    Gazebo仿真 ros control中的节点启动问题
    gazebo 仿真 urdf配置 ros2control
    431
    • 9
      956635683
      四驱四转小车,gazebo启动成功:
      但是在运行以下代码时出错:
      1. ros2 control load_controller position_controller
      2. ros2 control set_controller_state position_controller active
      3. ros2 control set_controller_state position_controller inactive
        出错截图:
      gazebo进程报错:
      YAML文件截图:
      URDF文件:
      <?xml version="1.0"?>
      <robot name="SLDASM6">
        <link name="base_footprint"/>
          <child link="base_link"/>
          <origin rpy="0 0 0" xyz="0 0 0"/>
        </joint>
        <link name="base_link">
          <inertial>
            <origin
              xyz="0 2.81892564846231E-18 -0.01"
              rpy="0 0 0" />
            <mass value="0.454477345778312" />
            <inertia
              ixx="0.000871431296911177"
              ixy="-1.28282275253518E-09"
              ixz="-8.22671320090087E-21"
              iyy="0.000871738130550077"
              iyz="-1.30062780621123E-21"
              izz="0.0017128709377427" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/base_link.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <link name="LINK1">
          <inertial>
            <origin
              xyz="0 -1.38777878078145E-17 -0.0358503670123729"
              rpy="0 0 0" />
            <mass value="0.00733856168867493" />
            <inertia
              ixx="4.05757150334916E-06"
              ixy="-4.63221143029695E-23"
              ixz="2.76505770768833E-23"
              iyy="3.99722848663285E-06"
              iyz="4.18774943094673E-22"
              izz="2.67495324757519E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK1.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint name="J1" type="continuous">
          <origin
            xyz="0.0654792997866397 0.0666132205566422 0"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="LINK1" />
          <axis
            xyz="0 0 1" />
          <hardwareInterface>Position</hardwareInterface>
        </joint>
        <link name="LINK11">
          <inertial>
            <origin
              xyz="0 -1.38777878078145E-17 2.77555756156289E-17"
              rpy="0 0 0" />
            <mass value="0.0327888025255167" />
            <inertia
              ixx="8.01891151764667E-06"
              ixy="-1.38966342908909E-22"
              ixz="5.38638611724067E-22"
              iyy="1.52508917746809E-05"
              iyz="2.6315261058982E-22"
              izz="8.01891151764667E-06" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK11.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint name="J11" type="continuous">
          <origin
            xyz="0 0 -0.07"
            rpy="0 0 0" />
          <parent
            link="LINK1" />
          <child
            link="LINK11" />
          <axis
            xyz="0 1 0" />
      	<hardwareInterface>Velocity</hardwareInterface>
        </joint>
        <link name="LINK2">
          <inertial>
            <origin
              xyz="-6.93889390390723E-18 0 -0.0358503670123729"
              rpy="0 0 0" />
            <mass value="0.00733856168867492" />
            <inertia
              ixy="2.31610571514848E-23"
              ixz="-3.83931492667846E-22"
              iyz="-5.47440727449521E-22"
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK2.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J2"
          type="continuous">
          <origin
            xyz="0.065479 -0.065785 0"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="LINK2" />
          <axis
            xyz="0 0 1" />
        </joint>
        <link name="LINK22">
          <inertial>
            <origin
              xyz="0 0 2.77555756156289E-17"
              rpy="0 0 0" />
            <inertia
              ixx="8.01891151764668E-06"
              ixy="1.23911655760444E-21"
              ixz="1.87271335385636E-23"
              iyy="1.5250891774681E-05"
              iyz="9.5134033420699E-22"
              izz="8.01891151764668E-06" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK22.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J22"
          type="continuous">
          <origin
            xyz="0 0 -0.0700000000000011"
            rpy="0 0 0" />
          <parent
            link="LINK2" />
          <child
            link="LINK22" />
          <axis
            xyz="0 1 0" />
        </joint>
        <link name="LINK3">
          <inertial>
            <origin
              xyz="1.38777878078145E-17 0 -0.0358503670123729"
              rpy="0 0 0" />
            <inertia
              ixy="-2.11758236813575E-22"
              ixz="-3.43745650941657E-22"
              iyz="-4.01213179299295E-23"
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK3.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J3"
          type="continuous">
          <origin
            xyz="-0.066308 0.066613 0"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="LINK3" />
          <axis
