    虚拟机上ros2 建立pkg失败
    求助ai和csdn找不到 下载过yolov5 conda,pytorch d455相机相应插件
    172.2k
      rrrooosss @小伊
      @小伊 (My_torch) ros2@ros2:~/chapt/topic_ws$ /home/ros2/miniconda3/envs/My_torch/bin/python /home/ros2/chapt/topic_ws/src/yolov5_ros2_node/yolov5_ros2_node/yolov5_ros2_node.py
      File "/home/ros2/chapt/topic_ws/src/yolov5_ros2_node/yolov5_ros2_node/yolov5_ros2_node.py", line 1, in <module>
      import rclpy
      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/init.py", line 49, in <module>
      from rclpy.signals import install_signal_handlers
      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/signals.py", line 15, in <module>
      from rclpy.exceptions import InvalidHandle
      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/exceptions.py", line 15, in <module>
      from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/impl/implementation_singleton.py", line 32, in <module>
      rclpy_implementation = import_c_library('._rclpy_pybind11', package)
      File "/opt/ros/humble/lib/python3.10/site-packages/rpyutils/import_c_library.py", line 39, in import_c_library
      return importlib.import_module(name, package=package)
      File "/home/ros2/miniconda3/envs/My_torch/lib/python3.10/importlib/init.py", line 126, in import_module
      ImportError: /home/ros2/miniconda3/envs/My_torch/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/_rclpy_pybind11.cpython-310-x86_64-linux-gnu.so)
      The C extension '/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/_rclpy_pybind11.cpython-310-x86_64-linux-gnu.so' failed to be imported while being present on the system. Please refer to 'https://docs.ros.org/en/{distro}/Guides/Installation-Troubleshooting.html#import-failing-even-with-library-present-on-the-system' for possible solutions
        这个错误信息表明在尝试运行 yolov5_ros2_node.py 脚本时,Python 无法正确加载 ROS 2 的 C 扩展 _rclpy_pybind11,原因是缺少特定版本的 libstdc++.so.6 库。具体来说,错误提示缺少 GLIBCXX_3.4.30 版本。
        libstdc++.so.6 是 GCC 的标准 C++ 库,而 ROS 2 依赖的某些组件可能需要较新版本的这个库。以下是一些可能的解决方案:
        1. 更新 GCC:
          通常,GLIBCXX_3.4.30 是 GCC 10 或更高版本引入的。你可以尝试更新你的 GCC 版本。使用以下命令检查当前的 GCC 版本:
          gcc --version
          如果版本低于 10,你可能需要升级 GCC。在 Ubuntu 上,你可以通过添加 PPA 来安装较新的 GCC 版本,或者使用如 conda 这样的环境管理工具来安装特定版本的 GCC。
        2. 设置 LD_LIBRARY_PATH:
          如果你有正确版本的 libstdc++.so.6,但系统没有默认使用它,你可以通过设置 LD_LIBRARY_PATH 环境变量来指定库的搜索路径。例如:
          export LD_LIBRARY_PATH=/path/to/your/libstdc++:/usr/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH
          替换 /path/to/your/libstdc++ 为包含正确版本 libstdc++.so.6 的目录。
        3. 使用 Docker 或 Singularity:
          为了避免系统依赖冲突,可以考虑使用 Docker 或 Singularity 来运行 ROS 2。这些容器技术允许你创建一个包含所有必需依赖项的隔离环境。
        4. 重新编译 ROS 2:
          如果你从源代码安装了 ROS 2,并且你的系统 GCC 版本已经足够新,尝试重新编译 ROS 2 可能有助于解决问题。这可以确保所有的二进制文件都是与你的系统库兼容的。
        5. 检查 Conda 环境:
          由于你在 Conda 环境中运行 ROS 2,确保该环境没有干扰系统级的库。有时,Conda 环境可能会提供与系统不兼容的库版本。尝试在一个干净的、没有额外库干扰的环境中运行你的代码。
        如果上述方法都不能解决问题,建议查阅 ROS 2 的官方文档或社区论坛寻求更具体的帮助。
        3 1 条回复 最后回复 回复 引用 0
          rrrooosss @小伊
          @小伊 from yolov5.models.experimental import attempt_load
          from yolov5.utils.general import non_max_suppression, scale_coords
          from yolov5.utils.torch_utils import select_device这几行代码[{
          "resource": "/home/ros2/chapt/topic_ws/src/yolov5_ros2_node/yolov5_ros2_node/yolov5_ros2_node.py",
          "owner": "python",
          "code": {
          "value": "reportMissingImports",
          "target": {
          "$mid": 1,
          "path": "/microsoft/pyright/blob/main/docs/configuration.md",
          "scheme": "https",
          "authority": "github.com",
