    microros-agent会话频繁断连,销毁重建
    fishbot microrosagent
    3.9k
    • M
      Mostima
      刚拿到四驱版fishbot时下载官方固件并使用WIFI连接,使用ROS2键盘控制FishBot移动时经常发生控制无响应问题,车载的OLED屏也频繁显示WIFI断连重新连接。
      后学习至16.6节《做个遥控车-订阅ROS2 Twist》时,使用WIFI连接控制小车也出现控制无响应问题,遂怀疑是WIFI问题,并将程序改为通过串口发布控制指令,并添加OLED显示,显示当前车辆运行状况(线速度指令/角速度指令)
      使用数据线连接小车,通过ROS2键盘控制时,按下i(前进键)小车开始前进,OLED显示屏显示当前线速度及角速度指令,但一段时间后小车自动停止,OLED屏幕显示清空,需重新按下键盘按键控制其继续移动(且有时无反应)导致控制不连续,查看运行microros-agent的终端发现会话,客户端,服务端,话题不停销毁重建
      串口控制microros-agent界面显示如下
      [1733226894.314018] info     | TermiosAgentLinux.cpp | init                     | running...             | fd: 3
      [1733226894.314568] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 4
      [1733226894.763491] info     | Root.cpp           | create_client            | create                 | client_key: 0x227F3C7A, session_id: 0x81
      [1733226894.763565] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0x227F3C7A, address: 0
      [1733226894.786831] info     | ProxyClient.cpp    | create_participant       | participant created    | client_key: 0x227F3C7A, participant_id: 0x000(1)
      [1733226894.802584] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x227F3C7A, topic_id: 0x000(2), participant_id: 0x000(1)
      [1733226894.813539] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0x227F3C7A, subscriber_id: 0x000(4), participant_id: 0x000(1)
      [1733226894.826249] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0x227F3C7A, datareader_id: 0x000(6), subscriber_id: 0x000(4)
      ---------------------------------------------------------此处断连并自动销毁重建会话---------------------------------------------------------------------------------
      [1733226933.706977] info     | Root.cpp           | delete_client            | delete                 | client_key: 0x227F3C7A
      [1733226933.707028] info     | SessionManager.hpp | destroy_session          | session closed         | client_key: 0x227F3C7A, address: 0
      [1733226933.707059] info     | Root.cpp           | create_client            | create                 | client_key: 0x78542B7B, session_id: 0x81
      [1733226933.707075] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0x78542B7B, address: 0
      [1733226933.720749] info     | ProxyClient.cpp    | create_participant       | participant created    | client_key: 0x78542B7B, participant_id: 0x000(1)
      [1733226933.736451] info     | ProxyClient.cpp    | create_topic             | topic created          | client_key: 0x78542B7B, topic_id: 0x000(2), participant_id: 0x000(1)
      [1733226933.747355] info     | ProxyClient.cpp    | create_subscriber        | subscriber created     | client_key: 0x78542B7B, subscriber_id: 0x000(4), participant_id: 0x000(1)
      [1733226933.759909] info     | ProxyClient.cpp    | create_datareader        | datareader created     | client_key: 0x78542B7B, datareader_id: 0x000(6), subscriber_id: 0x000(4)
      WIFI控制microros-agent界面显示如下
      [1733227467.146393] debug    | UDPv4AgentLinux.cpp | send_message             | [** <<UDP>> **]        | client_key: 0x08D2B914, len: 13, data:
      0000: 81 00 00 00 0B 01 05 00 05 00 05 00 80
      ---------------------------------------------------------此处发送多次消息但无响应---------------------------------------------------------------------------------
      [1733227467.346800] debug    | UDPv4AgentLinux.cpp | send_message             | [** <<UDP>> **]        | client_key: 0x08D2B914, len: 13, data:
      [1733227467.547222] debug    | UDPv4AgentLinux.cpp | send_message             | [** <<UDP>> **]        | client_key: 0x08D2B914, len: 13, data:
      [1733227467.557690] debug    | UDPv4AgentLinux.cpp | recv_message             | [==>> UDP <<==]        | client_key: 0x08D2B914, len: 24, data:
      0000: 80 00 00 00 00 01 10 00 58 52 43 45 01 00 01 0F 16 80 BD 26 81 00 FC 03
      [1733227467.586688] info     | Root.cpp           | delete_client            | delete                 | client_key: 0x08D2B914
      [1733227467.586739] info     | SessionManager.hpp | destroy_session          | session closed         | client_key: 0x08D2B914, address: 192.168.31.229:47138
      [1733227467.586775] info     | Root.cpp           | create_client            | create                 | client_key: 0x1680BD26, session_id: 0x81
      [1733227467.586792] info     | SessionManager.hpp | establish_session        | session established    | client_key: 0x1680BD26, address: 192.168.31.229:47138
      [1733227467.586983] debug    | UDPv4AgentLinux.cpp | send_message             | [** <<UDP>> **]        | client_key: 0x1680BD26, len: 19, data:
      0000: 81 00 00 00 04 01 0B 00 00 00 58 52 43 45 01 00 01 0F 00
      [1733227467.796858] debug    | UDPv4AgentLinux.cpp | recv_message             | [==>> UDP <<==]        | client_key: 0x1680BD26, len: 13, data:
      0000: 81 00 00 00 0A 01 05 00 00 00 00 3F 80
      [1733227467.797311] debug    | UDPv4AgentLinux.cpp | recv_message             | [==>> UDP <<==]        | client_key: 0x1680BD26, len: 40, data:
      0000: 81 80 00 00 01 07 20 00 00 0A 00 01 01 03 00 00 12 00 00 00 00 01 00 00 0A 00 00 00 65 73 70 33
      0020: 32 5F 63 61 72 00 00 00
      补充
      系统为ubuntu22.04,humble 双系统,非虚拟机
      一直采用usb供电,未使用电池供电,不知是否有影响
      WIFI使用小米路由器,未连接网线,单独提供给fishbot连接
      #include <Arduino.h>
      #include <Esp32McpwmMotor.h>
      #include <rcl/rcl.h>
      #include <rclc/rclc.h>
      #include <rclc/executor.h>
      #include <geometry_msgs/msg/twist.h>
      #include <Adafruit_SSD1306.h>
      #include <Adafruit_GFX.h>
      #include "Wire.h"
      // 定义 ROS2 执行器和支持结构
      rclc_executor_t executor;
      rclc_support_t support;
      // 定义 ROS2 内存分配器
      rcl_allocator_t allocator;
      // 定义 ROS2 节点和订阅者
      rcl_node_t node;
      rcl_subscription_t subscriber;
      // 定义接收到的消息结构体
      geometry_msgs__msg__Twist sub_msg;
      Adafruit_SSD1306 display(128, 64, &Wire); // 初始化 OLED 显示屏
      // 定义控制两个电机的对象
      Esp32McpwmMotor motor;
      // 回调函数,当接收到新的 Twist 消息时会被调用
      void twist_callback(const void *msg_in)
        // 将接收到的消息指针转化为 geometry_msgs__msg__Twist 类型
        const geometry_msgs__msg__Twist *twist_msg = (const geometry_msgs__msg__Twist *)msg_in;
        // 从 Twist 消息中获取线速度和角速度
        float linear_x = twist_msg->linear.x;
        float angular_z = twist_msg->angular.z;
        // 更新 OLED 显示屏
        display.clearDisplay();
        display.setCursor(0, 0);
        display.print("Linear X: ");
        display.println(linear_x);
        display.print("Angular Z: ");
        display.println(angular_z);
        display.display();
        // 如果速度为零,则停止两个电机
        if (linear_x == 0 && angular_z == 0)
          motor.updateMotorSpeed(0, 0);
          motor.updateMotorSpeed(1, 0);
          motor.updateMotorSpeed(2, 0);
          motor.updateMotorSpeed(3, 0);
          return;
        // 根据线速度和角速度控制两个电机的转速
        if (linear_x > 0)
          motor.updateMotorSpeed(0, 80);
          motor.updateMotorSpeed(1, 80);
          motor.updateMotorSpeed(2, 80);
          motor.updateMotorSpeed(3, 80);
      if (linear_x < 0)
          motor.updateMotorSpeed(0, -80);
          motor.updateMotorSpeed(1, -80);
          motor.updateMotorSpeed(2, -80);
          motor.updateMotorSpeed(3, -80);
        if (angular_z > 0)
        if (angular_z < 0)
      void setup()
        Serial.begin(115200);
        // 设置通过串口进行MicroROS通信
        set_microros_serial_transports(Serial);
        // 延时时一段时间,等待设置完成
        delay(2000);
        // 初始化两个电机的引脚
        motor.attachMotor(0, 25, 33); // 左前
        motor.attachMotor(1, 26, 27); // 右前
        motor.attachMotor(2, 12, 22); // 左后
        motor.attachMotor(3, 16, 17); // 右后
        // 初始化 ROS2 执行器和支持结构
        Wire.begin(18, 19);
        display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // 设置OLED的I2C地址,默认0x3C
        display.setTextSize(2);                    // 设置字体大小,最小为1
        display.setTextColor(SSD1306_WHITE);       // 设置字体颜色
        display.clearDisplay();                    // 清空屏幕
        display.display();                         // 显示内容
        // 初始化 ROS2 节点
        rclc_node_init_default(&node, "esp32_car", "", &support);
        // 初始化订阅者
        rclc_subscription_init_default(
            &subscriber,
            &node,
            ROSIDL_GET_MSG_TYPE_SUPPORT(geometry_msgs, msg, Twist),
            "/cmd_vel");
        rclc_executor_init(&executor, &support.context, 2, &allocator);
        // 设置订阅的回调函数
        rclc_executor_add_subscription(&executor, &subscriber, &sub_msg, &twist_callback, ON_NEW_DATA);
      void loop()
        rclc_executor_spin_some(&executor, RCL_MS_TO_NS(100)); // 循环处理数据
        小鱼 技术大佬 @Mostima
        @Mostima 在 microros-agent会话频繁断连,销毁重建 中说:
        这个有影响,小米路由器我以前遇到过这个问题,如果是双频合一的,一定要拆开,电脑连网线或者5g,小车连2.4g
        M 1 条回复 最后回复 回复 引用 0
        • M
          Mostima @小鱼
          @小鱼 已解决,采用电池供电后控制正常,应该是串口供电同时启动电机,控制板供电不足重启导致的断连
            小鱼 技术大佬 @Mostima
            @Mostima ok
            L 1 条回复 最后回复 回复 引用 0
              lyd199406 年度VIP @小鱼
              @小鱼 我也遇到了,我是很规律的8秒断一次,用电池不用usb也没有用
