    3.4.3系统信息获取与发布——c++版本代码
    ros2 cpp
    1.8k
    • A
      admin_
      背景:
      【《ROS 2机器人开发从入门到实践》3.4.3系统信息获取与发布】 https://www.bilibili.com/video/BV1GnH5eGEC3/?share_source=copy_web&vd_source=1a420da13de2005a4b95c85b21a48ff4
      目前,该视频只有python版本的发布者代码,我已经照着视频改了一版cpp的代码。测试通过,可以正常运行。运行依赖于3.4.2节的接口和3.4.5的消息展示,这两节的内容课程中都有对应的cpp实现,所以,本篇文章只针对3.4.3节只有python实现的代码进行cpp实现。
      代码:
      src/status_publisher/src/sys_status_pub.cpp
      #include "rclcpp/rclcpp.hpp"
      #include "status_interfaces/msg/system_status.hpp"
      #include "sys/sysinfo.h"
      #include <bits/local_lim.h>
      #include <cstring>
      #include <ctime>
      #include <fstream>
      #include <iostream>
      #include <sstream>
      #include <string>
      #include <unistd.h>
      using SystemStatus = status_interfaces::msg::SystemStatus;
      class SysStatusPub : public rclcpp::Node {
        private:
          rclcpp::Publisher<SystemStatus>::SharedPtr _status_publiser;
          rclcpp::TimerBase::SharedPtr _timer;
          void timer_callback() {
              struct sysinfo info;
              if (sysinfo(&info) != 0) {
                  RCLCPP_ERROR(this->get_logger(), "获取系统信息失败");
                  return;
              /*TODO:计算CPU使用率*/
              float cpu_percent = (float)(info.loads[0] * 100 / (1 << SI_LOAD_SHIFT));
              /*获取内存信息*/
              float memory_percent = (float)(info.totalram - info.freeram) / info.totalram * 100;
              float memory_total = (float)info.totalram / (1024 * 1024);
              float memory_available = (float)info.freeram / (1024 * 1024);
              /*获取网络I/O计数器*/
              float net_sent = 0.0;
              float net_recv = 0.0;
              getNetworkIO(net_sent, net_recv);
              auto msg = std::make_shared<SystemStatus>();
              /*获取当前时间并设置消息的时间戳*/
              msg->stamp = this->get_clock()->now();
              /*获取主机名*/
              char hostname[HOST_NAME_MAX];
              if (gethostname(hostname, HOST_NAME_MAX) == 0) {
                  msg->host_name = hostname;
              } else {
                  msg->host_name = "unknown";
              msg->cpu_percent = cpu_percent;
              msg->memory_percent = memory_percent;
              msg->memory_total = memory_total;
              msg->memory_available = memory_available;
              msg->net_sent = net_sent;
              msg->net_recv = net_recv;
              // RCLCPP_INFO(this->get_logger(), "发布:%s", rclcpp::tostring(*msg).c_str());
              // std::cout<<msg<<std::endl;
              // rclcpp::fromStdstring
              /*发布消息*/
              _status_publiser->publish(*msg);
          /*从/proc/net/dev文件读取网络I/O信息并汇总字节数*/
          void getNetworkIO(float &net_sent, float &net_recv) {
              std::ifstream file("/proc/net/dev");
              if (!file) {
                  RCLCPP_ERROR(this->get_logger(), "无法打开/proc/net/dev文件");
                  return;
              std::string line;
              /*跳过文件头两行,头两行为标题信息等,不是具体数据*/
              std::getline(file, line);
              while (std::getline(file, line)) {
                  std::stringstream iss(line);
                  std::string interface;
                  /*读取网络接口名称*/
                  std::getline(iss, interface, ':');
                  /*去除接口名称后的空格*/
                  interface.erase(interface.find_last_not_of(" \n\\t") + 1);
                  /*对应接受和发送字节的位置,在文件中固定顺序*/
                  long long int bytes_recv, bytes_sent;
                  iss >> bytes_recv;
                  /*跳过中间其他统计数据,直接读取发送字节数*/
                  for (int i = 0; i < 7; ++i) {
                      long long int t;
                      iss >> t;
                  iss >> bytes_sent;
                  net_recv += (float)bytes_recv / (1024 * 1024);
                  net_sent += (float)bytes_sent / (1024 * 1024);
              file.close();
        public:
          SysStatusPub() : Node("sys_status_pub") {
              /*创建发布者,话题名称为“sys_status”,队列长度为10*/
              _status_publiser = this->create_publisher<SystemStatus>("sys_status", 10);
              /*创建定时器,每隔1s触发一次回调函数*/
              _timer = this->create_wall_timer(std::chrono::seconds(1), std::bind(&SysStatusPub::timer_callback, this));
      int main(int argc, char **argv) {
          rclcpp::init(argc, argv);
          auto node = std::make_shared<SysStatusPub>();
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      src/status_publisher/CMakeLists.txt
      project(status_publisher)
      endif()
      # find dependencies
      find_package(rclcpp REQUIRED)
      find_package(status_interfaces REQUIRED)
      # find_package(rosidl_default_generators REQUIRED)
      add_executable(sys_status_pub src/sys_status_pub.cpp)
      ament_target_dependencies(sys_status_pub rclcpp status_interfaces)
      if(BUILD_TESTING)
      endif()
      install(TARGETS sys_status_pub
      ament_package()
      启动
      打开两个终端,分别进入你的工作空间目录下,分别执行sys_status_pub和sys_status_display。
      wd@ubuntu22:~/cpp_proj/241224/topic_practice_workspace$ colcon build
      wd@ubuntu22:~/cpp_proj/241224/topic_practice_workspace$ source install/setup.bash
      在第一个终端运行:
      wd@ubuntu22:~/cpp_proj/241224/topic_practice_workspace$ ros2 run  status_display sys_status_display
      在第二个终端运行:
      wd@ubuntu22:~/cpp_proj/241224/topic_practice_workspace$ ros2 run status_publisher sys_status_pub
      运行结果
      因为图片用外链工具生成,不保证时效性,大家可以自己运行一下,看看结果。
      运行结果图
      1 条回复 最后回复 回复 引用 1
      • A
        admin_
        在msg获取到系统状态信息后,python用RCLCPP_INFO输出msg内容,cpp不太会把共享指针指向的内容换成字符串输出。所以该部分没有实现,但是不打印msg并不影响发布msg的内容,对于结果是没有影响的。希望有大佬可以看看应该这里怎么做
        小鱼小 1 条回复 最后回复 回复 引用 1
          小鱼 技术大佬 @admin_
          @admin_ 不借助些复杂手段,没办法直接序列化msg成字符串并打印(C++中很不好做),只能自己手动拆msg,按照消息结构数据类型打印。
          A 1 条回复 最后回复 回复 引用 1
          • A
            admin_ @小鱼
            @小鱼 好滴,谢谢鱼总
