    launch启动报错
    launch.py 启动报错 humble
    734
    • 11233475321
      bstd321
      最后由 1123347532 编辑
      标题:launch 启动报错 Caught multiple exceptions when trying to load file of format [py](ROS2 HUMBLE)
      提问模板(建议直接复制粘贴):
      背景(可选):
      此为练习程序,我写了一个robot_tracker包用来读取robot_sensor的数据并滤波,编译能够通过,但是启动时报了以下错误
      [在这里详细描述您遇到的问题。请确保您提供了足够的背景信息,以便其他人能够理解您的问题。]
      具体细节和上下文:
      使用了VsCode的Ros插件启动launch文件
      启动运行之前使用了以下脚本进行工程的构建
      if [ "$SHELL" = "/bin/zsh" ]; then
          echo "source /opt/ros/humble/setup.zsh"
      elif [ "$SHELL" = "/bin/bash" ]; then
          echo "source /opt/ros/humble/setup.bash"
      else
          echo "source /opt/ros/humble/setup.sh"
      fi
      # 清理robot_tracker的旧文件
      echo "清理robot_tracker的旧文件"
      rm -rf build/robot_tracker install/robot_tracker
      rm -rf src/robot_tracker/launch/__pycache__
      mkdir -p build/robot_tracker install/robot_tracker
      # 清理robot_interfaces的旧文件
      echo "清理robot_interfaces的旧文件"
      rm -rf build/robot_interfaces install/robot_interfaces
      mkdir -p build/robot_interfaces install/robot_interfaces
      # 清理robot_sensor的旧文件
      echo "清理robot_sensor的旧文件"
      rm -rf build/robot_sensor install/robot_sensor
      mkdir -p build/robot_sensor install/robot_sensor
      # 构建 robot_interfaces
      echo "构建 robot_interfaces..."
      colcon build --packages-select robot_interfaces
          echo ". install/setup.zsh"
          . install/setup.zsh
          echo ". install/setup.bash"
      else
          echo ". install/setup.sh"
          . install/setup.sh
      fi
      # 构建 robot_sensor
      echo "构建 robot_sensor..."g
      colcon build --packages-select robot_sensor --symlink-install --event-handlers console_cohesion+ --cmake-args -DCMAKE_BUILD_TYPE=Debug
          . install/setup.zsh
      else
          . install/setup.sh
      fi
      # 构建 robot_tracker
      echo "构建 robot_tracker..."g
      colcon build --packages-select robot_tracker --symlink-install --event-handlers console_cohesion+ --cmake-args -DCMAKE_BUILD_TYPE=Debug
          . install/setup.zsh
      else
          . install/setup.sh
      fi
      echo "构建完成。"
      task.json中有如下任务:
                  "label": "build:debug_robot_tracker",
                  "type": "shell",
                  "command": ". script/build_debug_robot_tracker.sh",
                  "options": {
                      "cwd": "${workspaceFolder}" // 设置工作目录为当前工作区
                  "presentation": {
                      "reveal": "always",
                      "panel": "shared",
                      "clear": false
                  "group": "build"
      luanch.json中有如下启动任务:
                  "name" : "ROS2_Debug: robot_tracker",
                  "type" : "ros",
                  "request" : "debug_launch",
                  "target" : "${workspaceFolder}/install/robot_tracker/share/robot_tracker/launch/debug_robot_tracker.launch.py",
                  "preLaunchTask": "build:debug_robot_tracker",
      尝试过的解决方法:
      • [描述您已经尝试过的任何解决方法或方法。这可以帮助其他人了解您遇到问题的具体情况,并避免给出与您已经尝试过的解决方案相同的答案。]
      # *******Copyright (C),2019-2099,Coder*******
      # *	文件名  	:	debug_robot_tracker.launch.py
      # *	文件功能    :	Robot Sensor包Debug版本的launch文件
      # *	编程者      :	Coder
      # *	日期        :	2024.11.05
      # *	编号-----作者---------日期-------注释
      # *	00      Coder    2024.11.05	创建
      # *	说明:Robot Sensor包Debug版本的launch文件
      import os
      from launch.events import Shutdown
      from launch.event_handlers import OnProcessExit
      from launch.actions import DeclareLaunchArgument, EmitEvent, RegisterEventHandler
