    代码报错求助
    代码求助 创建c++节点
    1.6k
      C++创建节点时对代码进行编译报错
      cmake_minimum_required (VERSION 3.8)
      project (ros2_cpp)
      add_executable(rs2_cpp_noode ros2_cpp_node.cpp)
      find_package(rclcpp REQUIRED)
      target_include_directories(ros2_cpp_node PUBLIC ${rclcpp_INCLUDE_DIRS})
      target_link_libraries(ros2_cpp_node ${rclcpp_LTBRARIES})
      l@l-virtual-machine-22:~/VScode workplace/chapt2$ cmake .
      -- The C compiler identification is GNU 11.4.0
      -- The CXX compiler identification is GNU 11.4.0
      -- Detecting C compiler ABI info
      -- Detecting C compiler ABI info - done
      -- Check for working C compiler: /usr/bin/cc - skipped
      -- Detecting C compile features
      -- Detecting C compile features - done
      -- Detecting CXX compiler ABI info
      -- Detecting CXX compiler ABI info - done
      -- Check for working CXX compiler: /usr/bin/c++ - skipped
      -- Detecting CXX compile features
      -- Detecting CXX compile features - done
      -- Found rclcpp: 16.0.10 (/opt/ros/humble/share/rclcpp/cmake)
      -- Found Python3: /usr/bin/python3 (found version "3.10.12") found components: Interpreter
      -- Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake)
      -- Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake)
      -- Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake)
      -- Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c
      -- Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp
      -- Found rmw_implementation_cmake: 6.1.2 (/opt/ros/humble/share/rmw_implementation_cmake/cmake)
      -- Found rmw_fastrtps_cpp: 6.2.7 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake)
      -- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libcrypto.so (found version "3.0.2")
      -- Found FastRTPS: /opt/ros/humble/include
      -- Using RMW implementation 'rmw_fastrtps_cpp' as default
      -- Looking for pthread.h
      -- Looking for pthread.h - found
      -- Performing Test CMAKE_HAVE_LIBC_PTHREAD
      -- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
      -- Found Threads: TRUE
      CMake Error at CMakeLists.txt:5 (target_include_directories):
      Cannot specify include directories for target "ros2_cpp_node" which is not
      built by this project.
      CMake Error at CMakeLists.txt:6 (target_link_libraries):
      Cannot specify link libraries for target "ros2_cpp_node" which is not built
      by this project.
      -- Configuring incomplete, errors occurred!
      See also "/home/l/VScode workplace/chapt2/CMakeFiles/CMakeOutput.log".
      l@l-virtual-machine-22:~/VScode workplace/chapt2$ make
      make: *** 没有指明目标并且找不到 makefile。 停止。
        您遇到的错误主要是因为 target_include_directories 和 target_link_libraries 调用时目标名称错误。在您的 CMakeLists.txt 文件中,您创建的可执行文件名为 rs2_cpp_noode,但在后续配置中您使用了 ros2_cpp_node。这导致了 CMake 无法找到相应的目标来设置包含目录和链接库。
        为了解决这个问题,请按照以下步骤修改您的 CMakeLists.txt 文件:
        1. 更正可执行文件的名称:确保您在 add_executable 中使用的名称与后续在 target_include_directories 和 target_link_libraries 中使用的名称一致。
        2. 确保在 find_package 调用之后添加可执行文件和库依赖:因为您需要基于找到的包来设置包含目录和链接库。
        修改后的 CMakeLists.txt 应该如下所示:
        project (ros2_cpp)
        # 查找rclcpp
        # 添加可执行文件
        add_executable(ros2_cpp_node ros2_cpp_node.cpp)
        # 设置包含目录
        # 设置链接库
        target_link_libraries(ros2_cpp_node ${rclcpp_LIBRARIES})  # 注意这里修正了变量名,原来是 ${rclcpp_LTBRARIES}
        # 注意:如果您还有其他依赖,确保在这里也设置好
        其他注意事项:
        • 确保 ros2_cpp_node.cpp 文件存在并且包含正确的 ROS 2 节点代码。
        • 检查 rclcpp_LIBRARIES 是否是您需要的正确变量名(通常这是正确的,但请根据您的 ROS 2 版本和安装情况验证)。
        • 确保您的 CMake 版本与 ROS 2 要求的版本兼容。
        完成上述修改后,重新运行 CMake 和 make 命令:
        cmake .
        make
        如果一切正常,这将编译您的 ROS 2 节点。
          小鱼 技术大佬 @小伊
          @小伊 在 代码报错求助 中说:
          正解
