    Ubuntu18.04一键安装Ros2时出现404 not found
    一键安装 无法下载 ros2
    • B
      birkins
      RUN Choose Task:[请输入括号内的数字]
      [1]:bouncy(ROS2)
      [2]:crystal(ROS2)
      [3]:dashing(ROS2)
      [4]:eloquent(ROS2)
      [5]:melodic(ROS1)
      [0]:quit
      请输入[]内的数字以选择:3
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:dashing(ROS2)桌面版
      [2]:dashing(ROS2)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      Run CMD Task:[sudo apt search aptitude ]
      [-]Result:success r Debiandevelopment files)trained
      [-]Result:success e and 12 not upgraded.ger required:
      Run CMD Task:[sudo apt install ros-dashing-desktop -y]
      Reading package lists... Done
      Building dependency tree
      The following package was automatically installed and is no longer required:
      efibootmgr
      Use 'sudo apt autoremove' to remove it.
      The following additional packages will be installed:
      autotools-dev blt cppcheck cython default-libmysqlclient-dev fonts-lyx freeglut3 gdal-data gir1.2-harfbuzz-0.0
      google-mock googletest graphviz hdf5-helpers ibverbs-providers icu-devtools libaec-dev libaec0 libann0
      libarmadillo-dev libarmadillo8 libarpack2 libarpack2-dev libassimp-dev libassimp4 libavcodec-dev libavformat-dev
      libavresample-dev libavresample3 libavutil-dev libblas-dev libboost-all-dev libboost-atomic-dev
      libboost-atomic1.65-dev libboost-atomic1.65.1 libboost-chrono-dev libboost-chrono1.65-dev libboost-chrono1.65.1
      libboost-container-dev libboost-container1.65-dev libboost-container1.65.1 libboost-context-dev
      libboost-context1.65-dev libboost-context1.65.1 libboost-coroutine-dev libboost-coroutine1.65-dev
      ros-dashing-ament-index-cpp ros-dashing-ament-index-python ros-dashing-ament-lint ros-dashing-ament-lint-auto
      ros-dashing-ament-lint-cmake ros-dashing-ament-lint-common ros-dashing-ament-package ros-dashing-ament-pep257
      ros-dashing-ament-uncrustify ros-dashing-ament-xmllint ros-dashing-angles ros-dashing-builtin-interfaces
      Err:1 https://repo.huaweicloud.com/ros2/ubuntu bionic/main amd64 ros-dashing-ros-workspace amd64 0.7.2-1bionic.20201125.033634
      404 Not Found [IP: 218.10.185.36 443]
      Err:2 https://repo.huaweicloud.com/ros2/ubuntu bionic/main amd64 ros-dashing-fastcdr amd64 1.0.13-1bionic.20201125.034826
      []Err:226 https://repo.huaweicloud.com/ros2/ubuntu bionic/main amd64 ros-dashing-desktop amd64 0.7.4-1bionic.20210521.2[-]Result:code:100
      Run CMD Task:[ls /opt/ros/dashing/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
        在您的Ubuntu 18.04系统上安装ROS 2时遇到的404 Not Found错误表明指定的软件包在配置的仓库中不存在或已被移除。这通常是因为您尝试安装的ROS 2版本(在这个例子中是Dashing)已经不再被官方维护或更新,或者您使用的镜像源(在这个案例中是华为云的ROS 2仓库)中不包含该版本的包。
        为了解决这个问题,您可以尝试以下几个步骤:
        1. 更换ROS 2版本:
          • 考虑到Dashing版本可能已经不再被支持,您可以尝试安装一个更新的ROS 2版本,如Eloquent或Foxy。这些版本通常会在官方源中找到,并且更有可能得到社区的广泛支持。
        2. 更换软件源:
          • 如果您想坚持使用Dashing版本,尝试更换到一个包含该版本包的ROS 2源。例如,您可以使用官方的ROS 2仓库而不是华为云的。
        3. 手动安装:
          • 如果以上方法都不可行,您可能需要考虑从源代码手动编译ROS 2。这通常更复杂,但允许您安装任何版本的ROS 2,只要您能找到其源代码。
        更换ROS 2版本安装步骤
        这里是一个简化的安装ROS 2 Foxy版本的步骤(以Ubuntu 18.04为例):
        1. 设置ROS 2仓库:
          sudo apt update && sudo apt install -y curl wget
          sudo sh -c 'echo "deb [arch=amd64,arm64] http://packages.ros.org/ros2/ubuntu $(lsb_release -cs) main" > /etc/apt/sources.list.d/ros2-latest.list'
          sudo apt install -y software-properties-common
          sudo add-apt-repository universe
          sudo apt update
        2. 安装ROS 2:
          sudo apt install -y ros-foxy-desktop
          sudo apt install -y python3-rosdep python3-rosinstall python3-vcstools
          sudo rosdep init
          rosdep update
          rosdep install --from-paths src --ignore-src -r -y
        3. 环境设置:
          echo "source /opt/ros/foxy/setup.bash" >> ~/.bashrc
          source ~/.bashrc
        4. 验证安装:
          ros2 run demo_nodes_cpp talker
          在另一个终端中:
          ros2 run demo_nodes_py listener
        确保在执行这些步骤时替换为您想要安装的ROS 2版本(如Foxy、Eloquent等)。如果您选择从源代码编译,那么过程将更加复杂,需要克隆ROS 2的仓库,并遵循其文档中的构建说明。