          "fragment": "reportMissingImports"
          "severity": 4,
          "message": "无法解析导入“yolov5.utils.torch_utils”",
          "source": "Pylance",
          "startLineNumber": 11,
          "startColumn": 6,
          "endLineNumber": 11,
          "endColumn": 30
          "owner": "python",
          "code": {
          "target": {
          "$mid": 1,
          "scheme": "https",
          "severity": 4,
          "message": "无法解析导入“yolov5.utils.general”",
          "startLineNumber": 10,
          "startColumn": 6,
          "endLineNumber": 10,
          "endColumn": 26
          "owner": "python",
          "code": {
          "target": {
          "$mid": 1,
          "scheme": "https",
          "severity": 4,
          "message": "无法解析导入“yolov5.models.experimental”",
          "startLineNumber": 9,
          "startColumn": 6,
          "endLineNumber": 9,
          "endColumn": 32
            这些错误信息表明,在使用 Pylance(一个用于 Python 的静态类型检查器)进行代码检查时,Pylance 无法解析你的代码中尝试从 yolov5 库导入的模块。这通常意味着 Pylance 无法在你的项目环境或 Python 路径中找到这些模块。以下是几个可能的解决方案:
            1. 确保 YOLOv5 已正确安装:
              确保你已经正确安装了 YOLOv5 库。如果你还没有安装,你可以通过以下命令安装(假设你正在使用 pip):
              pip install yolov5
              或者,如果你是从源代码安装的 YOLOv5,确保源代码目录已经被添加到了 Python 的路径中。
            2. 检查 Python 环境:
              确保你的开发环境(如 VSCode)使用的是正确的 Python 解释器,这个解释器应该已经安装了 YOLOv5 库。在 VSCode 中,你可以通过状态栏选择正确的解释器,或者通过命令面板 (Ctrl+Shift+P 或 Cmd+Shift+P 在 Mac 上) 搜索并选择 "Python: Select Interpreter"。
            3. 配置 Pylance:
              Pylance 有时候需要一些额外的配置来正确地识别第三方库。你可以尝试在你的项目中创建一个 pyrightconfig.json 文件,并在其中指定 Python 路径或额外的类型存根。不过,对于大多数情况,只要库正确安装并且解释器设置正确,这一步通常不是必需的。
            4. 重启开发环境:
              有时候,开发环境(如 VSCode)需要重启才能识别新安装的库。尝试重启你的开发环境。
            5. 检查 YOLOv5 的安装路径:
              如果 YOLOv5 是从源代码安装的,确保源代码位于一个标准的 Python 库路径中,或者确保你已经在你的项目中设置了正确的路径。你可以通过 Python 的 sys.path 来查看当前的库搜索路径。
            6. 手动指定类型提示:
              如果问题依旧存在,且不影响代码运行(只是类型检查失败),你可以考虑在导入语句上方添加 # type: ignore 来忽略这些特定的类型检查错误。但这通常不是最佳实践,因为它会隐藏潜在的类型问题。
            通过以上步骤,你应该能够解决 Pylance 无法解析 YOLOv5 导入的问题。如果问题仍然存在,可能需要更详细地检查你的项目配置或寻求 YOLOv5 社区的帮助。
              rrrooosss @小伊
              @小伊 在 虚拟机上ros2 建立pkg失败 中说:
              上述代码中的/camera/rgb/image_raw话题应与您的D455相机发布图像数据的话题相匹配。如果需要发布检测结果到ROS话题,请取消result_pub相关行的注释,并定义result_pub。
              应该怎么去 匹配以及定义result_pub
                在ROS 2(Robot Operating System 2)中,确保你的节点能够正确发布和订阅话题是非常重要的。根据你提供的信息,似乎你正在尝试与Intel RealSense D455相机进行交互,并且希望发布检测结果到ROS话题。以下是如何匹配话题和定义result_pub的步骤:
                1. 匹配话题
                首先,确保你的ROS节点订阅的话题与D455相机发布图像数据的话题相匹配。通常,Intel RealSense ROS 2驱动程序会发布一系列默认话题,例如/camera/rgb/image_raw用于RGB图像,/camera/depth/image_raw用于深度图像等。
                • 检查相机发布的话题:你可以使用ros2 topic list命令来列出当前所有活动的话题。确保D455相机已经正确配置并正在运行,然后查找类似/camera/rgb/image_raw的话题。
                • 确保代码中的订阅话题匹配:在你的ROS 2节点代码中,确保你订阅的话题名称与相机发布的话题名称完全一致。例如,如果你的相机确实发布到/camera/rgb/image_raw,你的订阅代码应该类似于:
                  self.subscription = self.create_subscription(
                      Image,
                      '/camera/rgb/image_raw',
                      self.listener_callback,
                      10  # QoS 参数
                2. 定义result_pub
                如果你需要在处理完图像数据后发布检测结果,你需要定义一个发布者(Publisher)。以下是如何在Python中实现这一点的步骤:
                • 导入必要的包:确保你已经导入了rclpy和sensor_msgs.msg.Image或其他你需要发布的消息类型。
                • 创建发布者:在你的ROS 2节点初始化函数中(通常在__init__方法中),创建一个发布者。例如,如果你想要发布检测结果作为另一种图像消息,你可以这样做:
                  from rclpy.node import Node
                  class MyNode(Node):
                      def __init__(self):
                          super().__init__('my_node')
