    6.5.2ros2 control 打开失败
    ros2 controller
    3.3k
    • S
      solito1
      报错信息如下:
      [gzserver-2] [INFO] [1732524057.660599598] [gazebo_ros2_control]: Received urdf from param server, parsing...
      [gzserver-2] [INFO] [1732524057.660640358] [gazebo_ros2_control]: Loading parameter files /home/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/config/fishbot_ros2_controller.yaml
      [gzserver-2] [rcutils|error_handling.c:65] an error string (message, file name, or formatted message) will be truncated
      [gzserver-2] [ERROR] [1732524057.661138147] [gazebo_ros2_control]: parser error Couldn't parse parameter override rule: '--param robot_description:=<?xml version="1.0" ?>
      [gzserver-2] <!-- =================================================================================== -->
      [gzserver-2] <!-- | This document was autogenerated by xacro from /home/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot.urdf.xacro | -->
      [gzserver-2] <!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
      S 1 条回复 最后回复 回复 引用 0
      • S
        solito1 @solito1
        • S
          solito1
          • S
            solito1 @solito1
              2416822676 @solito1
              @solito1 前面的缩进用两个Tab试试?
              • S
                solito1 @2416822676
                @2416822676 yaml文件的吗
                  2416822676 @solito1
                  是的 好像有看到其他帖子因为yaml的缩进导致这个问题的
                  • S
                    solito1 @2416822676
                    @2416822676 好像并不是这个问题
                        @3211700086 在 6.5.2ros2 control 打开失败 中说:
                        请问你解决了吗,我和你发生几乎相同的问题,也是[rcutils|error_handling.c:65]
