    视频2.3
    章节2.3; amenttarget ros2
    476
    • Y
      yfm
      最后由 yfm 编辑
      cmake时候报错:
      yfm@yfm-virtual-machine:~/ros_learn/chapter2/C++/demo_cpp-pkg/build$ cmake ../
      -- Found ament_cmake: 1.3.10 (/opt/ros/humble/share/ament_cmake/cmake)
      -- Found rclcpp: 16.0.10 (/opt/ros/humble/share/rclcpp/cmake)
      -- Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake)
      -- Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake)
      -- Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake)
      -- Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c
      -- Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp
      -- Found rmw_implementation_cmake: 6.1.2 (/opt/ros/humble/share/rmw_implementation_cmake/cmake)
      -- Found rmw_fastrtps_cpp: 6.2.7 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake)
      -- Using RMW implementation 'rmw_fastrtps_cpp' as default
      -- Found ament_lint_auto: 0.12.11 (/opt/ros/humble/share/ament_lint_auto/cmake)
      -- Added test 'cppcheck' to perform static code analysis on C / C++ code
      RegularExpression::compile(): Nested ?+.
      RegularExpression::compile(): Error in compile.
      CMake Error at /opt/ros/humble/share/ament_cmake_cppcheck/cmake/ament_cmake_cppcheck_lint_hook.cmake:73 (string):
      string sub-command REGEX, mode MATCH failed to compile regex
      "^/home/yfm/ros_learn/chapter2/C++/demo_cpp-pkg/.
      /opt/ros/humble/share/ament_lint_auto/cmake/ament_lint_auto_package_hook.cmake:21 (ament_execute_extensions)
      /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package.cmake:66 (ament_execute_extensions)
      CMakeLists.txt:30 (ament_package)
      CMake Error at /opt/ros/humble/share/ament_cmake_cppcheck/cmake/ament_cmake_cppcheck_lint_hook.cmake:75 (string):
      :/home/yfm/ros_learn/chapter2/C++/demo_cpp-pkg/.*>$".
      -- Configured cppcheck include dirs:
      -- Configured cppcheck exclude dirs and/or files:
      -- Added test 'lint_cmake' to check CMake code style
      -- Added test 'uncrustify' to check C / C++ code style
      -- Configured uncrustify additional arguments:
      -- Added test 'xmllint' to check XML markup files
      -- Configuring incomplete, errors occurred!
      See also "/home/yfm/ros_learn/chapter2/C++/demo_cpp-pkg/build/CMakeFiles/CMakeOutput.log".
        错误消息显示,在 CMake 构建过程中遇到了一个问题:ament_find_dependencies 是一个未知的 CMake 命令。这通常意味着你的 CMakeLists.txt 文件中尝试调用了一个不存在的命令,或者相关的 CMake 模块没有被正确包含或安装。
        在 ROS 2 环境中,ament_find_dependencies 是 ament_cmake 包的一部分,用于处理依赖关系。这个错误可能由以下几个原因引起:
        1. ament_cmake 没有被正确安装:虽然错误日志显示找到了 ament_cmake(版本 1.3.10),但可能某些组件没有正确安装或配置。
        2. CMakeLists.txt 文件中的错误:可能是 CMakeLists.txt 文件中的语法错误,或者 ament_find_dependencies 命令的使用方式不正确。
        3. 环境配置问题:可能是因为环境变量没有正确设置,导致 CMake 无法找到 ament_cmake 的相关组件。
        为了解决这个问题,你可以尝试以下几个步骤:
        1. 确认 ament_cmake 已正确安装
        确保你的 ROS 2 环境已经正确安装,并且 ament_cmake 也在其中。你可以通过运行 ros2 pkg list | grep ament_cmake 来检查 ament_cmake 是否已安装。
        2. 检查 CMakeLists.txt
        • 确保你的 CMakeLists.txt 文件顶部包含了 find_package(ament_cmake REQUIRED)。
        • 检查 ament_find_dependencies 的使用是否正确,它通常应该像这样使用:ament_find_dependencies(DEPENDENCIES <dependency1> <dependency2> ...)。
        3. 重新配置环境
        • 确保你的 shell 环境已经加载了 ROS 2 的 setup.bash。你可以通过在你的 shell 中运行 source /opt/ros/humble/setup.bash 来手动加载。
        • 重新启动你的终端或重新加载你的 shell 配置文件(如 .bashrc 或 .zshrc),以确保所有环境变量都是最新的。
        4. 清理并重新构建
        • 在你的构建目录(例如 build)中,运行 make clean(如果可用)来清理旧的构建文件。
        • 从你的源代码目录重新运行 cmake .. 和 make。
        如果上述步骤仍然无法解决问题,可能需要更详细地检查你的 ROS 2 安装或寻求社区的帮助。
          小鱼 技术大佬 @yfm
          @yfm CMAKELISTS贴一下
          Y 2 条回复 最后回复 回复 引用 0
          • Y
            yfm @小鱼
            • Y
              yfm @小鱼
              project(demo_cpp-pkg)
              endif()
              add_executable(cpp_node src/cpp_node.cpp)
              # find dependencies
              find_package(rclcpp REQUIRED)
              ament_target_dependencies(cpp_node rclcpp)
              if(BUILD_TESTING)
              endif()
              ament_package()
                小鱼 技术大佬 @yfm
                @yfm 在 视频2.3 中说:
                这句话写错位置了,放到if上面
                @yfm 在 视频2.3 中说:
                if(BUILD_TESTING)
                Y 1 条回复 最后回复 回复 引用 0
                • Y
                  yfm @小鱼
                  @小鱼 下面是我又重头开始创建的workspace然后写的CMakeLists.txt
                  project(demo_cpp_node_pkg)
                  endif()
                  # find dependencies
                  #target_include_directories(cpp_node_test PUBLIC ${rclcpp_INCLUDE_DIRS})
                  #target_link_libraries(cpp_node_test ${rclcpp_LIBRARIES})
                  add_executable(cpp_node_test src/cpp_node_test.cpp)
                  ament_target_dependencies(cpp_node_test rclcpp)
                  if(BUILD_TESTING)
                  endif()
                  ament_package()
                  然后报错如下:
                  yfm@yfm-virtual-machine:~/ros_learn/C++/chapter_ws/demo_cpp_node_pkg/build$ cmake ../
                  RegularExpression::compile(): Nested *?+.
                    "^/home/yfm/ros_learn/C++/chapter_ws/demo_cpp_node_pkg/.*".
                    CMakeLists.txt:38 (ament_package)
                    "^\$<.*:/home/yfm/ros_learn/C++/chapter_ws/demo_cpp_node_pkg/.*>$".
                  See also "/home/yfm/ros_learn/C++/chapter_ws/demo_cpp_node_pkg/build/CMakeFiles/CMakeOutput.log".