                          # 订阅话题代码...
                          # 创建发布者
                          self.result_pub = self.create_publisher(Image, '/detection_results', 10)  # QoS 参数
                          self.timer_period = 1  # 秒
                          self.timer = self.create_timer(self.timer_period, self.timer_callback)
                      def timer_callback(self):
                          # 在这里处理图像并准备发布结果
                          # 例如,创建一个Image消息实例
                          result_image = Image()
                          # 填充result_image数据...
                          # 发布结果
                          self.result_pub.publish(result_image)
                      # 其他方法,如listener_callback...
                • 在回调函数中发布:或者,你可以在处理图像数据的回调函数中直接发布结果。确保在发布前填充好消息的所有必要字段。
                3. 运行和测试
                • 启动RealSense节点:确保你的RealSense ROS 2驱动程序节点正在运行,并且正在发布图像数据。
                • 运行你的节点:启动你的ROS 2节点,它将订阅图像数据并可能发布检测结果。
                • 使用ros2 topic echo测试:你可以使用ros2 topic echo /detection_results sensor_msgs/msg/Image来查看发布的检测结果(确保根据你的实际消息类型调整命令)。
                通过这些步骤,你应该能够成功匹配话题并定义result_pub来发布检测结果。如果遇到任何问题,检查话题名称、消息类型和节点日志可能会提供有用的调试信息。
                  rrrooosss @小伊
                  @小伊 (My_torch) ros2@ros2:~/YOLO-Realense_RC$ /home/ros2/miniconda3/envs/My_torch/bin/python /home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/realense.py
                  Namespace(weights='/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/runs/train/exp10/weights/best.pt', source='', img_size=640, conf_thres=0.25, iou_thres=0.45, device='', view_img=False, save_txt=False, save_conf=False, save_dir='runs/relense', classes=None, agnostic_nms=False, augment=False, update=False, name='exp', nosave=False)
                  YOLOv5 🚀 2024-12-2 torch 2.5.1 CPU
                  /home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/models/experimental.py:118: FutureWarning: You are using torch.load with weights_only=False (the current default value), which uses the default pickle module implicitly. It is possible to construct malicious pickle data which will execute arbitrary code during unpickling (See https://github.com/pytorch/pytorch/blob/main/SECURITY.md#untrusted-models for more details). In a future release, the default value for weights_only will be flipped to True. This limits the functions that could be executed during unpickling. Arbitrary objects will no longer be allowed to be loaded via this mode unless they are explicitly allowlisted by the user via torch.serialization.add_safe_globals. We recommend you start setting weights_only=True for any use case where you don't have full control of the loaded file. Please open an issue on GitHub for any issues related to this experimental feature.
                  ckpt = torch.load(w, map_location=map_location) # load
                  Fusing layers...
                  /home/ros2/miniconda3/envs/My_torch/lib/python3.10/site-packages/torch/functional.py:534: UserWarning: torch.meshgrid: in an upcoming release, it will be required to pass the indexing argument. (Triggered internally at /opt/conda/conda-bld/pytorch_1729647176142/work/aten/src/ATen/native/TensorShape.cpp:3595.)