          robot_tracker_share_directory = get_package_share_directory('robot_tracker')
          robot_sensor_share_directory = get_package_share_directory('robot_sensor')
          rviz_config_file = LaunchConfiguration('rviz_config') # RViz配置文件相对路径
          robot_tracker_yaml_config_file = LaunchConfiguration('robot_tracker_yaml_config') # RViz配置文件相对路径
          robot_sensor_yaml_config_file = LaunchConfiguration('robot_sensor_yaml_config') # RViz配置文件相对路径
          declare_robot_tracker_yaml_config_file_cmd = DeclareLaunchArgument(
              'robot_tracker_yaml_config',
              default_value = os.path.join(robot_tracker_share_directory, 'config', 'robot_tracker.yaml'),
              description='Full path to the robot_tracker YAML config file to use')
          declare_robot_sensor_yaml_config_file_cmd = DeclareLaunchArgument(
              'robot_sensor_yaml_config',
              default_value = os.path.join(robot_sensor_share_directory, 'config', 'robot_sensor.yaml'),
              description='Full path to the robot_sensor YAML config file to use')
          declare_rviz_config_file_cmd = DeclareLaunchArgument(
              'rviz_config',
              default_value = os.path.join(robot_tracker_yaml_config_file, 'rviz', 'robot_tracker.rviz'),
              description='Full path to the RVIZ config file to use')
          start_robot_sensor_cmd = Node(
              package='robot_sensor',                         # Robot Sensor软件包
              executable='robot_sensor_node',                      # 可执行文件为robot_tracker_node
              name='robot_sensor_node',                          # 节点名称为robot_tracker
              parameters=[robot_sensor_yaml_config_file])
          start_robot_tracker_cmd = Node(
              package='robot_tracker',                         # Robot Sensor软件包
              executable='robot_tracker_node',                      # 可执行文件为robot_tracker_node
              name='robot_tracker_node',                          # 节点名称为robot_tracker
              parameters=[robot_tracker_yaml_config_file])
          # 启动RViz
          start_rviz_cmd = Node(
              package='rviz2',                         # RViz2软件包
              executable='rviz2',                      # 可执行文件为rviz2
              arguments=['-d', rviz_config_file],
              output='screen',)                        # 输出到屏幕
          # 退出事件处理器
          exit_event_handler = RegisterEventHandler(
              event_handler=OnProcessExit(
                  target_action=start_rviz_cmd,       # 关联的目标动作是启动RViz
                  on_exit=EmitEvent(event=Shutdown(reason='rviz exited'))))  # 退出时触发关闭事件
          # 创建启动描述并填充
          ld = LaunchDescription()
          ld.add_action(declare_robot_tracker_yaml_config_file_cmd)  # 添加YAML配置文件参数
          ld.add_action(declare_robot_sensor_yaml_config_file_cmd)  # 添加YAML配置文件参数
          ld.add_action(declare_rviz_config_file_cmd)  # 添加RViz配置文件参数
          ld.add_action(start_robot_sensor_cmd)  # 启动Robot Sensor
          ld.add_action(start_robot_tracker_cmd)  # 启动Robot Sensor
          ld.add_action(start_rviz_cmd)         # 启动RViz
          ld.add_action(exit_event_handler)      # 添加退出事件处理器
          return ld  # 返回构建好的启动描述
      if __name__ == '__main__':
      环境如下
      Executing dumper with the following environment:
      "SHELL": "/bin/zsh",
      "ROS_VERSION": "2",
      "LSCOLORS": "Gxfxcxdxbxegedabagacad",
      "LESS": "-R",
      "APPLICATION_INSIGHTS_NO_DIAGNOSTIC_CHANNEL": "1",
      "ROS_PYTHON_VERSION": "3",
      "ELECTRON_RUN_AS_NODE": "1",
      "PWD": "/home/lixinlong/robot_ws",