              leo@leo-GF63-Thin-9SC:~/Documents/fishbot_ws$ ros2 run micro_ros_agent micro_ros_agent udp4 --port 8888
              [1734092151.322971] info | UDPv4AgentLinux.cpp | init | running... | port: 8888
              [1734092151.323234] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4
              [1734092158.702468] info | Root.cpp | create_client | create | client_key: 0x46BE5C07, session_id: 0x81
              [1734092158.702616] info | SessionManager.hpp | establish_session | session established | client_key: 0x46BE5C07, address: 192.168.3.12:47138
              [1734092158.735726] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x46BE5C07, participant_id: 0x000(1)
              [1734092167.133259] info | Root.cpp | delete_client | delete | client_key: 0x46BE5C07
              [1734092167.133353] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x46BE5C07, address: 192.168.3.12:47138
              [1734092167.133401] info | Root.cpp | create_client | create | client_key: 0x505F93E2, session_id: 0x81
              [1734092167.133422] info | SessionManager.hpp | establish_session | session established | client_key: 0x505F93E2, address: 192.168.3.12:47138
              [1734092167.212723] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x505F93E2, participant_id: 0x000(1)
              [1734092175.598559] info | Root.cpp | delete_client | delete | client_key: 0x505F93E2
              [1734092175.598633] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x505F93E2, address: 192.168.3.12:47138
              [1734092175.598672] info | Root.cpp | create_client | create | client_key: 0x47BCBFD5, session_id: 0x81
              [1734092175.598695] info | SessionManager.hpp | establish_session | session established | client_key: 0x47BCBFD5, address: 192.168.3.12:47138
              [1734092175.616629] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x47BCBFD5, participant_id: 0x000(1)
              [1734092183.878941] info | Root.cpp | delete_client | delete | client_key: 0x47BCBFD5
              [1734092183.879027] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x47BCBFD5, address: 192.168.3.12:47138
              [1734092183.879061] info | Root.cpp | create_client | create | client_key: 0x459B37C3, session_id: 0x81
              [1734092183.879070] info | SessionManager.hpp | establish_session | session established | client_key: 0x459B37C3, address: 192.168.3.12:47138
              [1734092183.897088] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x459B37C3, participant_id: 0x000(1)
              [1734092192.551680] info | Root.cpp | delete_client | delete | client_key: 0x459B37C3
              [1734092192.551806] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x459B37C3, address: 192.168.3.12:47138
              [1734092192.551864] info | Root.cpp | create_client | create | client_key: 0x6BABDE96, session_id: 0x81
              [1734092192.551898] info | SessionManager.hpp | establish_session | session established | client_key: 0x6BABDE96, address: 192.168.3.12:47138
              [1734092192.567721] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x6BABDE96, participant_id: 0x000(1)
              [1734092200.832169] info | Root.cpp | delete_client | delete | client_key: 0x6BABDE96
              [1734092200.832246] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x6BABDE96, address: 192.168.3.12:47138
              [1734092200.832287] info | Root.cpp | create_client | create | client_key: 0x40E04192, session_id: 0x81
              [1734092200.832308] info | SessionManager.hpp | establish_session | session established | client_key: 0x40E04192, address: 192.168.3.12:47138
              [1734092200.850599] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x40E04192, participant_id: 0x000(1)
              [1734092209.237954] info | Root.cpp | delete_client | delete | client_key: 0x40E04192
              [1734092209.238033] info | SessionManager.hpp | destroy_session | session closed | client_key: 0x40E04192, address: 192.168.3.12:47138
              [1734092209.238080] info | Root.cpp | create_client | create | client_key: 0x270471ED, session_id: 0x81
              [1734092209.238101] info | SessionManager.hpp | establish_session | session established | client_key: 0x270471ED, address: 192.168.3.12:47138
              [1734092209.291139] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x270471ED, participant_id: 0x000(1)
                小鱼 技术大佬 @lyd199406
                @lyd199406 检查下网络延迟
                  频繁出现重新连接,并且一秒重连一次