            xyz="0 0 1" />
        </joint>
        <link
          name="LINK33">
          <inertial>
            <origin
              xyz="0 -2.77555756156289E-17 0"
              rpy="0 0 0" />
            <mass
            <inertia
              ixy="1.32348898008484E-23"
              ixz="1.20319233745711E-22"
              iyz="1.48231251644303E-22"
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK33.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J33"
          type="continuous">
          <origin
            xyz="0 0 -0.07"
            rpy="0 0 0" />
          <parent
            link="LINK3" />
          <child
            link="LINK33" />
          <axis
            xyz="0 1 0" />
        </joint>
        <link
          name="LINK4">
          <inertial>
            <origin
              xyz="0 0 -0.0358503670123729"
              rpy="0 0 0" />
            <mass
              value="0.00733856168867491" />
            <inertia
              ixy="-1.55159629369121E-44"
              ixz="1.32642618950926E-22"
              iyz="-1.35845611653203E-22"
              izz="2.67495324757518E-07" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK4.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J4"
          type="continuous">
          <origin
            xyz="-0.0663076865851465 -0.0657848337581353 0"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="LINK4" />
          <axis
            xyz="0 0 1" />
        </joint>
        <link
          name="LINK44">
          <inertial>
            <origin
              xyz="1.38777878078145E-17 0 0"
              rpy="0 0 0" />
            <mass
            <inertia
              ixy="1.05879118406788E-22"
              ixz="1.72429389430485E-21"
              iyz="-1.73567112915338E-22"
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh filename="/home/longqianjiang/gazebo_demo/src/myrobot/meshes/LINK44.STL" />
            </geometry>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
            </geometry>
          </collision>
        </link>
        <joint
          name="J44"
          type="continuous">
          <origin
            xyz="0 0 -0.0700000000000004"
            rpy="0 0 0" />
          <parent
            link="LINK4" />
          <child
            link="LINK44" />
          <axis
            xyz="0 1 0" />
        </joint>
        <gazebo reference="base_link">
      	<material>Gazebo/Red</material>
        </gazebo>
        <gazebo reference="LINK1">
        </gazebo>
        <gazebo reference="LINK2">
      	<material>Gazebo/Green</material>
        </gazebo>
        <gazebo reference="LINK3">
      	<material>Gazebo/Blue</material>
        </gazebo>
        <gazebo>
          <plugin filename="libgazebo_ros2_control.so" name="gazebo_ros2_control">
            <parameters>/home/longqianjiang/gazebo_demo/src/myrobot/config/controller.yaml</parameters>
          </plugin>
        </gazebo>
        <ros2_control name="GazeboSystem" type="system">
          <hardware>
            <plugin>gazebo_ros2_control/GazeboSystem</plugin>
          </hardware>
          <joint name="J1">
            <command_interface name="position">
              <param name="min">-3.140000001</param>
              <param name="max">3.140000001</param>
      		<param name="initial_value">0.00000001</param>
            </command_interface>
      	  <state_interface name="position"/>
      	  <state_interface name="velocity"/>
          </joint>
          <joint name="J11">
            <command_interface name="velocity">
      	  <state_interface name="position">
            </state_interface>
          </joint>
          <joint name="J2">
          </joint>
          <joint name="J22">
            </state_interface>
          </joint>
          <joint name="J3">
          </joint>
          <joint name="J33">
            </state_interface>
          </joint>
          <joint name="J4">
          </joint>
          <joint name="J44">
            </state_interface>
          </joint>
        </ros2_control>
      </robot>
      9 1 条回复 最后回复 回复 引用 0
      • 9
        956635683 @956635683
        最后由 956635683 编辑
        上面说我的'joints' parameter was empty ,可是我的controllers.yaml就放在\wsl.localhost\Ubuntu-22.04\home\longqianjiang\gazebo_demo\src\myrobot\config下面,URDF上写了绝对路径,应该是可以读到的,怎么会为空呢
        • 9
          956635683
          自己解决了,是yaml的问题,改成如下格式即可,
          controller_manager:
          ros__parameters:
          update_rate: 100
          joint_state_broadcaster:
          type: joint_state_broadcaster/JointStateBroadcaster
          position_controller:
          type: position_controllers/JointGroupPositionController
          ros__parameters:
          joints:
          - J1
          韭菜会自己长出来的是吧?
            小鱼 技术大佬 @956635683
            @956635683 emmmm?
            • 9
              956635683 @小鱼
              @小鱼 鱼,gazebo有没有四驱四转的插件啊,自己写太痛苦了,网上比较多的是两驱差速,四驱看到一个差速的,四驱全向没找到
                小鱼 技术大佬 @956635683
                @956635683 这个大概率没有的,需要自己整
