    nav2 加载限速区插件不显示问题
    Nav2
    nav2 costmap speedfilter
    • 31782613053
      ᯤ⁹⁹ᴳ⁺
      最后由 3178261305 编辑
      在加载speed_filter出现不显示在map地图上的问题。
      costmap_filter_info_speedlimit.launch.py文件如下:
      import os
      from nav2_common.launch import RewrittenYaml
          # 获取成本图过滤器包的路径
          costmap_filters_demo_dir = get_package_share_directory('nav2_costmap_filters')
          # 创建自己的临时YAML文件,包括替换
          lifecycle_nodes = ['filter_mask_server', 'costmap_filter_info_server']
          namespace = LaunchConfiguration('namespace')
          use_sim_time = LaunchConfiguration('use_sim_time')
          autostart = LaunchConfiguration('autostart') # 自动启动
          params_file = LaunchConfiguration('params_file') #参数文件路径
          mask_yaml_file = LaunchConfiguration('mask')  #掩膜YAML文件的路径
          # 声明参数
          declare_namespace_cmd = DeclareLaunchArgument(
              'namespace',
              default_value='',
              description='Top-level namespace')
          declare_use_sim_time_cmd = DeclareLaunchArgument(
              'use_sim_time',
              default_value='true',
              description='如果为真,则使用模拟(Gazebo)时钟')
          declare_autostart_cmd = DeclareLaunchArgument(
              'autostart',
              description='如果为真,则自动启动 nav2 堆栈')
          declare_params_file_cmd = DeclareLaunchArgument(
              'params_file',
              default_value=os.path.join(costmap_filters_demo_dir, 'params', 'speedlimit_params.yaml'),
              description='ROS2参数文件的完整路径')
          declare_mask_yaml_file_cmd = DeclareLaunchArgument(
              'mask',
              default_value=os.path.join(costmap_filters_demo_dir, 'maps', 'speed_mask.yaml'),
              description='掩模YAML文件的完整路径')
          # 创建重写 YAML 参数
          param_substitutions = {
              'use_sim_time': use_sim_time,
              'yaml_filename': mask_yaml_file}
          configured_params = RewrittenYaml(
              source_file=params_file,
              root_key=namespace,
              param_rewrites=param_substitutions,
              convert_types=True) # 转换类型
          # 启动生命周期管理器节点
          start_lifecycle_manager_cmd = Node(
                  package='nav2_lifecycle_manager',
                  executable='lifecycle_manager',
                  name='lifecycle_manager_costmap_filters',
                  namespace=namespace,
                  output='screen',
                  emulate_tty=True,  # https://github.com/ros2/launch/issues/188
                  parameters=[{'use_sim_time': use_sim_time},
                              {'autostart': autostart},
                              {'node_names': lifecycle_nodes}])
          # 启动地图服务器节点
          start_map_server_cmd = Node(
                  package='nav2_map_server',
                  executable='map_server',
                  name='filter_mask_server',
                  output='screen',
                  emulate_tty=True,
                  parameters=[configured_params])
          # 启动成本图过滤器信息服务器节点
          start_costmap_filter_info_server_cmd = Node(
                  executable='costmap_filter_info_server',
                  name='costmap_filter_info_server',
                  output='screen',
                  emulate_tty=True,
          ld = LaunchDescription()
          # 添加声明参数的命令
          ld.add_action(declare_namespace_cmd)
          ld.add_action(declare_use_sim_time_cmd)
          ld.add_action(declare_autostart_cmd)
          ld.add_action(declare_params_file_cmd)
          ld.add_action(declare_mask_yaml_file_cmd)
          # 添加启动节点的命令
          ld.add_action(start_lifecycle_manager_cmd)
          ld.add_action(start_map_server_cmd)
          ld.add_action(start_costmap_filter_info_server_cmd)
          return ld
      speed_mask.yaml文件如下:
      image: speed_mask.pgm
      mode: scale # 图像中的灰度值会被缩放以映射到成本值上
      resolution: 0.05
      origin: [-4.61, -3.45, 0] # 原点
      negate: 0  # 不反转
      occupied_thresh: 1.0  # 占据阈值
      free_thresh: 0.0  # 空闲阈值
      speed_mask.pgm图片如下:
      speedlimit_params.yaml文件如下:
      costmap_filter_info_server:
        ros__parameters:
          use_sim_time: true
          type: 1
          filter_info_topic: "/costmap_filter_info"
          mask_topic: "/speed_filter_mask"
          base: 100.0
          multiplier: -1.0
      filter_mask_server:
        ros__parameters:
          use_sim_time: true
          frame_id: "map"
