 0;
            我的环境是ros noetic
            • 小鱼小 小鱼 将这个主题标记为已解决,在
