    ROS2机器人开发书籍中6.4.4不发布话题的问题
    ros2 cmdvel
    791
      我在学习第六章时成功创建了机器人模型,执行到6.4.4时一切正常,rviz中模型如下,但编辑gazebo_control_plugin.xacro,并修改fishbot.urdf.xacro增加6-38的代码后,进行重新构建 启动仿真后并没有6-39中的话题。
      具体细节和上下文:
      代码均为拷贝您提供的ros2bookcode
      <?xml version="1.0"?>
          <xacro:macro name="gazebo_control_plugin">
              <gazebo>
                      <ros>
                          <namespace>/</namespace>
                      </ros>
                      <update_rate>30</update_rate>
                      <!-- wheels -->
                      <left_joint>left_wheel_joint</left_joint>
                      <right_joint>right_wheel_joint</right_joint>
                      <!-- kinematics -->
                      <wheel_diameter>0.064</wheel_diameter>
                      <!-- limits -->
                      <!-- output -->
                      <publish_wheel_tf>true</publish_wheel_tf>
                  </plugin>
              </gazebo>
         </xacro:macro>
      </robot>
      fishbot.urdf.xacro
      <robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="fishbot">
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/base.urdf.xacro" />
          <!-- 传感器组件 -->
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/imu.urdf.xacro" />
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/laser.urdf.xacro" />
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/sensor/camera.urdf.xacro" />
           <!-- 执行器组件 -->
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/actuator/wheel.urdf.xacro" />
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/actuator/caster.urdf.xacro" />
          <xacro:base_xacro length="0.12" radius="0.1" />
          <!-- 传感器 -->
          <xacro:imu_xacro xyz="0 0 0.02" />
          <xacro:laser_xacro xyz="0 0 0.10" />
          <xacro:camera_xacro xyz="0.10 0 0.075" />
          <!-- 执行器主动轮+从动轮 -->
          <xacro:wheel_xacro wheel_name="left" xyz="0 0.10 -0.06" />
          <xacro:wheel_xacro wheel_name="right" xyz="0 -0.10 -0.06" />
          <xacro:caster_xacro caster_name="front" xyz="0.08 0.0 -0.076" />
          <xacro:caster_xacro caster_name="back" xyz="-0.08 0.0 -0.076" />
          <!-- Gazebo 插件 -->
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/plugins/gazebo_control_plugin.xacro" />
          <!-- <xacro:gazebo_control_plugin /> -->
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/fishbot.ros2_control.xacro" />
          <xacro:fishbot_ros2_control />
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/plugins/gazebo_sensor_plugin.xacro" />
          <xacro:gazebo_sensor_plugin />
      </robot>
      重新构建与启动仿真
      an@911:~/ros2bookcode/chapt6/chapt6_ws$ colcon build
      Finished <<< fishbot_description [0.09s]
      Summary: 1 package finished [0.23s]
      an@911:~/ros2bookcode/chapt6/chapt6_ws$ source install/setup.bash
      an@911:~/ros2bookcode/chapt6/chapt6_ws$ ros2 launch fishbot_description display_robot.launch.py model:=src/fishbot_description/urdf/fishbot/fishbot.urdf.xacro
      [INFO] [launch]: All log files can be found below /home/an/.ros/log/2024-09-12-19-13-09-487047-911-15696
      [INFO] [joint_state_publisher-1]: process started with pid [15698]
      [INFO] [robot_state_publisher-2]: process started with pid [15700]
      [INFO] [rviz2-3]: process started with pid [15702]
      [robot_state_publisher-2] [INFO] [1726139589.623140879] [robot_state_publisher]: got segment back_caster_link
      [robot_state_publisher-2] [INFO] [1726139589.623268195] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-2] [INFO] [1726139589.623274896] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-2] [INFO] [1726139589.623278944] [robot_state_publisher]: got segment camera_link
      [robot_state_publisher-2] [INFO] [1726139589.623283379] [robot_state_publisher]: got segment camera_optical_link
      [robot_state_publisher-2] [INFO] [1726139589.623287257] [robot_state_publisher]: got segment front_caster_link
      [robot_state_publisher-2] [INFO] [1726139589.623291064] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-2] [INFO] [1726139589.623295333] [robot_state_publisher]: got segment laser_cylinder_link
      [robot_state_publisher-2] [INFO] [1726139589.623299037] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-2] [INFO] [1726139589.623302634] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-2] [INFO] [1726139589.623306451] [robot_state_publisher]: got segment right_wheel_link
      [rviz2-3] [INFO] [1726139589.788711352] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-3] [INFO] [1726139589.788774003] [rviz2]: OpenGl version: 4.5 (GLSL 4.5)
      [joint_state_publisher-1] [INFO] [1726139589.822071202] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...