          topic_name: "/speed_filter_mask"
          yaml_filename: "speed_mask.yaml"
      navigation2_speedlimit.launch.py文件如下:
      import os
      from launch.actions import IncludeLaunchDescription
          # 定位到包的地址
          fishbot_navigation2_dir = get_package_share_directory('fishbot_navigation2')
          # 声明参数,获取配置文件路径
          # use_sim_time 这里要设置成true,因为gazebo是仿真环境,其时间是通过/clock话题获取,而不是系统时间
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          map_yaml_path = LaunchConfiguration('map',default=os.path.join(fishbot_navigation2_dir,'maps','fishbot_map.yaml'))
          nav2_param_path = LaunchConfiguration('params_file',default=os.path.join(fishbot_navigation2_dir,'param','speedlimit_nav2_params.yaml'))
          rviz_config_dir = os.path.join(nav2_bringup_dir,'rviz','nav2_default_view.rviz')
          # 声明启动launch文件,传入:地图路径、是否使用仿真时间以及nav2参数文件
          nav2_bringup_launch = IncludeLaunchDescription(
                  PythonLaunchDescriptionSource([nav2_bringup_dir,'/launch','/bringup_launch.py']),
                  launch_arguments={
                      'map': map_yaml_path,
                      'params_file': nav2_param_path}.items(),
          rviz_node =  Node(
                  package='rviz2',
                  executable='rviz2',
                  name='rviz2',
                  output='screen')
          return LaunchDescription([nav2_bringup_launch
                                    ,rviz_node
      speedlimit_nav2_params.yaml文件如下:
      amcl:
        ros__parameters:
          use_sim_time: True
          alpha1: 0.2
          alpha2: 0.2
          alpha3: 0.2
          alpha4: 0.2
          alpha5: 0.2
          base_frame_id: "base_link"
          beam_skip_distance: 0.5
          beam_skip_threshold: 0.3
          do_beamskip: false
          global_frame_id: "map"
          lambda_short: 0.1
          laser_max_range: 100.0
          laser_min_range: -1.0
          max_beams: 60
          max_particles: 2000
          min_particles: 500
          odom_frame_id: "odom"
          pf_err: 0.05
          pf_z: 0.99
          recovery_alpha_fast: 0.0
          recovery_alpha_slow: 0.0
          resample_interval: 1
          robot_model_type: "nav2_amcl::DifferentialMotionModel"
          save_pose_rate: 0.5
          sigma_hit: 0.2
          tf_broadcast: true
          transform_tolerance: 10.0
          update_min_a: 0.2
          update_min_d: 0.25
          z_hit: 0.5
          z_max: 0.05
          z_rand: 0.5
          z_short: 0.05
          scan_topic: scan
      amcl_map_client:
        ros__parameters:
          use_sim_time: True
      amcl_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      bt_navigator:
        ros__parameters:
          use_sim_time: True
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          plugin_lib_names:
          - nav2_smooth_path_action_bt_node
          - nav2_spin_action_bt_node
          - nav2_wait_action_bt_node
          - nav2_back_up_action_bt_node
          - nav2_drive_on_heading_bt_node
          - nav2_globally_updated_goal_condition_bt_node
          - nav2_is_path_valid_condition_bt_node
          - nav2_truncate_path_local_action_bt_node
          - nav2_recovery_node_bt_node
          - nav2_path_expiring_timer_condition
          - nav2_single_trigger_bt_node
          - nav2_controller_cancel_bt_node
          - nav2_path_longer_on_approach_bt_node
          - nav2_wait_cancel_bt_node
          - nav2_spin_cancel_bt_node
          - nav2_back_up_cancel_bt_node
          - nav2_drive_on_heading_cancel_bt_node
      bt_navigator_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      controller_server:
        ros__parameters:
          use_sim_time: True
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          failure_tolerance: 0.3
          progress_checker_plugin: "progress_checker"
          goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
          controller_plugins: ["FollowPath"]
          speed_limit_topic: "/speed_limit"
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          #precise_goal_checker:
          #  plugin: "nav2_controller::SimpleGoalChecker"
          #  xy_goal_tolerance: 0.25
          #  yaw_goal_tolerance: 0.25
          #  stateful: True
          general_goal_checker:
            stateful: True
          # DWB parameters
          FollowPath:
            plugin: "dwb_core::DWBLocalPlanner"
