    一建安装ros出现问题#
    移动机器人制作
    ros1 一键安装 ros2 humble安装
    1.4k
    • T
      tomywang
      --2024-12-02 13:29:12-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 47.119.165.169
      Connecting to fishros.com (fishros.com)|47.119.165.169|:80... connected.
      --2024-12-02 13:29:13-- http://fishros.com/install/
      Length: 387 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================>] 387 --.-KB/s in 0s
      2024-12-02 13:29:13 (68.5 MB/s) - ‘fishros’ saved [387/387]
      E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
      --2024-12-02 13:29:15-- http://mirror.fishros.com/install/tools/base.py
      Resolving mirror.fishros.com (mirror.fishros.com)... 47.119.165.169
      Connecting to mirror.fishros.com (mirror.fishros.com)|47.119.165.169|:80... connected.
      Length: 51464 (50K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall//tools/base.py’
      /tmp/fishinstall//t 100%[===================>] 50.26K --.-KB/s in 0.01s
      2024-12-02 13:29:15 (3.71 MB/s) - ‘/tmp/fishinstall//tools/base.py’ saved [51464/51464]
      标题:使用一键安装过程中遇到程序崩溃
        File "/tmp/fishinstall/tools/base.py", line 12, in <module>
          import http.client
        File "/usr/lib/python3.10/http/client.py", line 71, in <module>
          import email.parser
        File "/usr/lib/python3.10/email/parser.py", line 12, in <module>
          from email.feedparser import FeedParser, BytesFeedParser
        File "/usr/lib/python3.10/email/feedparser.py", line 27, in <module>
          from email._policybase import compat32
        File "/usr/lib/python3.10/email/_policybase.py", line 9, in <module>
          from email.utils import _has_surrogates
        File "/usr/lib/python3.10/email/utils.py", line 28, in <module>
          import random
        File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
        File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
        File "<frozen importlib._bootstrap_external>", line 879, in exec_module
        File "<frozen importlib._bootstrap_external>", line 1012, in get_code
        File "<frozen importlib._bootstrap_external>", line 672, in _compile_bytecode
      EOFError: marshal data too short
      ubuntu@ubuntu:~/Desktop$ wget http://fishros.com/install -O fishros && . fishros
      --2024-12-02 13:31:06-- http://fishros.com/install
      --2024-12-02 13:31:06-- http://fishros.com/install/
      fishros 0%[ ] 0 --.-KB/s in 0s
      Cannot write to ‘fishros’ (No space left on device).
        小鱼 技术大佬 @tomywang
        @tomywang 在 一建安装ros出现问题# 中说:
