    利用micro-ros-agent通过serial运行,没有打印出来node
    micro-ros-agent 串口运行,没有发现node
      lyd199406 年度VIP
      背景(可选):
      ros2 run micro_ros_agent micro_ros_agent serial --dev /dev/ttyUSB0
      具体细节和上下文:
      直接复制/home/leo/Documents/PlatformIO/Projects/fishbot_motion_control/.pio/libdeps/featheresp32/micro_ros_platformio/examples/micro-ros_publisher/src/Main.cpp的代码,没有报错,但是在打印出来node
      代码:
      #include <Arduino.h>
      #include <rcl/rcl.h>
      #include <rclc/rclc.h>
      #include <rclc/executor.h>
      #include <std_msgs/msg/int32.h>
      #if !defined(MICRO_ROS_TRANSPORT_ARDUINO_SERIAL)
      #error This example is only avaliable for Arduino framework with serial transport.
      #endif
      rcl_publisher_t publisher;
      std_msgs__msg__Int32 msg;
      rclc_executor_t executor;
      rclc_support_t support;
      rcl_allocator_t allocator;
      rcl_node_t node;
      rcl_timer_t timer;
      #define RCCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){error_loop();}}
      #define RCSOFTCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){}}
      // Error handle loop
      void error_loop() {
      while(1) {
      delay(100);
      void timer_callback(rcl_timer_t * timer, int64_t last_call_time) {
      RCLC_UNUSED(last_call_time);
      if (timer != NULL) {
      RCSOFTCHECK(rcl_publish(&publisher, &msg, NULL));
      msg.data++;
      void setup() {
      // Configure serial transport
      Serial.begin(115200);
      set_microros_serial_transports(Serial);
      delay(2000);
      //create init_options
      RCCHECK(rclc_support_init(&support, 0, NULL, &allocator));
      // create node
      RCCHECK(rclc_node_init_default(&node, "micro_ros_platformio_node", "", &support));
      // create publisher
      RCCHECK(rclc_publisher_init_default(
      &publisher,
      &node,
      ROSIDL_GET_MSG_TYPE_SUPPORT(std_msgs, msg, Int32),
      "micro_ros_platformio_node_publisher"));
      // create timer,
      const unsigned int timer_timeout = 1000;
      RCCHECK(rclc_timer_init_default(
      &timer,
      &support,
      RCL_MS_TO_NS(timer_timeout),
      timer_callback));
      // create executor
      RCCHECK(rclc_executor_init(&executor, &support.context, 1, &allocator));
      RCCHECK(rclc_executor_add_timer(&executor, &timer));
      msg.data = 0;
      void loop() {
      delay(100);
      RCSOFTCHECK(rclc_executor_spin_some(&executor, RCL_MS_TO_NS(100)));
      尝试过的解决方法:
      已经重新刷过硬件,设置设备类型是运动控制板,点击一键下载,显示写入成功
        从你提供的信息来看,你已经成功地将Micro-ROS代码部署到了ESP32开发板上,并且使用了micro_ros_agent通过串口进行通信。然而,你没有在micro_ros_agent的输出中看到任何关于节点的信息。这里有几个可能的原因和相应的解决步骤:
        1. 检查串口连接:
          • 确保你的ESP32开发板通过USB正确连接到电脑,并且/dev/ttyUSB0是正确的串口设备。
          • 你可以使用screen或minicom等工具来检查串口是否有数据输出。例如,使用screen /dev/ttyUSB0 115200来查看串口输出。
        2. 检查micro_ros_agent的日志级别:
          • micro_ros_agent默认可能不打印所有节点的信息。你可以尝试增加日志级别来看是否有更多输出。使用--verbose选项来运行micro_ros_agent,例如:
            ros2 run micro_ros_agent micro_ros_agent serial --dev /dev/ttyUSB0 --verbose
          • 这将提供更详细的输出,可能包括节点的创建和连接信息。
        3. 检查Micro-ROS客户端代码:
          • 确保你的Micro-ROS客户端代码(即ESP32上的代码)正确初始化了节点、发布者和定时器。
          • 你的代码看起来是正确的,但确认没有编译错误或警告,并且所有宏定义(如MICRO_ROS_TRANSPORT_ARDUINO_SERIAL)都已正确设置。
        4. 检查ROS 2网络:
          • 确保你的ROS 2主机(运行micro_ros_agent的机器)和ESP32开发板在同一个网络中(如果适用)。
          • 如果使用WiFi或其他网络连接方式,确保网络配置正确无误。
        5. 硬件和固件问题:
          • 尝试在不同的电脑上连接ESP32,看是否是电脑或USB端口的问题。
          • 尝试使用不同的USB线或USB转串口适配器。
        6. 代码调试:
          • 在ESP32代码中添加更多的调试输出,例如使用Serial.print来打印关键步骤的状态。
          • 这可以帮助你确认代码是否按预期执行到某个点。
        7. 检查ROS 2版本兼容性:
          • 确保你使用的micro_ros_agent和Micro-ROS客户端库的版本兼容。
          • 有时候,库或工具的更新可能会引入不兼容的更改。
        如果以上步骤都不能解决问题,你可能需要更深入地检查代码或寻求Micro-ROS社区的帮助。在GitHub或相关的论坛和社区中提问,通常可以得到来自开发者和用户的帮助。
          小鱼 技术大佬 @lyd199406
          @lyd199406 这两种方法是冲突的,你不能又用配置助手,又用pio
          是 Main.cpp 吗?大小写是不是错了
          代码和教程中的对比过了吗,有没有区别
          串口波特率调整一下试试