      [rviz2-3] [INFO] [1726139589.830594485] [rviz2]: Stereo is NOT SUPPORTED
      显示的话题列表
      an@911:~$ ros2 topic list
      /clicked_point
      /goal_pose
      /initialpose
      /joint_states
      /parameter_events
      /robot_description
      /rosout
      /tf
      /tf_static
      显示的仿真模型
      尝试过的解决方法:
      搜索很多次没找到解决方法,不知道是不是缺少了哪步,还请点明错误
      小鱼小 2 条回复 最后回复 回复 引用 0
        从您提供的描述和代码来看,您在尝试使用ROS 2和Gazebo来模拟一个机器人,并期望在仿真中看到特定的话题(如/odom),但实际上并没有看到这个话题。这里有几个可能的原因和解决方案:
        1. 检查Gazebo插件的加载
        首先,确保gazebo_control_plugin.xacro中的插件确实被加载到了URDF模型中。从您提供的fishbot.urdf.xacro文件来看,您已经包含了gazebo_control_plugin.xacro,但没有显式调用<xacro:gazebo_control_plugin />宏。虽然您可能通过其他方式(如fishbot_ros2_control.xacro)隐式地包含了它,但最好还是确认一下。
        解决方案:
        • 确保在URDF文件中正确调用了<xacro:gazebo_control_plugin />宏。
        • 检查fishbot_ros2_control.xacro文件,看是否有任何可能影响插件加载的代码。
        2. ROS 2 控制配置
        由于您提到了ros2_control,确保您的控制配置是正确的。ros2_control需要正确的硬件描述(通常通过YAML文件提供)和控制器配置(同样在YAML文件中)。
        解决方案:
        • 检查是否有对应的控制器配置文件(如YAML文件),并确保它们被正确加载。
        • 确保控制器节点正在运行,并且没有报告任何错误。
        3. 重新构建和清理
        有时,旧的构建文件可能会干扰新的构建。尝试清理您的构建目录并重新构建。
        解决方案:
        • 在工作空间目录中运行colcon build --packages-select fishbot_description --symlink-install来仅构建fishbot_description包。
        • 清理构建目录:rm -rf build install log,然后重新构建。
        4. 检查Gazebo和ROS 2的日志
        查看Gazebo和ROS 2的日志文件可能会提供更多关于为什么话题没有发布的线索。
        解决方案:
        • 查看~/.ros/log/目录下的ROS 2日志文件。
        • 查看Gazebo的终端输出或日志文件,看是否有任何错误或警告。
        5. 验证URDF和XACRO文件
        使用check_urdf工具验证URDF文件是否没有错误。
        解决方案:
        • 运行ros2 run robot_state_publisher robot_state_publisher fishbot_description/urdf/fishbot/fishbot.urdf.xacro,并使用check_urdf命令来验证URDF。
        6. 确保Gazebo和ROS 2的兼容性
        确保您使用的Gazebo和ROS 2版本是兼容的。
        解决方案:
        • 查阅ROS 2和Gazebo的官方文档,确认您使用的版本是否相互兼容。
        按照这些步骤检查和调整您的设置,您应该能够更接近问题的根源,并找到解决方案。如果问题仍然存在,您可能需要更详细地检查您的ROS 2控制配置或寻求来自ROS 2社区的帮助。
          小鱼 技术大佬 @1286588184
          @1286588184 没看到有启动gazebo欸
            小鱼 技术大佬 @1286588184
            @1286588184 在 ROS2机器人开发书籍中6.4.4不发布话题的问题 中说:
            重新构建与启动仿真
            你并没有启动仿真
              1286588184 @小鱼
              是启动这个launch文件吗
              an@911:~/ros2bookcode/chapt6$ ros2 launch fishbot_description gazebo_sim.launch.py
              [INFO] [launch]: All log files can be found below /home/an/.ros/log/2024-09-13-16-06-39-026307-911-4420
              [INFO] [robot_state_publisher-1]: process started with pid [4422]
              [INFO] [gzserver-2]: process started with pid [4424]
              [INFO] [gzclient-3]: process started with pid [4426]
              [INFO] [spawn_entity.py-4]: process started with pid [4428]
              [robot_state_publisher-1] [INFO] [1726214799.434220248] [robot_state_publisher]: got segment back_caster_link
              [robot_state_publisher-1] [INFO] [1726214799.434303381] [robot_state_publisher]: got segment base_footprint
              [robot_state_publisher-1] [INFO] [1726214799.434308766] [robot_state_publisher]: got segment base_link
              [robot_state_publisher-1] [INFO] [1726214799.434311465] [robot_state_publisher]: got segment camera_link
              [robot_state_publisher-1] [INFO] [1726214799.434314019] [robot_state_publisher]: got segment camera_optical_link