                  return _VF.meshgrid(tensors, **kwargs) # type: ignore[attr-defined]
                  Model Summary: 392 layers, 46611336 parameters, 0 gradients, 114.0 GFLOPS
                  0: 480x640 Done. (0.522s)
                  File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/realense.py", line 167, in <module>
                  detect()
                  File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/realense.py", line 138, in detect
                  cv2.imshow(p, im0)
                  cv2.error: OpenCV(4.10.0) /io/opencv/modules/highgui/src/window.cpp:1301: error: (-2:Unspecified error) The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Cocoa support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function 'cvShowImage'
                    错误信息表明你在使用 OpenCV 的 cv2.imshow() 函数时遇到了问题。这个错误通常发生在没有正确配置或安装支持 GUI 的库时。错误信息提示:“The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Cocoa support.” 这意味着 OpenCV 在尝试显示图像窗口时,缺少必要的 GUI 后端支持。
                    由于你使用的是 Ubuntu 系统,以下是一些可能的解决步骤:
                    1. 安装 GTK+ 开发库:
                      OpenCV 在 Linux 上通常依赖 GTK+ 来支持 GUI 功能。你可以通过安装 libgtk2.0-dev 和 pkg-config 来解决这个问题。在终端中运行以下命令:
                      sudo apt-get update
                      sudo apt-get install libgtk2.0-dev pkg-config
                    2. 重新编译 OpenCV(如果适用):
                      如果你从源代码安装了 OpenCV,并且之前没有包含 GUI 支持,你可能需要重新编译 OpenCV,并确保在配置阶段启用了 GTK+ 支持。这通常涉及到运行类似 cmake 的命令,并确保设置了正确的选项。不过,由于你使用的是通过包管理器安装的 OpenCV(看起来像是通过 pip 安装的预编译版本),这一步可能不适用。
                    3. 检查 OpenCV 的安装:
                      确认你的环境中安装的 OpenCV 版本和配置。由于你是通过 Python 的 pip 安装的,确保没有版本冲突或错误的安装。可以尝试重新安装 OpenCV:
                      pip uninstall opencv-python opencv-python-headless
                      pip install opencv-python
                      注意:opencv-python-headless 版本不包含 GUI 功能,因此确保只安装了 opencv-python。
                    4. 使用其他方法显示图像:
                      如果你不需要在屏幕上实时显示图像,可以考虑将图像保存到文件中,而不是使用 cv2.imshow()。这可以通过使用 cv2.imwrite() 函数来实现。
                    5. 检查环境变量:
                      确保你的环境变量正确设置,特别是与显示相关的变量,如 DISPLAY。如果你在远程服务器上运行代码,并且没有图形界面,这将是一个问题。你可以使用 SSH 的 -X 选项来启用 X11 转发,但这要求服务器和客户端都正确配置了 X11。
                    尝试上述步骤后,再次运行你的脚本,看看问题是否得到解决。如果问题仍然存在,可能需要更详细地检查你的系统配置或寻求更具体的帮助。
                      rrrooosss @小伊
                      1. 安装 GTK+ 开发库:
                        sudo apt-get update
                      3. 检查 OpenCV 的安装:
                      4. 使用其他方法显示图像:
                      5. 检查环境变量:
                      File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/realense.py", line 14, in <module>
                      from models.experimental import attempt_load
                      File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/models/experimental.py", line 7, in <module>
                      from models.common import Conv, DWConv
                      File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/models/common.py", line 15, in <module>
                      from utils.datasets import letterbox
                      File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/utils/datasets.py", line 23, in <module>
                      from utils.general import check_requirements, xyxy2xywh, xywh2xyxy, xywhn2xyxy, xyn2xy, segment2box, segments2boxes,
                      File "/home/ros2/YOLO-Realense_RC/YOLO-Realense_RC/utils/general.py", line 29, in <module>
                      cv2.setNumThreads(0) # prevent OpenCV from multithreading (incompatible with PyTorch DataLoader)
                      AttributeError: module 'cv2' has no attribute 'setNumThreads'
                        从你提供的错误信息来看,问题不在于 GUI 显示功能,而是 cv2 模块中不存在 setNumThreads 这个属性。这通常意味着你安装的 OpenCV 版本与你的代码不兼容。
                        cv2.setNumThreads(0) 这个函数用于设置 OpenCV 在处理图像时使用的线程数,这个功能在某些 OpenCV 版本中可能不可用或者已经被移除。这里有几个可能的解决步骤:
                        1. 确认 OpenCV 版本:
                          检查你当前安装的 OpenCV 版本。你可以通过 Python 脚本打印出 OpenCV 的版本来确认:
                          import cv2
                          print(cv2.__version__)
                        2. 更新或降级 OpenCV:
                          如果你的代码依赖于特定版本的 OpenCV,你可能需要更新或降级你的 OpenCV 安装。如果 setNumThreads 在新版本中被移除,你可能需要找到一个替代方法,或者降级到一个包含该功能的旧版本。使用 pip 可以轻松地更新或降级:
                          # 安装特定版本的 OpenCV
                          pip install opencv-python==<desired_version>
                        3. 修改代码:
                          如果 setNumThreads 函数在你的 OpenCV 版本中不可用,并且你不想或不能更改 OpenCV 版本,你可能需要修改代码以移除对该函数的调用。这可能需要你理解该函数在代码中的作用,并找到一个替代的实现方式,或者简单地移除这行代码(如果它对程序的功能不是必需的)。
                        4. 检查依赖关系:
                          确保你的项目中所有依赖库都是兼容的。有时候,库之间的不兼容会导致意想不到的错误。
                        5. 查阅文档和社区:
                          查阅 OpenCV 的官方文档或相关社区(如 Stack Overflow),看看是否有其他人遇到了类似的问题,并找到了解决方案。