      "LOGNAME": "lixinlong",
      "XDG_SESSION_TYPE": "tty",
      "VSCODE_ESM_ENTRYPOINT": "vs/workbench/api/node/extensionHostProcess",
      "MOTD_SHOWN": "pam",
      "HOME": "/home/lixinlong",
      "AUTOJUMP_ERROR_PATH": "/home/lixinlong/.local/share/autojump/errors.log",
      "LANG": "C",
      "LS_COLORS": "",
      "SSL_CERT_DIR": "/usr/lib/ssl/certs",
      "AMENT_PREFIX_PATH": "/home/lixinlong/robot_ws/install/robot_sensor:/home/lixinlong/robot_ws/install/robot_interfaces:/opt/ros/humble",
      "CMAKE_PREFIX_PATH": "/home/lixinlong/robot_ws/install/robot_sensor:/home/lixinlong/robot_ws/install/robot_interfaces",
      "VSCODE_AGENT_FOLDER": "/home/lixinlong/.vscode-server",
      "VSCODE_L10N_BUNDLE_LOCATION": "vscode-local:/c%3A/Users/11233/.vscode/extensions/ms-ceintl.vscode-language-pack-zh-hans-1.95.2024103009/translations/extensions/vscode.json-language-features.i18n.json",
      "AUTOENV_HOME": "/home/lixinlong/.autoenv",
      "COLCON_PREFIX_PATH": "/home/lixinlong/robot_ws/install",
      "SSH_CONNECTION": "192.168.196.1 11987 192.168.196.128 22",
      "XDG_SESSION_CLASS": "user",
      "VSCODE_HANDLES_SIGPIPE": "true",
      "PYTHONPATH": "/home/lixinlong/robot_ws/install/robot_interfaces/local/lib/python3.10/dist-packages:/opt/ros/humble/lib/python3.10/site-packages:/opt/ros/humble/local/lib/python3.10/dist-packages",
      "ZSH": "/home/lixinlong/.oh-my-zsh",
      "USER": "lixinlong",
      "AUTOJUMP_SOURCED": "1",
      "DISPLAY": "192.168.10.4:0.0",
      "SHLVL": "0",
      "PAGER": "less",
      "VSCODE_CWD": "/home/lixinlong",
      "XDG_SESSION_ID": "3",
      "LD_LIBRARY_PATH": "/home/lixinlong/robot_ws/install/robot_interfaces/lib:/opt/ros/humble/opt/rviz_ogre_vendor/lib:/opt/ros/humble/lib/x86_64-linux-gnu:/opt/ros/humble/lib",
      "XDG_RUNTIME_DIR": "/run/user/1000",
      "SSL_CERT_FILE": "/usr/lib/ssl/certs/ca-certificates.crt",
      "ROS_LOCALHOST_ONLY": "0",
      "SSH_CLIENT": "192.168.196.1 11987 22",
      "VSCODE_CLI_REQUIRE_TOKEN": "7fcae6c1-9ef5-477b-8ca8-391800a5fede",
      "LC_ALL": "en_US.UTF-8",
      "XDG_DATA_DIRS": "/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop",
      "BROWSER": "/home/lixinlong/.vscode-server/cli/servers/Stable-e8653663e8840adaf45af01eab5c627a5af81807/server/bin/helpers/browser.sh",
      "PATH": "/home/lixinlong/.local/bin:/home/lixinlong/.local/bin:/home/lixinlong/.vscode-server/cli/servers/Stable-e8653663e8840adaf45af01eab5c627a5af81807/server/bin/remote-cli:/opt/ros/humble/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin",
      "DBUS_SESSION_BUS_ADDRESS": "unix:path=/run/user/1000/bus",
      "VSCODE_NLS_CONFIG": "{"userLocale":"zh-cn","osLocale":"zh-cn","resolvedLanguage":"zh-cn","defaultMessagesFile":"/home/lixinlong/.vscode-server/cli/servers/Stable-e8653663e8840adaf45af01eab5c627a5af81807/server/out/nls.messages.json","languagePack":{"translationsConfigFile":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/tcf.json","messagesFile":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/e8653663e8840adaf45af01eab5c627a5af81807/nls.messages.json","corruptMarkerFile":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/corrupted.info"},"locale":"zh-cn","availableLanguages":{"*":"zh-cn"},"_languagePackId":"992791cd017d0441f609c48108aa8c37.zh-cn","_languagePackSupport":true,"_translationsConfigFile":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/tcf.json","_cacheRoot":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn","_resolvedLanguagePackCoreLocation":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/e8653663e8840adaf45af01eab5c627a5af81807","corruptedFile":"/home/lixinlong/.vscode-server/data/clp/992791cd017d0441f609c48108aa8c37.zh-cn/corrupted.info"}",