              [robot_state_publisher-1] [INFO] [1726214799.434316513] [robot_state_publisher]: got segment front_caster_link
              [robot_state_publisher-1] [INFO] [1726214799.434318834] [robot_state_publisher]: got segment imu_link
              [robot_state_publisher-1] [INFO] [1726214799.434321177] [robot_state_publisher]: got segment laser_cylinder_link
              [robot_state_publisher-1] [INFO] [1726214799.434323514] [robot_state_publisher]: got segment laser_link
              [robot_state_publisher-1] [INFO] [1726214799.434325751] [robot_state_publisher]: got segment left_wheel_link
              [robot_state_publisher-1] [INFO] [1726214799.434328088] [robot_state_publisher]: got segment right_wheel_link
              [gzclient-3]
              [gzserver-2]
              [spawn_entity.py-4] [INFO] [1726214799.722044380] [spawn_entity]: Spawn Entity started
              [spawn_entity.py-4] [INFO] [1726214799.722312098] [spawn_entity]: Loading entity published on topic /robot_description
              [spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
              [spawn_entity.py-4]   warnings.warn(
              [spawn_entity.py-4] [INFO] [1726214799.723847055] [spawn_entity]: Waiting for entity xml on /robot_description
              [spawn_entity.py-4] [INFO] [1726214799.735158585] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
              [spawn_entity.py-4] [INFO] [1726214799.735467999] [spawn_entity]: Waiting for service /spawn_entity
              [spawn_entity.py-4] [INFO] [1726214800.492925943] [spawn_entity]: Calling service /spawn_entity
              [gzclient-3] [Msg] Publicized address: 10.139.109.189
              [gzclient-3] [Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/an/.gazebo/models/.git"
              [gzserver-2] [Msg] Waiting for master.
              [gzserver-2] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
              [gzserver-2] [Msg] Publicized address: 10.139.109.189
              [gzserver-2] [Msg] Loading world file [/home/an/ros2bookcode/chapt6/install/fishbot_description/share/fishbot_description/world/custom_room.world]
              [gzserver-2] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
              [gzserver-2] [INFO] [1726214801.132406165] [depth_camera]: Publishing camera info to [/camera_sensor/camera_info]
              [gzserver-2] [INFO] [1726214801.132921282] [depth_camera]: Publishing depth camera info to [/camera_sensor/depth/camera_info]
              [gzserver-2] [INFO] [1726214801.133263243] [depth_camera]: Publishing pointcloud to [/camera_sensor/points]
              [spawn_entity.py-4] [INFO] [1726214801.196537173] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
              [gzserver-2] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros2_control.so: libgazebo_ros2_control.so: cannot open shared object file: No such file or directory
              [INFO] [spawn_entity.py-4]: process has finished cleanly [pid 4428]
              [INFO] [ros2-5]: process started with pid [4632]
              [ros2-5] usage: ros2 [-h] [--use-python-default-buffering]
              [ros2-5]             Call `ros2 <command> -h` for more detailed usage. ...
