    安装vscode、vcxsrv docker-desktop时报错
    docker ros ros2
    • 9
      934908124
      Chocolatey v2.3.0
      Installing the following packages:
      vscode;vcxsrv;docker-desktop
      By installing, you accept licenses for the packages.
      vscode v1.92.2 already installed.
      Use --force to reinstall, specify a version to install, or try upgrade.
      vcxsrv v21.1.10 already installed.
      Downloading package from source 'https://community.chocolatey.org/api/v2/'
      Progress: Downloading docker-desktop 4.33.1... 100%
      docker-desktop v4.33.1 [Approved]
      docker-desktop package files install completed. Performing other installation steps.
      Attempt to get headers for https://desktop.docker.com/win/main/amd64/161083/Docker Desktop Installer.exe failed.
      The remote file either doesn't exist, is unauthorized, or is forbidden for url 'https://desktop.docker.com/win/main/amd64/161083/Docker Desktop Installer.exe'. Exception calling "GetResponse" with "0" argument(s): "Unable to connect to the remote server"
      from 'https://desktop.docker.com/win/main/amd64/161083/Docker Desktop Installer.exe'
      ERROR: The remote file either doesn't exist, is unauthorized, or is forbidden for url 'https://desktop.docker.com/win/main/amd64/161083/Docker Desktop Installer.exe'. Exception calling "GetResponse" with "0" argument(s): "Unable to connect to the remote server"
      This package is likely not broken for licensed users - see https://docs.chocolatey.org/en-us/features/private-cdn.
      The install of docker-desktop was NOT successful.
      Error while running 'C:\ProgramData\chocolatey\lib\docker-desktop\tools\chocolateyinstall.ps1'.
      See log for details.
      Chocolatey installed 0/3 packages. 1 packages failed.
      See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
      Warnings:
      • vcxsrv - vcxsrv v21.1.10 already installed.
      • vscode - vscode v1.92.2 already installed.
      Failures
      • docker-desktop (exited 404) - Error while running 'C:\ProgramData\chocolatey\lib\docker-desktop\tools\chocolateyinstall.ps1'.
        从您提供的错误日志来看,主要问题出现在安装 Docker Desktop 时。错误提示表明无法从指定的 URL 下载 Docker Desktop 安装程序,原因是该 URL 不存在或者无法访问。这可能是由于多种原因造成的,包括但不限于:
        1. URL 过期或错误:您尝试下载的 Docker Desktop 安装程序的 URL 可能已经过时或错误。Docker 经常更新其下载链接,因此旧的链接可能会失效。
        2. 网络问题:您的计算机可能无法访问 Docker 的下载服务器。这可能是由于网络配置问题、防火墙设置或代理设置等原因造成的。
        3. Chocolatey 配置问题:虽然不太可能,但 Chocolatey 的配置问题也可能导致无法正确下载包。
        解决方案
        1. 手动下载 Docker Desktop:
          • 访问 Docker Desktop 的官方网站 或 Docker Desktop for Windows 的下载页面。
          • 下载适用于您操作系统的 Docker Desktop 安装程序。
          • 手动安装下载的安装程序。
        2. 检查网络设置:
          • 确保您的计算机可以访问互联网,并且没有防火墙或代理设置阻止访问 Docker 的服务器。
          • 如果您在公司或学校网络中,可能需要联系网络管理员以获取帮助。
        3. 使用 Chocolatey 的 --source 参数:
          • 如果您确定 Chocolatey 的默认源有问题,可以尝试使用其他源来安装 Docker Desktop。但请注意,这通常不是必需的,因为 Chocolatey 的默认源通常是可靠的。
          • 例如,您可以使用 --source 参数指定一个不同的源,但这通常不是必需的,因为 Chocolatey 的默认源已经包含了 Docker Desktop。
        4. 更新 Chocolatey:
          • 有时更新 Chocolatey 到最新版本可以解决与包源相关的问题。
          • 您可以通过运行 choco upgrade chocolatey 来更新 Chocolatey。
        5. 查看 Chocolatey 日志:
          • 查看 Chocolatey 的日志文件(通常位于 C:\ProgramData\chocolatey\logs\chocolatey.log)可以提供更多关于错误的详细信息。
        6. 联系 Chocolatey 支持:
          • 如果问题持续存在,您可以联系 Chocolatey 的支持团队或查看其社区论坛以获取帮助。
        希望这些解决方案能帮助您成功安装 Docker Desktop!