                        在进行上述任何更改后,确保重新运行你的代码以验证问题是否已解决。如果问题仍然存在,可能需要更深入地调查代码和库的兼容性。
                          rrrooosss @小伊
                          在image_callback函数中,添加将检测结果发送到STM32的代码:
                          import serial
                          串口初始化(在main函数之前)
                          ser = serial.Serial('/dev/ttyUSB0', 9600, timeout=1) # 调整端口和波特率以适应您的需求
                          发送函数
                          def send_to_stm32(message):
                          ser.write(f"{message}\n".encode('utf-8'))
                          在检测到目标后发送消息到STM32
                          for *xyxy, conf, cls in det:
                          label = f'{model.module.names[int(cls)]} {conf:.2f}'
                          result_msg = f"{label} at ({xyxy[0]}, {xyxy[1]})"
                          rospy.loginfo(result_msg) # 仅在ROS节点日志中打印结果(可选)
                          send_to_stm32(result_msg) # 发送结果到STM32
                          这个意思是要将这个函数放在image_callback函数中吗
                            是的,您的理解是正确的。根据您提供的代码段和描述,目的是在ROS 2(Robot Operating System 2)的环境中,当图像回调函数(image_callback)检测到目标时,将检测结果通过串口发送到STM32微控制器。
                            以下是如何实现这一功能的步骤和示例代码:
                            1. 确保串口初始化:在您的ROS 2节点主函数(通常是包含ros2 node启动命令的函数)之前,初始化串口连接。
                            2. 定义发送函数:创建一个函数,用于通过串口发送消息到STM32。
                            3. 在image_callback中调用发送函数:在图像回调函数中,当检测到目标时,调用这个发送函数,将结果发送到STM32。
                            示例代码
                            import serial
                            import rospy
                            from some_detection_library import detect_objects  # 假设您有一个用于检测目标的库
                            # 串口初始化(在main函数之前)
                            ser = serial.Serial('/dev/ttyUSB0', 9600, timeout=1)  # 根据需要调整端口和波特率
                                通过串口发送消息到STM32
                            def image_callback(image_msg):
                                图像回调函数,处理图像并发送检测结果到STM32
                                # 假设您有一个函数可以从图像消息中提取数据并进行目标检测
                                # 这里用detect_objects作为示例
                                det = detect_objects(image_msg)  # 这个函数应该返回检测到的目标列表
                                    label = f'{model.module.names[int(cls)]} {conf:.2f}'  # 假设model.module.names包含目标名称
                                    rospy.loginfo(result_msg)  # 打印结果到ROS日志(可选)
                            def main(args=None):
                                rospy.init_node('your_node_name')
                                image_sub = rospy.Subscriber('image_topic', Image, image_callback)  # 根据您的实际情况调整主题名
                                rospy.spin()
                            if __name__ == '__main__':
                                try:
                                except rospy.ROSInterruptException:
                                    pass
                                finally:
                                    ser.close()  # 确保在程序结束时关闭串口
                            注意事项
                            • 串口权限:确保您的用户有权限访问指定的串口。在Linux上,您可能需要将当前用户添加到dialout组或更改串口的权限。
                            • 串口设备名:根据您的操作系统和连接的设备,串口设备名(如/dev/ttyUSB0)可能会有所不同。
                            • 错误处理:在实际应用中,添加错误处理(如串口连接失败的处理)是很重要的。
                            • ROS 2消息类型:确保image_msg的类型与您的ROS 2节点订阅的主题类型相匹配。在上面的示例中,我假设主题类型为sensor_msgs/Image,但具体类型可能因您的应用而异。
                            • 检测库:detect_objects函数是一个假设的函数,您需要根据您使用的目标检测库进行替换。
                            通过以上步骤,您应该能够在ROS 2环境中实现将检测结果通过串口发送到STM32的功能。
                              rrrooosss @小伊
                              @小伊 你能把d455通过yolov5进行识别得到信息,并通过ros2humble得到,并传给stm32使他点灯的完整代码和步骤说一下吗
                                实现将Intel RealSense D455相机通过YOLOv5进行目标识别,并将识别信息通过ROS 2 Humble传递给STM32以控制其点灯的完整流程和代码涉及多个步骤。以下是一个简化的指南:
                                一、准备工作
                                1. 硬件准备:
                                  • Intel RealSense D455相机
                                  • STM32开发板
                                  • 连接线(如USB线)
                                2. 软件准备:
                                  • 安装ROS 2 Humble
                                  • 安装Intel RealSense SDK
                                  • 安装YOLOv5及其ROS 2封装(如yolov5_ros2)
                                  • 安装STM32开发环境(如STM32CubeMX和Keil)
                                二、步骤一:设置ROS 2工作空间并安装YOLOv5 ROS 2包
                                1. 创建并初始化ROS 2工作空间:
                                  mkdir -p ~/ros2_ws/src
                                  cd ~/ros2_ws/
                                  colcon build
                                  source install/setup.bash
                                2. 下载并安装yolov5_ros2包(假设已有现成的ROS 2封装):
                                  cd ~/ros2_ws/src
                                  git clone [yolov5_ros2的Git仓库地址]
                                  cd ..