              [ros2-5] ros2: error: argument Call `ros2 <command> -h` for more detailed usage.: invalid choice: 'control' (choose from 'action', 'bag', 'component', 'daemon', 'doctor', 'extension_points', 'extensions', 'interface', 'launch', 'lifecycle', 'multicast', 'node', 'param', 'pkg', 'run', 'security', 'service', 'topic', 'wtf')
              [ERROR] [ros2-5]: process has died [pid 4632, exit code 2, cmd 'ros2 control load_controller --set-state active fishbot_joint_state_broadcaster'].
              [INFO] [ros2-6]: process started with pid [4634]
              [ros2-6] usage: ros2 [-h] [--use-python-default-buffering]
              [ros2-6]             Call `ros2 <command> -h` for more detailed usage. ...
              [ros2-6] ros2: error: argument Call `ros2 <command> -h` for more detailed usage.: invalid choice: 'control' (choose from 'action', 'bag', 'component', 'daemon', 'doctor', 'extension_points', 'extensions', 'interface', 'launch', 'lifecycle', 'multicast', 'node', 'param', 'pkg', 'run', 'security', 'service', 'topic', 'wtf')
              [ERROR] [ros2-6]: process has died [pid 4634, exit code 2, cmd 'ros2 control load_controller --set-state active fishbot_diff_drive_controller'].
              [gzserver-2] [Wrn] [Publisher.cc:135] Queue limit reached for topic /gazebo/default/pose/local/info, deleting message. This warning is printed only once.
              现在是这样的
              /camera_sensor/depth/image_raw
              /camera_sensor/image_raw
              /clicked_point
              /clock
              /goal_pose
              /imu
              /initialpose
              /joint_states
              /parameter_events
              /performance_metrics
              /robot_description
              /rosout
              /scan
              /tf
              /tf_static
                小鱼 技术大佬 @1286588184
                @1286588184 你是跳着看的书吗,前面的装依赖之类的是不是没看和操作
                  我又试了一下,把这里的注释取消掉就正常出现cmd和odem话题了
                  <!-- Gazebo 插件 -->
                  /clock
                  /cmd_vel
                  /imu
                  /joint_states
                  /odom
                  /parameter_events
                  /robot_description
                  /rosout
                  /scan
                  /tf
                  /tf_static
                  不太明白这里为什么被注释了
                  这个代码我是直接下载的,一开始就是带注释的
                    小鱼 技术大佬 @1286588184
                    这里的报错很明显了,没有安装依赖
                      小鱼 技术大佬 @1286588184
                      @1286588184 建议跟着书操作,了解下代码为什么这么写和注释
                        1286588184 @小鱼
                        @小鱼 我发现了这个,但书里没找到关于这个依赖的安装信息,只在6.4.2中提到安装gazebo依赖
                        n@911:~$ sudo apt install ros-humble-gazebo-ros-pkgs
                        正在读取软件包列表... 完成
                        正在分析软件包的依赖关系树... 完成
                        正在读取状态信息... 完成
                        ros-humble-gazebo-ros-pkgs 已经是最新版 (3.7.0-1jammy.20240820.174040)。
                        下列软件包是自动安装的并且现在不需要了:
                          libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib
                          python-pkg-resources python-setuptools python2 python2-minimal python2.7
                          python2.7-minimal
                        升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 103 个软件包未被升级。
                        我安装了这个,上面报错显示的那个包我在文件夹里找到了,但就是不起作用,有什么办法吗,或者说书里具体哪里有讲这个
                        我是从第六章开始学的,之前一直跟着视频课的动手学ros2,正好学到机器人gazebo仿真出问题了,然后就从这本书的第六章开始学的
                          小鱼 技术大佬 @1286588184
                          @1286588184 不是这个,书中应该还提到了ros2_control依赖
                            小鱼 技术大佬 @1286588184
                            @1286588184 代码对应的是这章结束的代码,不是刚好6.4的,你运行的代码出现了第六章最后面才出现的内容
                              1286588184 @小鱼
                              @小鱼 好的 感谢小鱼老师 我找到了 这章的代码我打算重新去理解编写 一步一步按书上来