            debug_trajectory_details: True
            min_vel_x: 0.0
            min_vel_y: 0.0
            max_vel_x: 0.26
            max_vel_y: 0.0
            max_vel_theta: 1.0
            min_speed_xy: 0.0
            max_speed_xy: 0.26
            min_speed_theta: 0.0
            # Add high threshold velocity for turtlebot 3 issue.
            # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
            acc_lim_x: 2.5
            acc_lim_y: 0.0
            acc_lim_theta: 3.2
            decel_lim_x: -2.5
            decel_lim_y: 0.0
            decel_lim_theta: -3.2
            vx_samples: 20
            vy_samples: 5
            vtheta_samples: 20
            sim_time: 1.7
            linear_granularity: 0.05
            angular_granularity: 0.025
            transform_tolerance: 0.2
            trans_stopped_velocity: 0.25
            short_circuit_trajectory_evaluation: True
            stateful: True
            critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
            BaseObstacle.scale: 0.02
            PathAlign.scale: 32.0
            PathAlign.forward_point_distance: 0.1
            GoalAlign.scale: 24.0
            GoalAlign.forward_point_distance: 0.1
            PathDist.scale: 32.0
            GoalDist.scale: 24.0
            RotateToGoal.scale: 32.0
            RotateToGoal.slowing_factor: 5.0
            RotateToGoal.lookahead_time: -1.0
      controller_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      local_costmap:
        local_costmap:
          ros__parameters:
            update_frequency: 5.0
            publish_frequency: 2.0
            global_frame: odom
            use_sim_time: True
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            robot_radius: 0.08
            plugins: ["voxel_layer", "inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.16
            voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
                topic: /scan
                clearing: True
                marking: True
                data_type: "LaserScan"
                raytrace_max_range: 3.0
                raytrace_min_range: 0.0
                obstacle_max_range: 2.5
                obstacle_min_range: 0.0
            static_layer:
        local_costmap_client:
          ros__parameters:
            use_sim_time: True
        local_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      global_costmap:
        global_costmap:
          ros__parameters:
            update_frequency: 1.0
            publish_frequency: 1.0
            global_frame: map
            use_sim_time: True
            robot_radius: 0.08
            resolution: 0.05
            track_unknown_space: true
            filters: ["speed_filter"]
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
            static_layer:
            inflation_layer:
            speed_filter:
              plugin: "nav2_costmap_2d::SpeedFilter"
              enabled: True
        global_costmap_client:
          ros__parameters:
            use_sim_time: True
        global_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      map_server:
        ros__parameters:
          use_sim_time: True
          yaml_filename: "turtlebot3_world.yaml"
      map_saver:
        ros__parameters:
          use_sim_time: True
          save_map_timeout: 5.0
          free_thresh_default: 0.25
          occupied_thresh_default: 0.65
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          use_sim_time: True
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner/NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      planner_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      smoother_server:
        ros__parameters:
          use_sim_time: True
          smoother_plugins: ["simple_smoother"]
          simple_smoother:
            plugin: "nav2_smoother::SimpleSmoother"
            tolerance: 1.0e-10
            max_its: 1000
            do_refinement: True
      behavior_server:
        ros__parameters:
          costmap_topic: local_costmap/costmap_raw
          footprint_topic: local_costmap/published_footprint
          cycle_frequency: 10.0
          behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
          spin:
            plugin: "nav2_behaviors/Spin"
          backup:
            plugin: "nav2_behaviors/BackUp"
          drive_on_heading:
            plugin: "nav2_behaviors/DriveOnHeading"
          wait:
            plugin: "nav2_behaviors/Wait"
          global_frame: odom
          transform_tolerance: 0.1
          use_sim_time: true
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      robot_state_publisher:
        ros__parameters:
          use_sim_time: True
      waypoint_follower:
        ros__parameters:
          loop_rate: 20
          stop_on_failure: false
          waypoint_task_executor_plugin: "wait_at_waypoint"
          wait_at_waypoint:
            plugin: "nav2_waypoint_follower::WaitAtWaypoint"
            enabled: True
            waypoint_pause_duration: 200
      fishbot_map.yaml文件如下:
      image: fishbot_map.pgm
      mode: trinary
      resolution: 0.05
      negate: 0
      occupied_thresh: 0.65
      free_thresh: 0.25
      fishbot_map.pgm文件如下:
      启动终端:
      ros2 launch fishbot_description gazebo.launch.py
      ros2 launch fishbot_bringup fishbot_bringup.launch.py
      ros2 launch nav2_costmap_filters costmap_filter_info_speedlimit.launch.py
      ros2 launch fishbot_navigation2 navigation2_speedlimit.launch.py
      结果显示:
      没有在右上角显示限速区,这个应该怎么解决???