                                  colcon build
                                三、步骤二:配置Intel RealSense D455相机
                                1. 安装Intel RealSense SDK:
                                  按照Intel官方文档安装RealSense SDK。
                                2. 运行RealSense节点以发布图像话题:
                                  使用RealSense ROS 2封装(如realsense2_camera)来运行相机节点。
                                  ros2 run realsense2_camera realsense_node_factory
                                  确保相机发布的图像话题(如/camera/color/image_raw)可以被YOLOv5 ROS 2节点订阅。
                                四、步骤三:运行YOLOv5 ROS 2节点进行目标识别
                                1. 修改YOLOv5 ROS 2节点的参数以订阅RealSense相机的图像话题,并设置其他相关参数(如模型路径、设备类型等)。
                                2. 运行YOLOv5 ROS 2节点:
                                  ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p image_topic:=/camera/color/image_raw -p device:=cpu # 或使用GPU,如-p device:=gpu
                                五、步骤四:编写STM32代码以接收ROS 2消息并控制点灯
                                1. 在STM32上设置串口通信:
                                  配置STM32的串口(如USART)以接收来自ROS 2系统的消息。这通常涉及设置波特率、数据位、停止位和校验位等参数。
                                2. 在ROS 2系统中添加串口发布节点:
                                  编写一个ROS 2节点,将YOLOv5的识别结果通过串口发送给STM32。这可能需要使用ROS 2的串口桥接功能或自定义一个串口发布节点。
                                  示例代码(Python):
                                  import serial
                                  import rclpy
                                  from your_custom_msg_type import YourDetectionResult  # 替换为实际的消息类型
                                  class SerialPublisherNode(Node):
                                      def __init__(self):
                                          super().__init__('serial_publisher_node')
                                          self.serial_port = serial.Serial(port='/dev/ttyUSB0', baudrate=115200)  # 根据实际情况设置串口和波特率
                                              YourDetectionResult,
                                              '/yolo_result',  # YOLOv5 ROS 2节点发布的话题
                                              10  # 队列大小
                                      def listener_callback(self, msg):
                                          # 将ROS 2消息转换为串口数据格式并发送
                                          serial_data = self.convert_to_serial_format(msg)
                                          self.serial_port.write(serial_data.encode())
                                      def convert_to_serial_format(self, msg):
                                          # 实现消息到串口数据格式的转换
                                          pass  # 这里需要具体实现转换逻辑
                                      rclpy.init(args=args)
                                      node = SerialPublisherNode()
                                      rclpy.spin(node)
                                      node.destroy_node()
                                      rclpy.shutdown()
                                3. 在STM32上编写接收串口数据并控制点灯的代码:
                                  在STM32的固件中编写代码以接收串口数据,并根据数据内容控制点灯。这通常涉及中断服务程序(ISR)或轮询方式来读取串口数据,并根据数据的特定格式或值来执行相应的点灯操作。
                                六、注意事项
                                1. 串口通信的可靠性:确保串口通信的波特率、数据格式等参数在ROS 2节点和STM32之间一致,并注意处理可能的数据丢失或错误。
                                2. STM32的资源限制:STM32的处理能力和内存资源有限,因此在编写代码时要考虑优化算法和数据结构以减少资源占用。
                                3. 安全性:如果系统需要与外界通信或控制关键设备,请考虑添加适当的安全措施(如加密、身份验证等)。
                                由于篇幅限制和具体实现的复杂性,上述指南提供了一个简化的流程和示例代码框架。在实际开发中,可能需要根据具体需求和环境进行详细设计和调试。
                                  rrrooosss @小伊
                                  创建并初始化ROS 2工作空间:
                                  cd ~/ros2_ws/
                                  colcon build
                                  cd ~/ros2_ws/src
                                  cd ..