      "ROS_DISTRO": "humble",
      "VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
      "OLDPWD": "/home/lixinlong",
      "VSCODE_IPC_HOOK_CLI": "/run/user/1000/vscode-ipc-891140e9-a245-4594-a6b3-063bb34445e3.sock",
      ": "/usr/bin/env"
      错误时日志:
      cd /home/lixinlong/robot_ws ; /usr/bin/env /usr/bin/python3.10 /home/lixinlong/.vscode-server/extensions/ms-python.debugpy-2024.12.0-linux-x64/bundled/libs/debugpy/adapter/../../debugpy/launcher 41575 -- /home/lixinlong/.vscode-server/extensions/ms-iot.vscode-ros-0.9.2/assets/scripts/ros2_launch_dumper.py /home/lixinlong/robot_ws/install/robot_tracker/share/robot_tracker/launch/debug_robot_tracker.launch.py
      Caught multiple exceptions when trying to load file of format [py]:
      • PackageNotFoundError: "package 'robot_tracker' not found, searching: ['/home/lixinlong/robot_ws/install/robot_sensor', '/home/lixinlong/robot_ws/install/robot_interfaces', '/opt/ros/humble']"
      • InvalidFrontendLaunchFileError: The launch file may have a syntax error, or its format is unknown
        根据您提供的错误信息和代码,这里有几个可能导致启动文件 debug_robot_tracker.launch.py 报错的问题。我将逐一分析并提供可能的解决方案:
        1. 包未找到错误(PackageNotFoundError):
          错误信息 PackageNotFoundError: "package 'robot_tracker' not found, searching: ['/home/lixinlong/robot_ws/install/robot_sensor', '/home/lixinlong/robot_ws/install/robot_interfaces', '/opt/ros/humble'] 表明系统无法在指定的路径中找到 robot_tracker 包。
          解决方案:
          • 确保 robot_tracker 包已经正确构建并安装在 ROS 2 工作空间中。检查 robot_ws/src/ 目录下是否存在 robot_tracker 包的源代码。
          • 确认你的工作空间已经被正确设置并源代码已经编译。你可以使用 colcon build 命令来构建工作空间。
          • 确保 source install/setup.bash 已经被执行,以便设置环境变量,让 ROS 2 能够找到新安装的包。
        2. RViz配置文件路径错误:
          在代码中,declare_rviz_config_file_cmd 的 default_value 使用了 robot_tracker_yaml_config_file 变量,这是不正确的,因为 robot_tracker_yaml_config_file 是一个指向 YAML 配置文件的路径,而不是一个目录。
          解决方案:
          • 修改 declare_rviz_config_file_cmd 的 default_value 以正确指向 RViz 配置文件的路径。例如:
                'rviz_config',
                default_value=os.path.join(robot_tracker_share_directory, 'rviz', 'robot_tracker.rviz'),
        3. 代码格式和语法:
          你的代码在 Python 脚本的末尾有一个语法错误。if name == 'main': 应该是 if __name__ == '__main__':。
          解决方案:
          • 修改代码末尾的 if 语句为 if __name__ == '__main__':。
        4. 使用正确的 Python 解释器和环境:
          确保你在使用正确的 Python 解释器和 ROS 2 环境。有时候,特别是在使用 VSCode 或其他 IDE 时,可能需要手动配置 Python 解释器路径。
        应用以上解决方案后,重新尝试运行你的启动文件。如果问题仍然存在,可能需要检查 ROS 2 的日志输出以获取更多信息。
          小鱼 技术大佬 @1123347532
          @1123347532 差个source
          11233475321 1 条回复 最后回复 回复 引用 0
          • 11233475321
            bstd321 @小鱼
            @小鱼 在 launch启动报错 中说:
            脚本里面写. install/setup.zsh了但是还是找不到,即便是在终端里把脚本按顺序敲一遍也没有,但是install目录下能看到robot_tracker这个编译的包
              小鱼 技术大佬 @1123347532
              @1123347532 把环境变量都检查一遍
              • 11233475321
                bstd321
                最后由 1123347532 编辑
                问题已解决,原因是环境变量AMENT_PREFIX_PATH错误,虽然没有找到这个变量为什么出错导致查找不到robot_tracker包,但我通过在lauch.json配置中手动修复该环境变量后启动正常,修改前配置为
                // robot_tracker_launch_task
                            "type" : "ros",
                            "request" : "launch",
                            "launch": ["rviz"]
                修改后配置为
                    "type" : "ros",
                    "launch": ["rviz"],
                    "env":{
                        "AMENT_PREFIX_PATH" : "/opt/ros/humble:${workspaceFolder}/install/robot_tracker"
                @小鱼 感谢大佬