                                  colcon build
                                  还没有现成的,需要有完整的代码
                                    在虚拟机上设置ROS 2工作空间并尝试安装YOLOv5 ROS 2包时遇到建立包失败的问题,可能有几个原因。以下是一些可能的解决步骤和建议:
                                    1. 确认ROS 2安装正确:
                                      确保你的ROS 2环境已经正确安装,并且所有依赖都已满足。你可以通过运行ros2 --version来检查ROS 2是否安装成功。
                                    2. 检查Git仓库地址:
                                      确保你克隆的YOLOv5 ROS 2包的Git仓库地址是正确的。如果地址错误或仓库不存在,git clone命令会失败。
                                    3. 检查网络问题:
                                      如果你在使用虚拟机,确保你的虚拟机可以访问外部网络,特别是Git仓库所在的服务器。网络问题可能导致克隆失败。
                                    4. 依赖问题:
                                      YOLOv5 ROS 2包可能依赖于其他ROS 2包或Python库。如果缺少这些依赖,colcon build可能会失败。查看YOLOv5 ROS 2包的CMakeLists.txt或package.xml文件,确认所有依赖都已列出,并尝试手动安装这些依赖。
                                    5. 查看构建错误:
                                      当colcon build失败时,它通常会输出错误信息和堆栈跟踪。仔细阅读这些信息,它们可以提供为什么构建失败的线索。
                                    6. 工作空间问题:
                                      确保你的工作空间路径(如~/ros2_ws)没有权限问题,并且所有的目录都正确创建。
                                    7. 使用正确的shell:
                                      确保你使用的是与ROS 2兼容的shell(如bash)。某些命令(如source)在不同的shell中可能表现不同。
                                    8. 清理工作空间:
                                      如果之前构建失败,尝试清理工作空间后再重新构建。你可以删除build和install目录,然后再次运行colcon build。
                                      rm -rf ~/ros2_ws/build ~/ros2_ws/install
                                      colcon build
                                    9. 查看ROS 2社区和文档:
                                      如果问题依然存在,查看ROS 2的官方文档、GitHub问题跟踪器或相关社区论坛,看看是否有其他人遇到并解决了类似的问题。
                                    10. 确保YOLOv5 ROS 2包是完整的:
                                      如果提示说“还没有现成的,需要有完整的代码”,确保你克隆的仓库包含了所有必要的代码和文件。有时,仓库可能不完整或处于开发状态,这可能导致构建失败。
                                    按照这些步骤操作后,你应该能够更接近解决问题的根源。如果问题仍然无法解决,可能需要更详细的错误信息来进一步诊断。
                                      rrrooosss @3513232534
                                      @3513232534 在 虚拟机上ros2 建立pkg失败 中说:
                                      创建并初始化ROS 2工作空间:
                                      cd ~/ros2_ws/
                                      colcon build
                                      cd ~/ros2_ws/src
                                      cd ..
                                      colcon build
                                      还没有现成的ros2封装,完整的代码怎么写呢
                                        如果你还没有现成的 YOLOv5 的 ROS 2 封装,那么你需要自己创建一个 ROS 2 包,并在其中集成 YOLOv5。以下是一个基本的步骤指南,帮助你创建一个 ROS 2 包并在其中集成 YOLOv5。
                                        步骤 1:设置 ROS 2 工作空间
                                        首先,确保你已经设置好了 ROS 2 工作空间。如果你还没有,可以按照以下步骤操作:
                                        cd ~/ros2_ws/
                                        colcon build
                                        步骤 2:创建一个新的 ROS 2 包
                                        在 src 目录下创建一个新的 ROS 2 包。这里我们假设你要创建一个名为 yolov5_ros2 的包:
                                        cd ~/ros2_ws/src
                                        ros2 pkg create --build-type ament_cmake yolov5_ros2
                                        这将创建一个基本的 ROS 2 包结构。
                                        步骤 3:集成 YOLOv5
                                        1. 下载 YOLOv5 代码:
                                          首先,你需要下载 YOLOv5 的代码。你可以使用 git clone 命令或者直接下载 ZIP 文件。
                                          cd ~/ros2_ws/src/yolov5_ros2
                                          git clone https://github.com/ultralytics/yolov5.git
                                          或者,你也可以手动下载 YOLOv5 的代码并解压到 yolov5_ros2 包中。
                                        2. 修改 CMakeLists.txt:
                                          在 CMakeLists.txt 文件中,你需要添加对 YOLOv5 的依赖和编译指令。这通常涉及到设置包含目录和链接库。但是,YOLOv5 主要是用 Python 编写的,所以你可能需要更关注如何在 ROS 2 中调用 Python 脚本。
                                          如果你打算用 Python 调用 YOLOv5,你可以直接在 ROS 2 包的 setup.py 中添加 YOLOv5 的依赖,并在你的 ROS 2 节点中导入 YOLOv5 的 Python 代码。
                                        3. 编写 ROS 2 节点:
                                          在 yolov5_ros2/yolov5_ros2 目录下创建一个 Python 脚本(例如 yolov5_node.py),并在其中编写 ROS 2 节点代码,调用 YOLOv5 的功能。
                                          import rclpy
                                          import sys
                                          sys.path.append('/path/to/yolov5')  # 根据实际情况修改路径
                                          from models.experimental import attempt_load  # 假设你要使用 experimental 模型
                                          class YOLOv5Node(Node):
                                              def __init__(self):
                                                  super().__init__('yolov5_node')
                                                  # 加载 YOLOv5 模型
                                                  self.model = attempt_load('yolov5s.pt', map_location='cpu')  # 修改为你的模型路径
                                                  # 你可以在这里添加订阅者、发布者等
                                                  # 处理接收到的消息,调用 YOLOv5 进行推理等
                                                  pass
                                              yolov5_node = YOLOv5Node()
                                              # 添加订阅者等
                                              rclpy.spin(yolov5_node)
                                              yolov5_node.destroy_node()
                                              rclpy.shutdown()
                                          注意:这里的代码只是一个示例,你需要根据 YOLOv5 的实际 API 和你的需求进行调整。
                                        4. 修改 package.xml 和 setup.py:
                                          确保在 package.xml 和 setup.py 中添加了对 Python 和其他依赖的描述。
                                        步骤 4:编译和运行
                                        回到工作空间的根目录,编译你的包:
                                        cd ~/ros2_ws/
                                        colcon build
                                        然后,你可以运行你的 ROS 2 节点:
                                        ros2 run yolov5_ros2 yolov5_node.py
                                        请注意,由于 YOLOv5 主要是用 Python 编写的,并且可能依赖一些特定的库和配置,所以在集成过程中可能会遇到一些问题。你可能需要根据实际情况对代码和依赖进行调整。
                                          rrrooosss @小伊
                                          步骤 3:集成 YOLOv5
                                          下载 YOLOv5 代码:
                                          修改 CMakeLists.txt:
                                          这里应该建立ament_python吧
                                            在 ROS 2 中集成 YOLOv5 确实需要注意 YOLOv5 主要是一个基于 Python 的项目,而 ROS 2 支持多种编程语言,包括 C++ 和 Python。由于 YOLOv5 是用 Python 编写的,因此在 ROS 2 中集成它时,使用 ament_python 构建类型可能更合适,而不是 ament_cmake。以下是更详细的步骤,指导你如何在 ROS 2 中正确集成 YOLOv5:
                                            步骤 1: 创建 ROS 2 包
                                            由于 YOLOv5 是基于 Python 的,你应该使用 ament_python 构建类型来创建 ROS 2 包。首先,删除之前可能创建的 ament_cmake 包,然后重新创建一个 ament_python 包:
                                            # 删除之前的包(如果存在)
                                            rm -rf ~/ros2_ws/src/yolov5_ros2
                                            # 创建一个新的 ament_python 包
                                            ros2 pkg create --build-type ament_python yolov5_ros2
                                            步骤 2: 下载 YOLOv5 代码
                                            进入你新创建的 ROS 2 包目录,并下载 YOLOv5 代码:
                                            或者,你可以手动下载 YOLOv5 的代码并解压到 yolov5_ros2 包中的某个目录(例如 yolov5 目录)。
                                            步骤 3: 修改 setup.py
                                            在 setup.py 文件中,你需要添加 YOLOv5 的依赖。由于 YOLOv5 是一个 Python 项目,你可能需要确保所有必要的 Python 依赖项都被正确安装。YOLOv5 通常有一个 requirements.txt 文件列出了它的依赖项。你可以将这些依赖项添加到你的 ROS 2 包的 setup.py 中,或者通过创建一个单独的 requirements.txt 文件并在工作空间中安装它们。
                                            例如,你可以在 yolov5_ros2 包目录下创建一个 requirements.txt 文件,内容类似于 YOLOv5 的 requirements.txt,然后使用以下命令安装这些依赖项:
                                            # 在你的 ROS 2 工作空间的根目录下
                                            pip install -r src/yolov5_ros2/requirements.txt
                                            同时,在 setup.py 中,你可能需要添加一些额外的入口点,以便 ROS 2 可以识别你的 Python 节点。
                                            步骤 4: 编写 ROS 2 节点
                                            现在,你可以开始编写一个 ROS 2 节点,该节点将调用 YOLOv5 的 Python 代码。你可以创建一个新的 Python 脚本,在这个脚本中导入 YOLOv5 并执行必要的操作。确保你的节点正确地发布和订阅 ROS 2 主题或服务,以便与 ROS 2 生态系统集成。
                                            步骤 5: 构建和测试
                                            最后,不要忘记构建你的 ROS 2 工作空间并测试你的集成:
                                            colcon build
                                            # 运行你的 ROS 2 节点
                                            ros2 run yolov5_ros2 your_node_name
                                            通过这些步骤,你应该能够在 ROS 2 中成功集成 YOLOv5,并利用其强大的目标检测功能。
                                            3 4 条回复 最后回复 回复 引用 0
